Garbage Tektro Mech Disc Brake Replacement - (POTENTIAL RABBIT HOLE)
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Liked 132 Times
My OEM brakes are very underwhelming Tektro Aries series mech disc calipers. My biggest complaint is you cannot fine tune the adjustment of the "outer" pad, the only way to adjust is loosening the bolts on the caliper and moving closer to the disc, then adjusting the inside pad. Piss poor design IYAM. Stopping power is not great for my 36lb bike with 29+ tires either but only noticeable on the steepest of descents. Would like to upgrade to more stopping power while I am at it but not AS big of a deal I guess. Rotor size = 203mm front + 180mm rear.
Looking to replace as soon as my pads wear out - biggest factors are
1. price (I have $ but not a pro and I have kids so can't drop $400 on brakes "just cuz")
2. ADJUSTABILITY on BOTH sides (don't care if it's hand or tool, I pack a multi tool)
4. Reliable/Maintenance free (!!) (I don't mind changing out pads or bleeding OCCASIONALLY but constant bleeding is not my deal, I ride EVERY DAY and can tolerate ZERO downtime because I have 1 bike)
So school me here - Do I want to go with something like TRP's Spyke brakes which actuate both sides and look pretty snazzy? For close to that price should I just go with 4 piston hydros (Deore BR MT520s)? What about mech-actuated hydros? Are all hydros adjustable on both sides? Do I really want to deal with the care and feeding of hydros? Should I just go with a known quantity/tried and true product like BB7s?
Riding habits - I commute everyday, barely touch the brakes as the commute is long and flat with few intersection (the MUP I use has some underpasses and overpasses to avoid car traffic). I also ride a singletrack MTB trail network everyday near my house that has some very technical sections and is very steep in spots, lots of rock rolls, step ups, rock race drops, and, well, rocky-rockiness.
I use BB7's, got 180 mm rotors front and rear? Deore will be fabo. Good stuff there. Wait for a sale?
Cheap bang for the buck
https://www.jensonusa.com/Shimano-BR-MT201-Disc-Brake
Not much reason to go mechanical when you can get those instead for the same price or cheaper.
Unless you are riding a down hill bike or weigh 300+lbs there isn't much of a reason to go quad piston.
Likes For Canker:
Which bike do you have? I assume the parts are what you get with the pricepoint.
Even with my BB5, its pretty much set and forget, what's you process for aligning the brakes?
Deores are great for what you pay for them. You don't adjust pads, you're going to need to align like the Tektros and adjust pistons with mineral oil during setup.
It's not rocket science but all disc brakes need some experience. Lots of good YT videos to help out there.
Very Slow Rider
Liked 132 Times
I am no into touring but don't want to rule it out. Even then, I don't see getting up to the 300 lb mark, even fully laden with gear
Very Slow Rider
Liked 132 Times
I ride a Jones Plus LWB. Most Jones bikes are a custom order ordeal. I got a complete bike which is great but not enamored with the brakes or tires. Cost = $2,050 so not the most expensive bike out there but not the cheapest and totally fun.
I have 0 experience with disc brakes; as such, so far it has been the following
Step 1: watch YT
Step 2: loosen bolts and attempt
Step 3: swear a lot
Step 4: take to LBS
My LBS has been great about adjusting for $10 but still the lever feel isn't right.
Is this true on all hydro brakes? I am fine with aligning them, it's the process of getting the gaps between the rotor and pads set up which is annoying so I am looking for easier service, if that means going hydro or more adjustable mech models, then so be it!
Step 1: watch YT
Step 3: swear a lot
Step 4: take to LBS
Disco Infiltrator
Liked 2,116 Times
Hydraulic brakes do adjust automatically. If you have a lightly warped rotor going sing sing sing, it will still do that a bit, and the caliper still needs to be square with the rotor.
I like mine. They did take some breaking in. They are Tektros about the same level as the 200 Shimanos linked above, and use the same pads. No evidence of leaks or air after two years but they could be stronger. I haven’t yet tried any “nice” ones for longer than a test ride.
Bikepacking rigs come with cable brakes for the same reason as touring bikes come with bar cons instead of brifters, and steel frames. They are supposedly easier to deal with malfunction in the field. Trail bikes come hydraulic
If you want to stay mechanical in order of doing:
Upgrade pads to good after market
Upgrade cables to compressionless like Jagwire Mountain Pro. This is the best bang for your buck.
Upgrade Calipers to TRP Spyke with good aftermarket pads. They sell Spykes on Aliexpress for next to nothing, but the stock pads are pretty bad.
I'm at this level with my touring bike. It stops real fast, has good feel and didn't cost the earth. I ride like a loon, carry a heavy load and have 2.5" sticky road tires.
Upgrade discs to Icetech
If you regularly travel then cables are good because you can be brutal with them when boxing and unboxing your bike, one less thing to worry about..
If you want to go hydraulic then maybe get Icetech rotors. Whatever hydraulics you go, make sure they can take Icetech style pads with the cooling fins, they work good on my MTB.
I think the lowest grade Shimano that takes Icetech is the https://bike.shimano.com/en-US/produ...0/BR-M615.html maybe replaced by these https://www.universalcycles.com/shop...68&category=30
Very Slow Rider
Liked 132 Times
Very Slow Rider
Liked 132 Times
Advanced Slacker
Liked 2,557 Times
BB7s or one of the cheaper hydro options mentioned.
IME it is a wash maintenance and hassle-wise.
BB7s require frequent fine tuning as the pads wear, but it is easy to do, especially with the outboard adjuster.
Hydros are virtually maintenance and hassle free...... until they are not, and they have the potential to be a serious PITA. That potential has become a reality for me on a number of occasions over the years.
Likes For Kapusta:
Advanced Slacker
Liked 2,557 Times
Others requires multiple attempts per year to get stubborn bubbles out of a caliper. Luck of the draw.
People in the first group will tell you hydros are absolutely maintenance free.
People in the latter group will tell a different story.
Likes For Canker:
Bleeding brakes is simple work, anyone who wrenches on cars will agree. I don’t understand why that process scares people so much.
Likes For Ross520:
Disco Infiltrator
Liked 2,116 Times
People like to imagine how hard it will be to do something different. I've never been happy with any cable cut I've ever made, so whatevs
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Very Slow Rider
Liked 132 Times
I just don't wan to be messing with it all the time, once in a while for maintenance = ok.
Likes For davei1980:
Occam's Rotor
My kid (your weight) bought these to replace some SRAM brakes that sell for 5X more than the Jenson sale price, and says they are indistinguishable from his XT brakes in terms of performance, and much improved over the SRAM brakes.
Very Slow Rider
Liked 132 Times
I am leaning that way... one guy on the Jones bike page I belong to suggested new levers, which brought new life to his brakes, but shoot, for the price of the levers he was recommending I could damn-near by a set of these 2 piston hydros! Also, new levers doesn't solve for the lack of outboard adjustment problem
Side note - my levers do have two anchor points, it shipped with the cable attached to the canti postion. I moved to the V brake position (less mech leverage) and they do feel better and I can no longer bottom them out. Jeff Jones says you can use either position on the levers but I disagree and so does Tektro.
That's a really good point. I've bled brakes on cars dozens, if not hundreds of times (I used to work on a stock car racing pit crew for a team which traveled on a now-defunct NASCAR developmental league)
Occam's Rotor
Also SLX brakes IMO are the best bang for the buck. Haven't tried the 201s, so can't offer a comparison on them.
Likes For qclabrat:
