Gloves With Best Padding - Please Chime In
Bikes: '72 Paramount 15-9, '74 Schwinn Paramount P10-9, '73 Schwinn Super Sport, 1983 Schwinn Voyageur SP,17 Motobecane Cafe Noir, 1970 Raleigh Competition Tourist, 1999 Rans V-Rex
Liked 83 Times
I'm getting old and hands get numb around the 5-mile mark. I know there's other ways to address but I'd like to focus on gloves for now.
What gloves provide the best padding? I'm OK with cost. Just want to find a great pair of gloves.
Thanks!
Thanks!
Funny you should ask, I have 5 pair, the most recent some Specialized with minimal padding that are supposed to relieve stress on the contact points. I was getting ready for my ride the other day and realized all my gloves were in the wash except for some Nashbar vintage looking gloves I never wear, the kind with the knitted tops. I purchased them because they’re what I used years ago thinking they would be perfect if I ever did one of those vintage rides.
My ride is right at 20 miles and usually about 5 miles in my hands start getting numb so I start moving them around, hoods, tops, etc. On the ride with the Nashbar gloves I went about 15 miles before I noticed any sign of hand discomfort. They were noticeably more comfortable and I found I was moving my hands less than all my more expensive gloves. YMMV
I think you may be looking at the effect rather than the cause. You might need to check your fit on the bike and putting too much weight on your hands.
Likes For jayhawkpanic:
As far as fit goes, aside from riding like a German motorcycle cop, you’re eventually going to get numbness in your hands as you age closer to your golden years.
Unfortunately Nashbar no longer has the crochet gloves.
Liked 1,484 Times
I recently got a pair of Rivendell's summer gloves, my first new pair of them in probably a dozen years or more. It takes longer for the numbness to creep in with these than with the gloves I had before, which were generic cheap Bells with thinner pads. FWIW, the bikes ridden with these gloves both have dropped bars set with the tops about level with the saddle and both used shellacked cloth bar tape. It works for me.
Likes For Reynolds 531:
You can buy gel pads that are designed to fit the handlebars, under the tape. This both dampens vibrations and increases the handlebar diameter to reduce nerve activation.
Likes For T-Mar:
Same here. I could never wear padded globes. The lumps of padding make my hands hurt. I use unpadded gloves. When I was younger, I mostly didn't wear gloves at all, except in racing. Point is, extra thick padding may help numbness, but could make it worse. Depends on you.
Likes For Salamandrine:
aged to perfection
Liked 1,317 Times
I aways found the (now no longer available) Spencos to be excellent. There was a pair of Castelli gloves available with gel padding a couple years ago.
you can try the no-name gel gloves offered on eboy.
Another thing you might try is to put padding under your bar tape. Almost all of my bikes have some kind of padding (left over piece of bar tape, or a gel pad) under the tape on the bar tops.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Liked 526 Times
Interesting timing for this thread. I used to buy a pair of the $7 Nashbar gloves every 2 years or so. I went there this week, and they don't have 'em any more.
Where are your hands getting numb? What gloves are you using now? How do you have your bars wrapped, or what style of grip are you using?
SP
Nwpt, OR
Likes For rando_couche:
Liked 1,362 Times
Most of the modern gloves seem to have an odd padding pattern that doesn't pad where I need it to on a vintage bike. However, Aerotech makes crochet leather gloves that have really nice padding. They do tend to run a little large though...according to their site I should use size large, but the mediums fit me better. https://www.aerotechdesigns.com/gelpaleandco.html
Liked 83 Times
I ride on heavily padded (gel pads) bars, bars with just one layer of the thick Fizik tape and bars with just cloth tape. I move my hand position (back of levers, lower part of bars, straddle the bar at the top) to keep my hands as "numb free" as possible. Gloves help but as we get older, I think this is a common problem.
I've tried using gel pads under bar tape, double wrap etc. Same issue.
I'm good on 23" to 24" frames. Same problem. Adjusting bar and/ or seat height doesn't make that much of a difference unless I go to ape hangers! No problem with those bars
I've about 10 bikes in the collection. At this point, I'd like to get thoughts on the best gloves out there. For me, thickest padding is likely what I need.
Ulnar nerve neuropathy, or what they call cyclist's palsy is no laughing matter. This used to plague me badly back in the day. I found this to be a good article on the subject, and ways to help prevent it.
Unfortunately I don't have any recommendations for the best modern gloves as all of my pairs are old stuff.
One tip may be to ride with less pressure in your tires, within reason, if you can swing it.
https://www.physio-pedia.com/Cyclist%27s_palsy
señor miembro
Bikes: '70s - '80s Campagnolo
Liked 6,654 Times
Search ebay's cycling gloves category for "mesh" and/or "crochet" and go from there. I've had good luck with inexpensive ones in the $12 range...
meh
Liked 1,013 Times
Yep, same here. I used Serfas RX gloves with some luck but still had numbness. I've been riding without gloves for the last 2 years and rarely had an issue. This includes ultra-endurance rides - like a 240-mile one day rides... no numbness.
Polymultiplié
Bikes: Yes, please.
Liked 4,896 Times
My favorite gloves are these, from Tre Emme. I bought a pair two years ago because I liked the way they look, but like them so much that I bought another two pairs two weeks ago when I was back in Italy. They haven't much in the way of padding - just an extra layer of goat skin - but apparently that works well for me.
Likes For non-fixie:
Liked 523 Times
Bike Butcher of Portland
Bikes: It's complicated.
Liked 6,007 Times
My take is different. Heavily padded saddles aren't the cure for sore behinds, the shape is much more important. Similarly, my hands don't like skinny handlebars, I've been pre-wrapping with a split down the middle old inner tube to beef up the bar diameter for decades, with a finish wrap on top. The inner tube doesn't add any noticeable cushion, it's just free material for me. The larger radius distributes the weight over a larger area.
Others that mention saddle adjustment, ofttimes one that's pointed down will cause you to constantly have to push back on the bars. If you look at someone that's been riding a Brooks B17 for awhile you might think it's pointed up slightly.
Once your setup is optimized, moving your hands around often while riding is the generally accepted method to keep the dreaded hand fatigue away.
Likes For gugie:
