What size rear rack do I need?
I am interested in purchasing a light weight rear rack that is compatible with a men's XL Cannondale Quick 5 with disc brakes.
Mad bike riding scientist
Quoted: 6262 Post(s)
Liked 4,282 Times
As for the rack, Tubus is expensive but stiffer and better in the long run.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 18427 Post(s)
Liked 4,544 Times
As @cyccommute suggested, assuming the brake calipers are inside the rear triangle, then a great number of racks will work.
Looking at photos, it appears as if the bike should have both upper and lower rack mounts which makes it easier.
It also looks like the lower rack mount point is about 1" to 1 1/2" above the axle. That means that a rack designed for a 26" wheel may fit the bike quite well, but the size won't make a big difference.
I prefer the "touring" style racks that have some kind of rear support to keep panniers from flopping into the wheel.
Liked 4,282 Times
No. Larger frames are easier to fit racks to than smaller bikes.
Stuart Black
Stuart Black
Cycleway town
Before the tandem I found my bags had to be almost entirely outside the wheelbase on a 26in MTB.
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
Just about any rack should work. Assuming a newer model bike,the flat mount brake should make it simple. You won’t need any kind of spacer or adapter. If you do need an adapter, I would still suggest any rack while using this adapter. It allows for more flexibility over other kinds of disc racks.
My only change would be to have the rear light mount location a bit inboard of the rear of the top platform of the rack to better protect the light.
