Cleaning white brake hoods
Likes For pickettt:
Probably about like white handlebar tape... getting grease off of plastic probably requires solvent or something abrasive... try something counterintuitive like olive oil and follow that with some vinegar to clean off the olive oil. Otherwise, WD-40 is your last hope!
Bikes: TRIMMED DOWN THE HERD
Quoted: 1095 Post(s)
Liked 947 Times
One of my bikes has them. I used to wipe them down weekly. I gave up after a few weeks. No matter what I do, the dirt is on there on the first ride after a clean.
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Mr. Clean Magic Eraser.
Or gentle soap and water on a terrycloth towel.
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Likes For CroMo Mike:
Made in Taiwan
Bikes: Camerotti ti roadbike, Old Sears Free Spirit Tange Hi-Ten Single Speed built from a 12 speed, 1997 Cannondale CAD3 r500 with Shimano 6400 groupset
Quoted: 35 Post(s)
Liked 11 Times
I find Dawn dish soap diluted with water in a spray bottle and a soft terrycloth towel works best. Try to avoid rubbing alcohol or other solvent type cleaners, I find that they tend to dry out the rubber. Which leads to the hoods cracking.
All dogs want to be lap dogs doesn't matter the size
-Animal loving friend
Quoted: 4560 Post(s)
Liked 2,804 Times
Best stuff by far I've tried is LA's Totally Awesome Grill & Oven Cleaner. Big pump spray bottle, costs a whole buck at Dollartree. Works on white hoods, white cable housings, pretty well on a white saddle cover.
It's not the caustic stuff in compressed gas cans. It smells like the main ingredient is ammonia, with the usual surfactants, etc. but it works better than anything else I've tried, including Dawn, Windex, Clorox foaming bleach spray, alcohol, nail polish remover, WD-40, dry erase sponge erasers, all the usual household stuff.
Whatever it is (the maker lists no significant hazardous materials), it cuts through grime and grease better than anything I've tried other than petroleum solvents.
It leaves the hoods feeling a bit softer and grippier, but I'd avoid using it too often. Strong ammonia can weaken latex. I use it about once or twice a year, and clean up in between with Dawn or any dish washing soap.
Quoted: 1626 Post(s)
Liked 2,693 Times
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
This! Been using Magic Eraser on my white saddle and bar tape. Bar tape is over two years old and is still very white.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Cycleway town
Rubber is a pig to clean, same problem with whitewall tyres. No easy answer!
In addition to the above, I have used the Purple Power cleaner / degreaser. The problem with any method may leave them sticky afterwards. For that, I rub them with a bit of olive oil.
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times
How about trying some TSP (tri sodium phosphate). Available where ever cleaning supplies are sold (even in the grocery store). It's a good grease and grime cutter.
Jon
Jon
Quoted: 660 Post(s)
Liked 601 Times
Quoted: 551 Post(s)
Liked 278 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Liked 2,804 Times
Westley's Bleche-White and LA's Totally Awesome Grill & Oven cleaner contain mostly the same or similar ingredients, per their respective MSDSs. Some folks claim the original Bleche-White formula was changed a few years ago and doesn't work as well now. Dunno, haven't used it in decades.
Neither product lists "bleach" among the ingredients, nor ammonia -- to my surprise. Sure smells like ammonia.
Incidentally, Clorox Foaming Bleach Cleanser pump spray didn't work particularly well on white brake hoods. It's a good household cleanser otherwise.
And don't mix cleansers willy-nilly trying to make them "better". Mixing bleach and ammonia creates chlorine gas, very dangerous stuff. I suspect that's one reason some cleansers have switched away from bleach and ammonia to other surfactants and boosters.
