Need help with getting a chain, urgently
Quoted: 9 Post(s)
Hello All,
1st time I've had to do this... the chain has developed some stiff links and no oil can free them up. The bike, Sunn Shaman, is 5-10 years old.
Data: 9 gears on back, 3 on front. 106 links including the joining link (which is a quick release one, needing no tools). Chain internal width is 2.3mm (measured with a caliper). Overall chain length is 137cm.
I have no tools for link removal and need to purchase a chain which is the right length already. I could buy on Amazon and get it next day, if I had a P/N.
Any tips much appreciated...
Peter
Brighton, UK
Peter
Brighton, UK
longtime noob
Bikes: 2018 Trek Domane SL 6 // 1999 Trek 5000 // Burley Encore X
Quoted: 46 Post(s)
Liked 63 Times
Hello All,
Peter
Brighton, UK
Peter
Brighton, UK
Quoted: 9 Post(s)
I am not sure but these are the various logos I can see
STYLO
SRAM X-O
44T95SPD
GXP
TRUVATIV
ELITIS SL
I believe Sunn is a French company. The bike was about 2k GBP and was being discounted to 1.3k because Sunn had gone bust.
It's my fault for not having oiled the chain more often.
STYLO
SRAM X-O
44T95SPD
GXP
TRUVATIV
ELITIS SL
Quoted: 4236 Post(s)
Liked 3,963 Times
I assume you have no LBS nearby or that is open? Here this transaction would take about 5 minutes where I work. Andy (who also lives in a Brighton)
AndrewRStewart
AndrewRStewart
longtime noob
Quoted: 46 Post(s)
Liked 63 Times
I believe any 9 speed SRAM-compatible chain would be just that... COMPATIBLE... but I can't be sure of the length. If you dropped 1300GBP on a bike, I would encourage you to invest just a few more on a chain breaker/pliers.
Better yet, visit your LBS (as Andrew R Stewart recommends)
Quoted: 1956 Post(s)
Liked 2,200 Times
No company makes personalized bike chains with your exact number of links because the next person might need 104 or 110. You can buy a SRAM chain PC-951 and a chain breaker and do it yourself. Or you can take your bike to someone and have it done. Those are your choices.
John
John
Quoted: 1110 Post(s)
Liked 1,050 Times
Without a chain tool you are stuck, the new chain will come 116 links, if shifting has been perfect with the old one you can lay the two out side by side and trim to length but not without a chain tool. I also don't recommend wasting the chain tool on old crusty chains, typically I use bolt cutters to remove them or diagonal cutters and cut one plate at a time. You might have a quick link in the current chain to make it easier to remove though the link can be annoying and in some cases not come apart without the correct tool. Most multi-tools will have a chain tool, if you don't have a multi-tool you should get one for your bike to keep in the saddle bag, over the last 25 years I've needed one maybe 5 times and someone else a couple other times but if you get one with a chain tool you can justify the expense. Just order a kmc x9, any version of 9 will work, and multi-tool and cut the old chain off.
Non omnino gravis
Quoted: 1324 Post(s)
Liked 927 Times
If you can't get a new chain and chain breaker tool easily, then you might try flexing each stiff link side to side and see if that loosens them up.
A lot of Multi-tools for bicycles now come with a chain breaker tool on them.
Seeing as your chain is 9-speed; look at each link carefully and see if one of them isn't a quick-link. You'll see a longish slot on either side of the like if it is a quick-link. With luck, if you have one of those on your bike you'll be able to take the chain off. If you can get the chain off, give it a good scrubbing with a wire brush and then oil it and try flexing any stiff links to free them up. You should be able to reuse the quick-link. Here's an image of an 11-speed quick-link and what it looks like on the chain. A 9-speed on is very similar.
Cheers
Cheers
Quoted: 1439 Post(s)
Liked 1,094 Times
I use the Park Mini Chain Brute https://www.parktool.com/product/min...hain-tool-ct-5 and carry it in my tool roll along with a couple of extra quick links and the cut-off links left from sizing my chain. Then I can open the chain to mend a bad link or add in a few if needed if more than a single link is damaged. I carry a tool made from coat hanger wire, similar to this: https://bicycles.stackexchange.com/q...ink-in-a-chain, to open the quick link easily and to hold the ends of the chain while I insert one. The whole thing fits in my tool roll along with the few hex L-wrenches and other small tools I need; I abhor multi-tools, they do a great many jobs, poorly. The few single-purpose tools I need are smaller, weigh less and do a better job.
Quoted: 212 Post(s)
Liked 83 Times
Hello All,
Peter
Brighton, UK
Peter
Brighton, UK
If you spend $30 on tools and $35 on a chain, you'll be set. If you don't want to buy the right tools, you'll never be able to do it yourself. So if buying the right tools is not on your agenda, take it to a bike shop. It takes them just a few minutes, because they have both the right tools and practice.
First time I replaced a chain it took me a half hour. Now it takes me about 15 minutes, half of which is spent measuring to be sure I get it right, and finding my tools.
Quoted: 9 Post(s)
Yes that quick link posted by Miele Man is exactly what I have, and it came apart fine with just fingers.
I have tried loosening the stiff links with a lot of oil, and movement, but while they were OK for the next ride, they have done stiff again.
AFAIK all bike shops around here are either shut or there are long queues outside. I am too far out of Brighton to ride down there with the bike in this state. But I could do an amazon order now and get it delivered tomorrow. If anyone can suggest some amazon.co.uk part numbers, that would be brilliant I am happy to buy a chain tool also.
Quoted: 9 Post(s)
Quoted: 9 Post(s)
I've been reading up on this. It sounds like I have an SRAM kit and the best chains recommended for that are KMC.
SRAM chains are not so available, too.
If I have this right, with the chain tool you just push out the rivets, and then use a link like above to join it.
My challenge now is to find a KMC 9 speed chain which can be shipped on Monday...
Quoted: 863 Post(s)
Liked 1,105 Times
Quoted: 9 Post(s)
I eventually ordered this lot (all available for Monday delivery, which is amazing) and hopefully it will be ok
[ You are not allowed to post URLs until you have at least 10 posts, it says ]
Out of luck - sorry.
Could not reply sooner due to the 5 posts per 24hrs limitation on this site.
