Mavic Cosmic Hubs Service Question
Any assistance with these would be greatly appreciated.
Before I do any cosmetic damage, anyone care to let me know how to go about servicing these hubs. I have searched for online documentation and come up empty handed.
I am good with servicing the hub except knowing how to remove the bearing covers, the silver Aluminum caps, how do they come off on these hubs.
Both sides of the hub appear the same, not sure if the silver covers unscrew, they pry straight off separating at the seam or there is another approach to removing the covers. Nothing to really grip on to in the way of a tool face.
Other Mavic hubs I viewed in the past similar to these had pin tool holes and appeared as though they unscrewed however these do not.
Thanks for your help in advance.
Finding Mavic technical documentation sucks. I'd tell you to contact them, and you may as well try, but the company is currently kinda bankrupt so you might not get a reply. I'd bet you though that it's such a slight press fit. The worst possible case is I've encountered some wheels (some older Zipps) where you literally had to detention the wheel to remove bearing shields, which is friggin ridiculous. I'd probably try to gently pry the cover off.
Yes, Mavic online documentation is very sparse and I had known about their recent bankruptcy claim and this is somewhat what motivated me to sort these out before they went completely offline.
Thanks again for the reply, take care!
Old Legs
Bikes: '80 Strayvaigin, '84 Ciocc Aelle-Shimano 105, '90 Concorde Astore /Campy Triple ,85 Bridgestone 500/Suntour, 2005 Jamis Quest, 2017 Raleigh Merit 1, Raleigh Carbon Clubman
Quoted: 302 Post(s)
Liked 33 Times
will this help. I have tubular wheels. Bottom page might be your front hub. If like mine, spokes need to come out, I think. My bearings are fine for now. If it comes to removing spokes, off to my LBS. to access spoke nipples , I have to remove the friggin tubular.good luck. If your bearings are fine, just ride.KB
Quoted: 4224 Post(s)
Liked 3,917 Times
IIRC Mavic went to a single use axle cone (actually a sleeve that the bearing ID fit on) in the mid 1990s. When a readjustment or a bearing replacement is done this "cone/sleeve" needs to be replaced. The cone/sleeve is deformed (like a rivet) on it's installation. Hence the single use. I always felt this was a stupid design, a cost savings Mavic would say. I'll speculate that some riders were over tightening the pin holed preload ring, as found on the older hub designs, so Mavic came up with a design that eliminated hone adjustment. Andy
AndrewRStewart
AndrewRStewart
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Got your reply, thanks for the response. Well you were correct, I had posted in a couple of different forums seeking assistance and was not getting any knowledgable response. Don't think they made a lot of these wheels with these particular bearing caps, most Cosmic's came with the black plastic bearing covers. Anyway tried twisting the covers, one side spun however didn't unscrew so pulled out a small flat bladed screw driver and pushed and pried staying with in the limits of doing any cosmetic damage. Detected a bit of separation at the cap/hub seam and eventually the cap popped off. Caps have an inner lip that is just a pressed/snap fit in a grove on the hub outer lip.
Liked 3,917 Times
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
Liked 3,917 Times
Nope to which question? I believe you have the older pin holed preload adjusting version but your reply is vague. Andy
AndrewRStewart
AndrewRStewart
Old Legs
Quoted: 302 Post(s)
Liked 33 Times
