Go Back  Bike Forums > Bike Forums > Beach Cruisers
Cruiser Gearing
Beach Cruisers Do you love balloon tires and fenders? Do you love riding the simplicity of a single gear and coaster brakes or a single gear cluster? Do you love the classic curves in the tubing of a cruiser that takes you back to the 1950's and 1960's, stylistically? Here's your home! Welcome to the Beach Cruisers and Cruisers forum!
Cruiser Gearing
Old 05-07-20, 08:40 PM
Cyclist30923
Liked 19 Times in 6 Posts
Cruiser Gearing
My Fito Madena came with a 44t chainring in the front matched with a Shimano 7 speed freewheel, 14 to 28t. After riding it a bit, I swapped out that way-too-big chainring with a Lucky 7 36t. This combo works way better for me, and I am able to use way more of the gears while maintaining much more consistent cadence and higher speeds. I would love to hear what others are using. Eventually I am planning to ditch the heavy one piece crank and install a lighter 3 piece alloy crank.
Cyclist30923 is offline
Old 05-08-20, 08:38 AM
alloo
alloo's Avatar
Bikes: 2022 Priority Coast, 2022 Priority Current
Liked 137 Times in 99 Posts
Is that cruising? Is that racing?
alloo is offline
Old 05-08-20, 09:32 PM
OldCruiser
Bikes: Most of my bikes are Single Speed Conversions
Liked 3,067 Times in 1,015 Posts
I see nothing wrong with lowering the gearing on any bike .
I’ve swapped out chainrings , freewheels, and cassettes on several bike to lower the gearing .
On one of my Electra Cruiser 1’s I swapped out the rear cog for a 23 tooth . I spin out around 11mph , but climb hills without standing up .
IMO , Cruiser Bikes should be just that , an easy peddling cruising bike .
I love making Multi speed cruisers Out of mountain bikes because of the lower gearing .
OldCruiser is offline
Old 05-10-20, 08:02 AM
FiftySix
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Liked 1,176 Times in 795 Posts
My 21st century Schwinn Jaguar cruiser (wife's Jaguar, too) both came with a 46T chainring and a Shimano 7 speed rear with 13, 15, 17, 19, 21, 23, 26.
My wife and youngest daughter actually cruise on the bike, usually in 3rd gear. Which is 46/21 or 56.8 gear inches with the 26 x 2.125 tires.
I rode my Jaguar for quick exercise, not cruising, with 5th gear my usual choice. Which is 46/17 or 70.2 gear inches with the same tires. Typical exercise speeds in that gear would be 15 to 16 mph according to the local street side radar speed signs.
That gear range works good around here because we have no hills, just wind.
FiftySix is offline
Old 05-11-20, 11:28 AM
Cyclist30923
Thanks for all the info everyone! The best gearing is what each of us prefer. The bottom line is that with proper gearing, beach cruisers do not have to be the slow, heavy bikes that weight weanies perceive them to be. With an alluminum frame and lower gearing, 20 mile rides at a brisk pace are pretty routine on my ride.
Likes For Cyclist30923:
Old 06-19-20, 09:23 AM
ed h
Liked 27 Times in 9 Posts
A while back on my Nirve 7 speed cruiser, redid the drivetrain for more usable gearing, as there quite some moderate to steep hills where I ride.
First to go was the mega range freewheel, the 1st to 2nd shift is quite a large gap. Went to 13-34 rear cassette and rims from an older MTB.
Up front did the one piece crankset conversion to a 34 tooth sprocket. Much better for climbing hills.
ed h is offline
Likes For ed h:
Old 06-19-20, 12:00 PM
coopman
Bikes: Specialized Roll Sport Low Entry and Bianchi Super Pista
Liked 61 Times in 44 Posts
I like the simplicity of most of these bikes. I ride a Specialized Roll Sport with 21 gears and, with no hills in my area, end up only using 3-4 of them. The bike is over-equipped for my purposes.
coopman is offline
Old 06-19-20, 03:35 PM
xroadcharlie
Bikes: 2018 Giant Sedona
Liked 117 Times in 96 Posts
The stock approx 41 - 82 gear inch (GI) range your bike came with does seem optimistic for a cruiser style bike. While I seldom use under 41 GI's on my Giant Sedona comfort bike becaues it's mostly flat here, It's good to have some down to the 33 GI's you get now for fighting brisk winds and climbing challenging hills.
My bike came with a 28/38/48T crankset and the Mega range freewheel ed h tossed, and understandably so. It's OK on my bike thanks to its 3 chainrings. But with only one chainring, Not vary practical. In fact that is one reason I didn't buy Giant's Cypress instead. I do like the simplicity of a single chainring, And the stock 42T unit on the Cypress with the mega range freewheel would give me 33 GI's too, But the next step up is 47 GI. WAY too much of a gap.
A 14 - 28 freewheel and a 38T chainring might have worked well for most of my rides giving me a 10 kph @ 60 rpm - 27 kph @ 80 rpm range.
xroadcharlie is offline
Old 06-19-20, 04:45 PM
coopman
True, we are all different and so are our riding situations. If I ever move to a place that has hills, I would probably appreciate having all those gears.
coopman is offline
Old 08-03-20, 11:37 PM
bicyclridr4life
Bicyclerider4life
Bikes: Huffy Beach Cruisers, Miami Sun Trike, Vertical PK7, KHS Montana Summit, Giant Cypress DX, Schwinn OCC Stingray
Liked 11 Times in 8 Posts
My "main ride" these days is a Miami Sun (traditional) trike with the optional 7 speed (14 to 28 tooth) derailleur and rear disk brake.
It came with a 36 tooth chainring.
Because I usually have a "somewhat" heavy load (no, not me) and pull a garden/nursery cart with it, I changed out the 36 tooth chainring for a 28 tooth.
I want ro put on a 14-32 or 14-36 in back.
I'm hauling stuff; not racing. My racing days ended roughly 40 years before I was born.
On some of the hills with 250 pounds in the basket, and 1200 pounds in the lawn/garden cart (I wasn't even overloaded; my garden/nursey cart has a 1400 pound capacity) a 1:1 "granny" gear isn't low enough.
bicyclridr4life is offline
Old 08-04-20, 12:50 PM
GeezyRider
GeezyRider's Avatar
Bikes: There is always room for one more.
Liked 403 Times in 232 Posts
If your trike has a 7-speed spin-on freewheel, I think you will be limited to a max 34t cog. If it is a cassette, you will have more options.
Don
GeezyRider is offline
Likes For GeezyRider:
Old 08-04-20, 05:43 PM
fietsbob
Bikes: 8
Liked 1,360 Times in 866 Posts
2 speed kick back coaster hubs are great on cruisers 1st gets you started, up to 2nd, your cruising speed...
fietsbob is offline
Likes For fietsbob:
Old 08-05-20, 04:02 PM
wayne2000
Bikes: Cruiser, single speed Specialized Hard Rock 1990s
Liked 4 Times in 1 Post
I have a single speed cruiser and I’m thinking my next one will be a 3 speed. Don’t really need more than that.
wayne2000 is offline
Old 08-17-20, 02:13 AM
Jax Rhapsody
Rhapsodic Laviathan
Jax Rhapsody's Avatar
Bikes: Rideable; 83 Schwinn High Sierra. Two cruiser, bmx bike, one other mtb, three road frames, one citybike.
Liked 123 Times in 91 Posts
I wouldn't call a 44t big, much less "too big", they are typical of SS cruisers and rear multi geared ones. It's almost like the 3:73 of cruisers. A tad too slow for me, though. Last cruiser I got was a Nel Lusso and swapped the crank for the one on this old huffy hybrid I had with a I think 52/42 on it. Thing was almost as fast as the one I had years ago with a 62t crank. I swapped out the coaster for a freewheel. I have a bmx 3pc conversion saved for when I can build my DB Drifter1.
Jax Rhapsody is offline
Old 08-17-20, 08:31 AM
xroadcharlie
Recently I experimented using just 2 of my 21 gears on my comfort bike, 55 and 70 gear inches...the 38 and 48T chain rings w/18T rear cog. These 2 gears alone cover a huge territory from slow sidewalk cruising to quick cruising without spinning frustratingly fast. Keeping in mind speed is generally not a priority on comfort/cruiser style bikes.
3 properly spaced gears, perhaps the two I used plus a lower gear for challenging hills would be a huge improvement over a fixed gear without the complexity of derailleurs.
I had a 3 speed "Mustang" style bike when I was a kid. Loved that bike. Used 2nd much of the time, 1st for accelerating and climbing, 3rd with a tailwind.
Old 08-17-20, 12:41 PM
rhenning
Liked 107 Times in 80 Posts
That is why my cruiser has a Bendix red band 2 speed hub. 46 teeth in the front and 19 in the back. Low gear is about a 2 to one reduction. Roger
rhenning is offline
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Your Privacy Choices -
