How important is a torque wrench?
I've decided to replace my BB myself.I don't have a torque wrench and have never used one and don't want to spend the money on one.Anyone have some hints on how to tighten the BB by feel?
Likes For fietsbob:
Bikes: CO-OP ADV 3.1 aka Beeftank (stolen, RIP), State All-Road
Liked 144 Times
I’ve removed and installed many a bottom bracket without a torque wrench. No problems yet. I’ve found you can go pretty hard. I do use a torque wrench for most other bits though.
Is it metal or carbon fiber? Since I don't own any 'fiber I have never used a torque wrench on a bicycle...And the old Campy tool kit didn't come with one either. New composite bikes now are a different breed though.
Just don't use any cheater bars and you should be ok. It takes less torque than you think to hold stuff together.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Likes For canopus:
Not very for bottom brackets. I have never had a problem where you the issue is getting things, like BB cups, that need to be tight, tight enough. When the issue is making sure you don’t get things too tight (e.g. seat post and stem clamps around carbon posts and bars) a torque wrench is useful. But even then going by feel rarely causes a problem unless you get carried away.
Likes For DOS:
Bikes: Velo Orange Piolet
Liked 2,011 Times
You can do the calculation - e.g. if the spec is 600 inch pounds, that's 50 lbs. pushing down on the end of a 12 inch wrench (or 60 lbs. on a 10 inch wrench, etc.) Then you can guestimate how that force will feel on your hand.
For screw in BB cups I put almost as much force as I can into a 10 inch BB wrench with one hand. Figure I'm putting force into the wrench around the 8 inch mark, I'm pushing/pulling 75 pounds to get 600 inch pounds torque.
Liked 2,205 Times
Tightening anything with carbon, stem on a carbon steerer, h-bar, carbon seatpost, I’d use a torque wrench.
Clark W. Griswold
Liked 4,234 Times
A torque wrench is handy. I highly recommend it. We install hitches on cars and came across one that was 186 Foot lbs of torque and the mechanic who does it said his arms were worn out getting up there and he has a Snap On Torque Wrench for the job. Sure you will probably be fine installing it without one I certainly have but sometimes making sure it is properly torqued can be quite handy. Too low and it comes loose too tight and it breaks.
Likes For veganbikes:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Liked 339 Times
I suggest getting eventually a digital torque adapter, rather than a full wrench, e.g., Performance Tool M206.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Liked 2,038 Times
I use a torque wrench on the square taper crankset because I never seem to tighten the bolts enough, and it will eventually creak
Likes For cyclist2000:
On a car, I meticulously use a torque wrench. On a bicycle not so much. I was taught early on that if all the threads are meticulously clean and lightly lubricated just hand tightening by feel of all the small bolts and nuts is just fine. However, when a bike part has a marked torque spec, like a cassette lockring and crank bolts, I use a torque wrench.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
If it weren't for Covid I'd tell you to come on over. I have one that I bought specifically to install a BB. I find it overkill for anything else though.
Likes For zacster:
I only have reservations about not using a torque tool with carbon parts. I hate doing the stem bolts on a carbon steerer. Else i dont much care. Guess its like having a pump with a gauge. Once you have it, you enjoy the convenience and wont ever go back.
I never used a torque wrench and all my friends would tell me that I was over-tightening everything. So, I used less torque and some fasteners were coming loose. I bought a torque wrench (actually two) about 15 years ago and I use them on everything. I have a chart with all the torque specs attached to my tool caddie . No guess work anymore.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Liked 788 Times
SE Wis
Liked 3,428 Times
Most every auto parts store will have a tool loan program. Put a deposit down, use tool, return and get deposit back.
https://www.autozone.com/lp/loan-a-tool
Liked 2,201 Times
Well you can always put a wrench on the currently installed bb and try to barely tighten it see what pressure you need.
John
John
Likes For 70sSanO:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Liked 173 Times
And if you were in the better borough (aka Queens), I'd tell you to come on over as well. After working on motorcycles, I prefer to use a torque wrench whenever possible. That said, I don't have a good set of torx bits yet, so I do those by feel (and of course a lot of the new stuff for carbon fiber uses them).
Likes For phughes:
Likes For phughes:
