Comfort bike?
Comfort bike?
Trying to find the best comfort bike for a large man. I will mainly ride on paved greenway and maybe some light dirt paths. I really leaning toward the jamis explorer a2. dont really like a the front shock. Looking for a exercise type bike that is comfortable. Any suggestions?
A bike that fits you and your riding style will be comfortable.
Note those upright bikes sold as comfort bikes are only comfortable for short rides. An upright spine is a horrible suspension......
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 766 Times
Other bikes in this same general category that may appeal to you include the Trek Verve, Giant Cypress, and Raleigh Detour. All these bikes have the larger 700c wheels (vs. 26" wheels on the Jamis). Giant's Sedona is probably most like the Jamis, in terms of being a comfort-oriented frame, without front suspension, and with 26" wheels.
With upright bikes like the Jamis and the Giant Sedona, I'd recommend a coil spring seat. You can get very nice ones from Brooks and also less expensive knock-offs from eBay. A sprung seat will add a tremendous amount of vertical compliance to the bike (feel fewer impacts).
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 412 Times
pete2020....did you see this section? https://www.bikeforums.net/clydesdale...-200-lb-91-kg/
It may give you some ideas/options.....
"Comfort Bike" is a bit of a joke, IMO. No matter what bike you decide to get, your time in the saddle will be limited to your tolerance level for butt pain. I have tried about 10 saddles now and have not found one that I can sit on for more than about 30 minutes before I have to take a "butt break". I weigh 220 lbs.
https://bicycleman.com/sun-ez-1-recumbent-bike/
Recumbents have very strong wheels and large seats with built in lumbar support back rests. They are also very adjustable so you can get it adjusted just right for you for you comfort.
I agree with the previous comments. Perhaps you could explain why front suspension is undesirable. For what you're planning to do it certainly isn't necessary but it is a good comfort feature.
That jamis explorer a2 looks like a fine bike.
When bike manufactures install suspension forks and seat posts on entry level bikes, Like a Giant Sedona DX, They may be optimised for "average" riders, perhaps in the 150 - 225 lb range. I know they often have an adjustable preload feature but not sure how effective it might be for men over 200 lbs. I would ask the dealer if a suspension fork would be suitable for your needs. If it is, Look at the Giant Sedona DX. If not, The base Sedona might be a fine choice too after swapping out the suspension seat post with a rigid one, or a custom suspension post for your weight.
My Sedona only has a suspension seat post, Which seems to work well for recreational cyclists absorbing big bumps and isolating me from smaller vibrations, But even at 145 lbs I have the preload set up pretty high, I don't know how well it would work for a heavy man. I'm guessing most suspension forks might have the same limitations. Some better hybrid bikes offer air charged suspension forks that might be adjusted to accommodate your weight.
My next bike will have suspension forks too because I often encounter some rough patches on roads, Sidewalks and MUP's I ride on. I don't know what effect properly adjusted suspension components has on peddling efficiency on smooth roads, They probably do reduce it some, But for recreational cyclists or commuters who regularly ride on rough surfaces it might be well worth it.
The KHS Brentwood or KHS Movo bikes are the only two comfort class I can think of offhand without a front suspension.
