Bar tape tape
Quoted: 2651 Post(s)
Liked 2,006 Times
Bar tape tape
I re-wrapped my handlebar this weekend, and didn't finish it with electrical tape -- a first!
After previous wrappings, I'd use the tape included in most bar tape boxes, and then to make sure it held, give it a wrap or two of electrical tape. This time, I forgot where I'd put the electrical tape. What was in the box was long enough to make almost two wraps, more than I remember from previous wrappings. It's held for two whole days now.
What's other people's experience with the tape-that-comes-in-the-box? How well does it hold, is it really long enough, and does it hold on its own?
Señor Member
Quoted: 649 Post(s)
Liked 294 Times
I find the included strip of tape is not flexible enough to make a clean cover for the end of the handlebar tape. Electrical tape usually looks better, and is available in many colours from the dollar store.
Another option is to finish the wrap in twine or string...
https://www.rivbike.com/pages/handle...d-twine-finish
Likes For Wilfred Laurier:
Quoted: 2027 Post(s)
Liked 1,099 Times
I also found the included finishing tape is too rigid to make a smooth wrap so I still use electrical tape. I tried the silicone self-adhering tape I've seen suggested here but found it curls up at the edges too easily so it doesn't stay put.
It varies—some works fine, others not. I usually don't like the loud logos on it, and enjoy finding colored electrical tape to match an accent color on the bike.
Likes For cpach:
Sr Member on Sr bikes
I don't use adhesive tape (especially electrical tape) to secure the bar tape. In an unconventional method, I start at the top and wrap down. When I get to the end of the bars...I tuck the excess into the bar, and insert the bar end stopper to hold it. Been doing it that way for years with not problems.
I've seen some (actually did this on one of my bikes) who will start at the top, wrap down the the break lever, then using another piece, wrap from the bottom up to the brake lever. Then, secure it all under the hood. No adhesive tape showing anywhere.
Dan
Dan
Likes For _ForceD_:
Quoted: 206 Post(s)
Liked 102 Times
For the past few years, I’ve been using black shrink tape to finish off my wraps. I cut a 3/4” piece and slide it on the bar up to the stem (I have to remove the brakes, of course). Then I do the wrap and secure the tag ends with a small piece of tape, slide the shrink tape over the end, and heat it up. Looks great and holds perfectly. You’ll have to measure your bars to see what diameter you’ll need - I use the 2” size.
gallery
gallery
Some days, it's not even worth gnawing through the restraints.
my experience is that it doesn‘t hold. Therefore i double up with a color matched zip tie.
Electrical tape, or any tape that has adhesive, is a thing of the past. People are using self-fusing silicon tape to finish their bar wraps these days. No adhesive at all: it simply naturally fuses to itself.
Likes For AndreyT:
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
Liked 1,099 Times
As I mentioned in my posting above, I tried that tape and found when I rode with my hands on the bar tops I would catch the edges which tended to curl up and slip even if the tape were pulled as tight as it would tolerate. I suppose it works if you only ride the hoods or the drops.
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
Liked 2,006 Times
It is more of a matter of wrapping technique. The trick is to stretch the first loops of the tape (to make it conform) and keep the last loop or two relaxed to prevent creep. Too much stretch in the last loop, and any tape will creep and likely leave residue, no matter how good it is.
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
Wow ! Just learned something new, thanks for the tip. Heading to Home Depot , tomorrow. KB
Quoted: 1324 Post(s)
Liked 927 Times
I've given up on commercial bicycle handlebar tape due to its expense, thickness, fast wear, and difficulty securing the ends by the reinforcing sleeve of the handlebar. I now use Renfrew Brand Hockey Tape to wrap my bars. When I get the tape up to the reinforcing sleeve i just carefully cut the tap as it is and push it down onto the bar. This tape sticks really well and is hard to find the end of later it I want to unwrap the handlebar for any reason. I don't regret using it on any of my bikes as it's quite durable.
Cheers
Cheers
Likes For Miele Man:
Quoted: 942 Post(s)
Liked 527 Times
I have found that the tape that comes with SupaCaz is awesome and superior to electrical tape (at least on the version I have).
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4383 Post(s)
Liked 3,054 Times
I use electrical tape for a good tight adhesion, and then cover that with the decorative stuff not too tight.
Likes For DiabloScott:
Quoted: 1975 Post(s)
Liked 232 Times
really, either are interchangeable, the adhesive is the same. I like the super 88 better because you can get away with like 2 wraps around the tape to secure. I also don't overlap onto the bar itself so don't need it to conform to anything really
Rhapsodic Laviathan
Another trick I learned is to wrap the bar with etape sticky side up, bottom to the lever. So if you take a spill or otherwise rip the bartape, it just won't come off. It does (etape)work better under tension, like bartape if it isn't stretched too far.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
Silicone tape is my new goto. Only sticks to itself, easily removable, leaves no residue, does not creep, and keeps the bar tape reusable if you ever need to remove or rewrap it.
Rhapsodic Laviathan
Dan
Dan
Advocatus Diaboli
Quoted: 4823 Post(s)
Liked 1,557 Times
Trying to understand why if there even was residue, who cares. It's either covered up by your next wrap or covered by your tape. 3M electrical tape has no issues 'not sticking'.
Liked 232 Times
I think people are referring to electrical tape residue when the tape slips or moves from cheap electrical tape, I've seen it on other bikes. Makes for a mess on top/sides of the finishing electrical tape and can even get on your hands/gloves
