Chain coming off when switching to higher gears
hi there so i am having an issue lately and honestly would like some insight as to what it could be, so i can figure out average costs of fix.
bike is a btwin triban100, so nothing fancy. has a 7 speed shimano gearing. this article explains better exact gears
lately while switchign to 6th and 7th gear the chain comes off pretty often, or it takes a bti before it finally gets into the gear. any ideas what it could be?
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 682 Post(s)
Liked 767 Times
If this is a recent development on an old bike, I'd suspect a bent rear derailleur hanger. If it's a very slight bend, the problem may be corrected with careful adjustment of the high limit screw.
The hanger can be fixed and it's not difficult, but it requires an expensive shop tool. Adjustment requires some skill and knowledge and a bike stand helps a lot.
bike is about a year and half old, this only started happening very recently though
Blamester
Try a spray of wd40 or similar to begin with. Where the outer cable ends are.
Start simple go from there.
Quoted: 6353 Post(s)
Liked 4,956 Times
Chain coming off the back or the front chain ring?
You been mucking around with limit screws or done anything maybe we should know about?
