Which 16" 36h aluminum/lightweight rim should I buy (USA)?
I need a lightweight 16 inch 36 hole rim with available tubes (USA).
Sun Ringle M-14A Rim Sun 16 349x12.4
Sun Ringle M-14A Rim Sun 16 349x18.9
The second one "18.9" is wider and probably easier to buy tubes for?
Like this tube... Sunlite Tube 16X1 Pv 32Mm (349X19) ?
Any rim is plenty strong enough for my purpose.
Thanks.
If this post goes in "mechanics" or elsewhere, please feel free to correct.
Thanks.
Thanks.
Thanks.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
The tube size goes with the tire width, not the rim. The rim makes only a little difference.
Cycleway town
That's usually a child's wheel, so tubes will typically be quite girthy, and tyre choices can be frustrating.
Not to be confused with 16 3/8 rims, as used by Brompton etc, which have a bead seat radius just 3mm smaller than an 18ins wheel - those tyres and tubes are available in thinner sizes, including popular choices like the Schwalbe Marathon.
Edit - had to correct a figure..
