Is GRX compatible with XTR?
Bikes: Too many to list
Liked 1,125 Times
Have a cherry condition 2015 XTR 11 speed groupset in a box from when i upgraded a bike to Eagle
am currently planning a gravel build and noticed an SLX cassette specced with a GRX 800 bike build elsewhere
so if GRX works with the mountain cassettes, would it also work with a mtn rdr?
trying to put together a build that uses some of my old but nearly new parts if possible
thanks
thanks
Some Guy on the Road
Bikes: Foundry Chilkoot, Trek Domane
In a word, no.
The rear derailleur still has a road pull ratio, and is compatible with other road levers, but not MTB. The GRX 1x derailleur is just built to work with the existing 11-40 and 11-42 cassettes
Need a cable pull ratio adapter. Then it works fine.
Wolftooth Tanpan
JTEK Shiftmate (8? or 8A?)
I'm using 105 R7000 shifters (same in this regard to GRX) and a Wolftooth Tanpan with an XT M8000-SGS and 11-40. Shifting works great.
Wolftooth Tanpan
+1 for the Tanpan. If you already have the derailleur then it's easier and cheaper to make that work with the shifter
