Rust on headtube lug - evaporust?
Quoted: 838 Post(s)
Liked 1,082 Times
I’ve gotten plenty of rust off of components before but have yet to encounter it on a key structural point of a frame so I thought I’d ask. Doesn’t look bad other than aesthetically. Assuming it’s safe, should it be left as is and have nail polish put over it? Or is it worth putting some evaporust gel on? Steel wool first perhaps?
Rest of the frame is super clean so this is odd. Perhaps water stuck under the cable?
Likes For oneclick:
Quoted: 1088 Post(s)
Liked 1,205 Times
You're probably right about it being water, or more likely sweat, under the cable. I agree that it's very minor and will easy to clean up with Evaporust.
Likes For noobinsf:
Sunshine
Quoted: 10964 Post(s)
Liked 7,491 Times
before applying evaporust, sand down the edges of the rusted area to remove any loose/overhanging paint too. that will help ensure the paint that is left is well adhered to the frame and wont just chip off shortly after you touch up the area.
Likes For mstateglfr:
Stop reading my posts!
Quoted: 1443 Post(s)
Liked 1,062 Times
Evaporust now makes a "gel" for just this sort of "spot treatment" or so I read. But you could make something like a "bandage" of guaze or cotton ball soaked in your choice of rust killer and tape it in place
Oh the OP mentions "gel" I did not read carefully...new product to me and have not tired it yet.
Likes For unworthy1:
Quoted: 1950 Post(s)
Liked 2,011 Times
Is that a 80s sub 700 Trek?
Quoted: 838 Post(s)
Liked 1,082 Times
Sure is! 1987 520. The paint is insane on these. Really nice bike too. 531 frame, generous clearance, pretty long wheelbase, triple, all the braze ons, cantis. Solid components for the year too.
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
My Bikes
My Bikes
Liked 2,011 Times
I asked about it being a Trek because maybe the "key structural part" is not so key since the head tube and head "lugs" are cast as one piece and then brazed to top and down tubes. The paint on my 85 620 seems to be the thinnest and least protective at the head tube lug.
Touch up for sure.
Touch up for sure.
Likes For Classtime:
Sunshine
Liked 7,491 Times
So the head tube is one piece with the lugs and there is effectively no brazing performed on the head tube? So then the head tube is never really a tube on its own, its just part of an intricate cast? Wow- mindblown. Is the casting process/design why in the pictures here, the lugs kiss where the frame pump peg is, even though the frame size is large enough for them to not kiss?
Liked 2,011 Times
I leaned of it here Fuji Otaku: The Phoenix Project - The 1985 Trek 620 Alights but I still enjoy riding my 620. It is most noticeable in the windows of the lugs that aren't windows after all.
Bikes: Raleigh Classic 15, 84; Miyata 912, 85; Miyata Ridge Runner SE, 85; Miyata 610, 86; Miyata 100M, 86; Miyata Valley Runner, 88; Miyata Triple Cross, 89; GT Karakoram, 90; Miyata Elevation 300, 91; Marinoni Touring, 95; Long Haul Trucker, 2013
Quoted: 159 Post(s)
Liked 133 Times
I use the gel with a small brass brush. Works well.
