SRAM Force eTap AXS Firmware
Bikes: Canyon, Bowman & Colnago
Quoted: 132 Post(s)
Liked 39 Times
I recently upgraded to the SRAM Force eTap AXS disc groupset. So far I'm loving it.
I understand one can update the component firmware via the SRAM AXS app. I downloaded the app from the Google Play store and I was surprised that it had a very low user rating. Many of the complaints seemed to be in regard to the components either not updating the firmware via the app or starting to update and then failing, and essentially bricking their components. With that in mind, I am very apprehensive about attempting to update the firmware.
Has anyone else had issues updating the components' firmware via the AXS app?
Thanks!
Thanks!
Quoted: 1533 Post(s)
Liked 724 Times
Whoah. One whiff of possible bricking, and updates be damned unless there's a must-have fix or new feature, in which case you've gotta wonder how bad you need it.
If it was a popular Android phone, you'd stand a chance of googling an unbrick method, but I bet you'd be totally out in the cold here.
Quoted: 132 Post(s)
Liked 39 Times
I completely agree with you. That is why I'm not going anywhere near the "Update" button. At least not until I am 110% sure everything will work and I won't be left with a modern art paperweight that used to be my rear derailleur.
Liked 724 Times
If this is really a thing, SRAM wanna get on top of it, before EPIC SUPPORT FAIL gets tattooed on their forehead...
You'd think any update bricks should be a no-brainer for warranty.
Zen Master
Is there another way, through SRAM's site perhaps, a SRAM dealer? An avenue with more of a link to the manufacturer?
Ron - Tucson, AZ
Ron - Tucson, AZ
Quoted: 132 Post(s)
Liked 39 Times
I went back to the Google Play store and saw that the AXS app was installed 10,000+ times. The number of reviews totaled only 235. Out of those 235 reviews about two-thirds were negative. Out of those negative reviews only a handful were complaining about the firmware updates bricking their components.
Seemed like the odds were in my favor so I tried to update the firmware.
TOTAL SUCCESS!!!
TOTAL SUCCESS!!!
Likes For mrblue:
Thanks!
Thanks!
I manually paired the device as suggested on the SRAM site. Press AXS on rear until blinking. Tap AXS on front till blinks and repeat on R + L shift levers. Press AXS on rear to save. Takes 30 seconds. Problem solved. Opened app again and started over adding the bike. It works. Not sure I will update again, but the manual pairing fixed the "brick" issue
I updated two SRAM AXS bicycles over the past two weeks.
Neither had any issues.
Each component updated on first try for both bikes.
If it works, why do you need an update? My Specialized Turbo Creo is asking for software updates but it works well. I am not going to touch it.
most times updates contain primary upgrades which they mention in the changelog
sometimes there will be small enhancement that they don't mention
thats why
sometimes and not so often the firmware could be buggy
but rare IMO
thats why
but rare IMO
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
The Shimano app also has pretty poor reviews for the same reasons (bricking / not completing). Looks like the cycling companies should hire some actual app developers.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
It should be noted that just about all consumer device pairing apps get horrible reviews. Look at in-dash entertainment unit app reviews. For Toyota's EnTune app, 'You're better off ****ing duct taping your phone to your dashboard'.
Don't do it! I've tried to update my AXS Rival rear derailleur yesterday have been trying to get it back ever since. Stuck in a update loop where it says the update is cancelled and then wants me to do it again.
Just steadily flashing green and nothing I do can stop it. I'm supposed to be going for a 3 day ride this week and I'm been to my lbs, been on the phone, been emailing.
Nothing yet
Nothing yet
Quoted: 4560 Post(s)
Liked 5,083 Times
It's a bit of a pain having to update each component individually, but it works for me. What I wouldn't do is try to upgrade the night before a big event!
I finally got it going by setting my front derailleur as the primary and syncing the two shifter to that. Then I updated the rear. I think that's what made it work, but I'm not sure. ON othe road again!
Thanks
Liked 5,083 Times
Well done! It's always a bit of a worry whenever updating firmware. I'm inclined to leave my SRAM firmware alone since it all works flawlessly. But I did the last update because it said it was adding trim functionality within the app, which could be potentially useful. I haven't actually checked, but I assume it means you can now adjust the trim directly from the app rather than having to use the lever buttons.
Quoted: 1139 Post(s)
Liked 1,239 Times
Haven't had a problem - about 1 year in. Last two Android versions and three different phones (that's a long story, I'm not a frequent phone changing kind of guy!)
