Any tips on easing a sore hip?
I had a sore hip yesterday.
Not too bad and right on the hip bone.
Now the side isn't so sore as much as the side of the lower back.
Any little tips on easing the pain would be appreciated.
Quoted: 318 Post(s)
Liked 149 Times
I can't say anything definitive, but sometimes stretching is the cure. I had hip pain so bad it was debilitating. The doctor said there was no structural damage and sent me to physical therapy for stretching, which fixed me right up. In my case the piriformis stretch seemed to do the most good.
Quoted: 347 Post(s)
Liked 418 Times
Could be really tight hip flexors that are hurting? You could try a form roller to roll yourself out after riding. There are many YouTubes from cyclists on using a form roller. The one from Julie Elliot is my favorite for using the roller. Using it on your hip flexors is a bit controversial, but I’ve found it very helpful after hard rides.
I was just in to see the PT for similar issue. He suggested:
He also did some pinned stretching on me which hurt, but helped immediately. From here is just working on mobilization of the hip and occasional nerve gliding.
Quoted: 604 Post(s)
Liked 1,064 Times
Ibuprofen, or any other non-steroidal anti-inflammatory agent, or aspirin, as long as your not allergic.
Tim
Tim
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Lower your saddle slightly.
Quoted: 663 Post(s)
Liked 496 Times
https://youtu.be/iLTBIaHU5iw
Likes For berner:
I had a similar running induced injury a few years ago. I think it was a tight psoas muscle. Stretching and ibuprofen were key to a speedy recovery.
+1 for foam rolling. I went to PT where I got some Theragun treatments also You can make your own for about $1, with an old golf ball and a jigsaw blade (and the powered jigsaw you already own). There is a youtube on it. I really like my DIY version.
Likes For PdalPowr:
Quoted: 1088 Post(s)
Liked 1,354 Times
And very possibly great advice. It took me years to get over hip pain resulting from a too high seat. Steroids were involved in making the pain go away. Thankfully it is gone now, and I have a lower seat, no pain, and rode across Indiana and Ohio this year fully loaded, with no pain. Check out Steve Hogg's site. https://www.stevehoggbikefitting.com...ard-can-it-be/ and https://www.stevehoggbikefitting.com...d-can-it-be-2/
Likes For phughes:
Go and see a Physical Therapist, ideally one who specializes in sports PT and fits bikes. I had some issues with my hips/glutes/hammies this year and the PT I'm seeing has helped give me exercises that work for me and engage the glutes fully. As the PT would say, I am now 'more functional'.
Likes For rydabent:
Quoted: 5234 Post(s)
Liked 3,609 Times
haven't looked into hip issues, but did some research about shoulders. pretty sure I have an impingement so I'm avoiding over the head lifting & taking Nonsteroidal anti-inflammatory drugs (NSAIDs) which block the COX enzymes and reduce prostaglandins throughout the body. As a consequence, ongoing inflammation, pain, and fever are reduced. I was doing occasional ibuprofen w/ some improvement, so trying this for a week or so & I'm, pleased but I mistakenly put a sheet of drywall away at work the other night & felt a twinge. pissed at myself. good luck with your hip!
Bikes: Fred cycles
Quoted: 34 Post(s)
Liked 18 Times
I have a Brooks saddle that's slightly uneven. Caused terrible hip pain on one side. Adjusting the saddle so my butt was evenly supported (regardless of the position of the nose) fixed the issue.
Likes For duffer1960:
Liked 1,354 Times
How was it uneven? The reason I ask, is my B17 showed dimpled off-centered, which was a result of the saddle being too high, and me dropping to one side to compensate. That caused the hip problems I had. This was after being fitted too high. Lowering the saddle fixed the issue, and now I sit properly centered not he saddle, and the dimples have now reformed properly centered on the seat.
Occam's Rotor
Liked 2,331 Times
I have this weird feeling that my Brooks saddle is too low, but if I raise it, I get the hip issue.
There seems to be a reoccurring theme here...
Likes For Cyclist0108:
Quoted: 451 Post(s)
Liked 364 Times
Some good advice above. I would only add that you really don't want to take NSAIDs for any longer than absolutely necessary, as they increase stroke risk pretty markedly. That said, when you need 'em, you need 'em. I am currently on Alleve for a bad tooth--so there you go...
Liked 3,609 Times
Liked 3,609 Times
This is interesting .... I've had both hips replaced and had 1 1/2 years of trouble free cycling, I started thinking I was a "more serious" cyclist as my distances increased and raised my seat thinking it'd be where a "more serious" cyclist would have theirs and have had a year of problems.
I lowered it a bit about 4 weeks ago and fingers crossed the issues seem to have gone.
Likes For Witterings:
Quoted: 451 Post(s)
Liked 364 Times
Bikes: 2007 Motobecane Fantom Cross Expert, 2020 Motobecane Omni Strada Pro Disc (700c gravel bike), 2021 Motobecane Elite Adventure with Bafang 500W rear hub drive
Quoted: 174 Post(s)
Liked 144 Times
Plus one on lowering saddle
Just went through left leg episode. No pain while riding bike on magnetic resistance trainer, but significant pain, seemingly out of nowhere at night in bed. Pain radiating out enough that I couldn't even tell if it was leg or abdominal issue. Took a few days of from cycling and went for walks instead. When the problem had lessened, I could localize the intermittent pain, and as best I can tell it was inflamed tendon in hip flexor. At 63 years of age, things that were once easy can cause problems like this.
Lowered seat a half inch and returned to cycling on the trainer after several days of no pain. So far, so good. Did lowering the seat help? Can't be sure, but it seems that what works on the road might not work on indoor trainer. Outdoors you naturally change position, cadence etc. a lot more. Indoors I tend to sit and crank without much change of position, and actually pedal harder than outdoors on the road. So seat height may be more critical the more you stay seated and in the same position fore/aft on saddle.
My issue felt more like a repetitive motion syndrome, possibly a nerve thing the pain was so severe. I'd try taking a reprieve and once the pain subsides, return to cycling at lower intensity for a while until you regain confidence. Also move around to avoid staying in one position; stand up to pedal up hills and whenever butt feels sore.
Likes For Chuckles1:
Liked 1,354 Times
I think you missed wgscott's point. The issue is running it too high. There seems to be a tendency today to jack the seat height too high. This has been made bearable by seats with cutouts, which helps mask a too high seat height. With a Brooks you will feel it, and you will see the dimples offset to one side, as a result of compensating by dropping to one side. If you have the seat height correct, the seat disappears under you. Mine is amazing.
Likes For phughes:
velo-dilettante
Quoted: 1644 Post(s)
Liked 3,192 Times
as long as there's no swelling, a hot tub/jacuzzi will do wonders in the short term.
