C&V Brings Home Trek Madone...
52psi
Liked 803 Times
...immediately installs San Marco Regal. ![Thumbs Up](images/smilies/thumb.gif)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1200x900/regalmadone12x9_4950c28ee395515b9524b74b87386e66d2f9e99b.jpg)
Likes For Fahrenheit531:
Likes For JustinOldPhart:
52psi
Liked 803 Times
Man. The level of "if you got nuthin' nice to say..." around here is remarkable. That was actually what I had on hand for this morning's shakedown ride and I was sure it'd be a jumping-off point for a brief round of hilarity so I took a picture.
Oh well.
In other news, climbing sure is a different experience.
Oh well.
![lol](images/smilies/lol.gif)
www.theheadbadge.com
Liked 4,524 Times
Likes For cudak888:
Junior Samples
It was an "OK, boomer" moment.
Master Parts Rearranger
Liked 2,038 Times
5600? 6600? With a compact crankset? I like the swoopy carbon fiber and the semi-integrated seatmast. Several years ago, I bought a '16 Trek Emonda ALR6 frameset. Built it up with 7800 components, but 7700 shifters. Silver '17 Raleigh Grand Sport (or similar) wheels with a Campy freehub that I put a 9-speed cassette onto. It got a few groupset combos after that but it worked great and was incredibly light.
52psi
Liked 803 Times
![Big Grin](images/smilies/biggrin.gif)
Right now things feel a bit sluggish from years of sitting unused; time to tear this sucker down and get to work!
Liked 2,038 Times
52psi
Liked 803 Times
Oooh, I like SL. Had a set of 6603 shifters and built up a bike to be sold. Incredibly snappy and sharp. Crummy cables/housings replaced and some spray Tri-Flow lubricant in all crevices of the shifter mechanisms should work a treat. Brought back some 7800 shifters (and 6400 before that) that "air shifted" in below 40-45° weather. Big fan of Tri-Flow, even if Dumonde chain lube (dark green kind) smells better. ![lol](images/smilies/lol.gif)
Liked 2,038 Times
You're welcome! Spray and shift them up and down a ton just to work it all the way around. I had problems finding a good lubricant as WD-40 has the spray and de-gunking feature but is definitely not a lubricant. Other lubricants were bottle/dripping in only, which doesn't get to where it needs to. It's a messy process and the Tri-Flow will spend a little time re-dripping out of the shifter (down the brake lever blade, naturally) after a good session. If you're planning on replacing the bar tape, or keeping it, removing it and all the cables, yet leaving the shifters mounted, may be a good idea as you still have access to all the slots and holes of the shifter (for spraying into) while also having a sturdy platform to actuate shifting up and down as you spray. I would think it wouldn't need more than about 30 seconds to a minute of spray and fidget per shifter, but every shifter is on a case-by-case basis and you'll hear and feel proper snappiness when you do.
Likes For RiddleOfSteel:
