How much $$ to update from a 2x9 to a 1x11?
bought a NOS 2018 Kona Rove DL and i'd really like a 1x11 as opposed to the 2x9 that it came with.
that said, i wouldn't be able to do the work myself so i imagine it'd be quite costly to make this update, correct?
has anyone done similar care to weigh in?
thx.
thx.
Liked 2,207 Times
Check to see of the wheels will accept n 11 speed cassette. Else it's a moot point on that wheel, unless you can get a local shop to swap to an 11spd compatible hub.
Edit: Then you need somebodies 1X crank with what is known as a “narrow/wide” chainring, plus bottom bracket. Then an 11 spd. rear shifter, 11 spd. cassette and chain.
Assuming you are paying full retail, given the current bicycling market, I'd say about $600 for the shifters, derailer, cassette, chain and crankset plus $100+ in labour
A few years ago I swapped a 105 2x10sp setup for a SRAM Force 1x11 on an old CX bike. For that project, I needed:
EDIT: The only snag I ran into was learning that chain ring bolts come in different lengths. The ones I bought were too long (for a double chain ring) and so I had to buy shorter ones designed for a single chain ring.
- 11sp shifters/brake levers (you can use 2x11 shifters, but the 1x versions remove the shifting components from the left side, so I guess they save a little weight? They're cheaper)
- 11sp 1x rear derailleur
- 11sp cassette
- 11sp chain
- 110bcd narrow/wide chain ring
- single chain ring bolts (they're shorter than the 2x bolts)
- new brake and shifter cables/housing
- New bar tape (you could probably reuse old, but this is a good time to replace)
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Liked 6 Times
Cheaper and easier is 1x10. Won’t need new shifters or wheels, would just need a 9 Mtb speed derailleur. I run 8/9 speed Deore with 10 speed 105 upfront.
Other derailleur work, but if they don’t have a barrel adjuster you need to add one to the housing near the stem. You could add a derailleur extender to get up to 40t if derailleur capacity is lower.
There are 9 speed long cage, Shimano Altus for example can go up to 40t.
Or get a 10 speed road and add a roadlink, should be able to do 40t in back with that.
Narrow wide is advisable but not essential. I don’t use one on my cx 1x10 setup and have no issues with dropped chains riding single track. Just make sure the chain is the right length. Narrow wide with a clutch derailleur is overkill but nice, my mtb is setup that way. Clutch on its own is supposed to remove the need for narrow wide.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Liked 1,030 Times
+1 on 1x10 being easier. STI is expensive.
If you want clutch, you can use a wolf tooth tanpan. Clutch with Shimano starts at 10sp, and 11sp MTB derailleurs work with 10sp cassettes and shifters.
If you don't need clutch, a 9 sp MTB derailleur will wrap larger cogs.
You don't need a new wheel!!!!!!!!!!!!!!!!!! You just need to run a shimano 11-34 or wider range 11 speed cassette. The 11-32 and narrower 11 speed cassettes are the ones that require a wider freehub body.
Likes For Canker:
Yup
Liked 6 Times
1x11 on a budget with hydro upgrade.
Shimano RS505 shifters with flat mount calipers - $170
Shimano GRX812 rear derailleur - $110
Shimano GRX-RX600 crank - $140
Shimano Deore XT 11-42 cassette - $60
Total - $480
Now that is assuming you are paying full retail for the GRX bits which most places will have a 15-20% coupon so it can be cheaper.
2x9 is still HG so you can use an 11sp MTB cassette no problem.
Total - $480
Likes For gus6464:
Total - $480
Total - $480
$80 MSRP vs $140 for a GRX-RX600 crank.
https://www.wolftoothcomponents.com/...shimano-cranks
