Velo-Orange Polyvalent with canti mounts
Hi everyone
Does anyone know where I can find a Velo-Orange Polyvalent frame with Canti bosses? VO used to make the Polyvalent with canti mounts until a few years ago and now it's only made with disc. I need a 51cm frame. I've looked on ebay but don't know where else to try. It's the only frame that I know of that has canti mounts set up for 650b wheels and a geometry that would actually fit me (I need as close to 52cm x 52cm as possible). Plus it has a 1" threaded fork. That's a must for me.
Thanks!
Thanks!
Bikes: 1988 Specialized Rockhopper Comp, 2012 Goodrich Randoneuse, 2016 A-Train, 2022 Wilde Dream Engine, 2022 Salsa Mukluk
Liked 98 Times
I'd ask in the 650b google group, somebody over there might know where to find one. You may also be able to find a different frame that'll work there as well.
Liked 4,323 Times
It will cost more money but have you considered a custom build? Alternatively, how about a 650b conversion of a vintage road bike with the right sizing? If you don't like the idea of caliper brakes, you can always get cantilevers brazed on and the bike painted to your liking. [MENTION=381793]gugie[/MENTION] who lives in Portland does this kind of work. There are other builders who will no doubt retrofit an old frame.
working on my sandal tan
Liked 2,600 Times
Bikes: Velo Orange Piolet
Liked 2,013 Times
I think Soma Grand Randonneur ticks all your boxes except 52x52 - it's a little longer.
https://www.somafab.com/archives/pro...neur-frame-set
Hi everyone
Thanks!
Thanks!
The trail is lower, at ~35 vs 45, FYI.
can you privately message me? I did talk to a builder I really like and he tried to talk me into the disc frame. He said he's removed many canti posts and added many disc mounts but never the reverse
Liked 2,600 Times
[MENTION=381793]gugie[/MENTION] is the guy I had in mind. He usually modifies older frames, but this would be along the same lines.
Liked 4,323 Times
This 1993 XO 2 may be too small but it has plenty of tire clearance (26 x 1.75 and fenders easily probably larger). It is designed for drop bars and it is one of the best riding bikes that I own (mine is a 57 cm). I have no connection to the seller:
https://www.ebay.com/itm/1993-Classi...cAAOSwN6VejelK
Likes For erbfarm:
Liked 4,323 Times
This is my '93 XO 2:
Likes For bikemig:
Liked 6,828 Times
You can PM [MENTION=381793]gugie[/MENTION], he will help you get sorted post haste.
Likes For merziac:
With all the options for stem length (0" to 5"), are you still unable to get the bike to fit properly? You could even go negative (-1") on reach by turning the stem around.
The bikemig photo shows a bike with a hugely long stem. My wife's bike has a near zero length stem.
I'm confused.
I'm confused.
Liked 4,323 Times
ambulatory senior
Liked 3,753 Times
Likes For 52telecaster:
Liked 4,323 Times
One more question for y'all. I also like the Velo Orange Campeur frameset, but it's built around 700C wheels (ugh). If I got that frame and had the canti bosses moved to accommodate 650B wheels, what other accommodations would I have to make? How would that affect the BB height? I really like the 460mm chainstay on that frame.
Liked 1,285 Times
Liked 2,600 Times
If you switched one to 650B, you might have a lot of trouble with pedal strike unless you're really careful about it, or use really short cranks. As a data point, my Bianchi has a BB drop of 65mm, but with 650x38B wheels and 165mm cranks, it feels just about perfect.
