Homemade Tools
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
Homemade Tools
As I move through the process of building my first few frames, I'm spending much time making tools to make this easier. I'm seeking some inspiration for how others solve similar issues. I'll start with a tube butt gauge I built. I also have a few lug vices and a canti boss jig that I'll take some photos of soon.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Likes For Cynikal:
Randomhead
Liked 3,781 Times
My butt checker is a bit embarrassing, even though it works fine, I have been meaning to make a new one. I really like the Farr butt checker https://farrframeworks.com/farr-tools
Likes For ljsense:
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
Agreed, the Farr gauge is really nice like all of his tooling. I'm hoping he makes the Bringheli add-ons again. They would make my jig much more useful.
Quoted: 716 Post(s)
Liked 807 Times
I made this one for another builder, because I don't use these cable stops.
My home made heat sinks.
My butt checker. I have made several of these for other builders in the past.
Likes For dsaul:
Randomhead
Liked 3,781 Times
Nice work. How does the stop fixture mount to the head tube?
Quoted: 4233 Post(s)
Liked 3,954 Times
Cynikal- Why the third and square beam? A simple flat plate is all that's needed to hold the butt gage in a bench vice. The shorty versions are cute but I like the ability to rest the tub's length on the support beam as completely as possibly. Less chance for tube wobbling errors of the read out. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I had thought that I would braze feet on it so it would stand on it's own. Turns out I just put that part in the vice like yours. Maybe I'll cut it off and repurposed it, who knows.
Quoted: 329 Post(s)
Liked 265 Times
This is a simple jig I made for hand-mitring. You set the angle you want by lying one arm flat on the table and using a digital angle finder box. Then you tighten that nut (the bolt is welded on the other side). Then you can put your two tubes into it, holding them flat inside the bits of angle iron, and see how well they fit up. It works pretty well and is easier than trying to peer at things in the jig because you can hold it all up to the light and move it all round.
Jig for hand-mitring
Likes For guy153:
Quoted: 457 Post(s)
Liked 112 Times
Guy153
That's neat! I saved that pic!!
Likes For Tandem Tom:
Randomhead
Liked 3,781 Times
I saw a butt checker that's just a rod with a ball bearing brazed into it at the end. indicator stand sits on the bench and put the rod in a vise.
Liked 3,954 Times
Liked 3,954 Times
Another thread tangented to a tool I had photoed and I remembered this thread. So I'm resurrecting this starting with that tool.
I am slowly replacing this tool with a newer version. The two shots above are of the first version and the current second one. Both used the same plate with Vees to locate the big ends of blades/stays but these Vees were hand cut (and by their looks while I was "distracted") and didn't hold the blade/stay ends at the same height. So making sure the two blades/stays and drop outs were at the same angle was tricky. Being able to quickly remove, file a bit more and retest the blade/stay during it's slotting was quite nice. A good tooling idea not done well.
The replacement plate end will have a longer workstand jaw holding shaft, Vees that are extremely close to being the same size and the swinging tabs will be nicer. Otherwise the same basic design. In time the axle end will get re done with a slightly wider/longer axle and a bit more stand off from the beam. The beam's length adjustment will remain. I might add a thing that clamps to the beam mid way and helps to support/keep parallel the blades/stays, like some fork jigs have. Andy
AndrewRStewart
Andrew R Stewart is online now Report Post
AndrewRStewart
AndrewRStewart
AndrewRStewart
Liked 3,954 Times
To further move this thread and invite other's home made tools here's a couple of braze on bit holders.
The tinker toy version is my earlier attempt. I have 4 of them. No special machines to make these (an important element for many). There are series of bolt together holes (added after this shot) to allow adjusting the various locations of the bits. I use a hose clamp to secure these to the frame.
The sleeker version is inspired by the Sputnik ones. I made two different shaped end links that press onto the braze on bit. Vee grooved and knife edged. I have 3 of these and use either hose clamps or spring clamps. Andy
AndrewRStewart
AndrewRStewart
Liked 3,954 Times
Here's the now completed stay/blade to drop out fixture. I placed the just finished (for now, till I see how the tire/rings interface...) chainstays and they sit very well in this new fixture. Unlike the old one there's no slight offness between the two sides during set up. I suppose I could have tweaked the old one to better situate the blades/stays WRT the drop outs but making stuff is more fun.
So anyone want the old one? The beam's center sliding extender (.75"x.058" wall tube is what I use) would have to be made, I'll toss in two M5 binder barrels and you provide the rest. $25 plus shipping. The new one took about 5 hours to make and I suspect the old would want a couple of hours to get going. Andy
AndrewRStewart
AndrewRStewart
Team Beer
Bikes: Too Many
Quoted: 116 Post(s)
Liked 160 Times
I'd be interested in that. I'll PM you.
Randomhead
Liked 3,781 Times
I have a chainstay tool mocked up. I like Andy's mounting system. Have to think about that. I'm making it out of extrusion
Liked 3,954 Times
Eric- I suspect your design will be more versatile, and likely straighter then mine. All I wanted was a simple way to hold the parts while checking after hand mitering and during brazing. In hindsight now that I am trying to make a 2.5+ tire width bike I see how a fixture which can have tire mock ups attached to check for clearance is a real help. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,781 Times
I certainly have thought that better is the enemy of good enough as far as this goes. Side to side is not that important as long as it's in range. Tilt might be a problem. I'm thinking about how I can use laser cut parts to make it a little better. It seems like there lots of applications for that. Konga bikes has some dxf you can download. I suggest you look at their insta before downloading though https://kongabicycles.com/ https://www.instagram.com/kongabicycles/?hl=en
I'm thinking about how to laser cut some parts for a shift lever boss tool
Liked 3,954 Times
Guess this tool time. I made this today (my 650B MtB project is paused waiting for BB delivery) to help me do something I have been frustrated with for years. What is this for? Andy (the answer tomorrow)
AndrewRStewart
AndrewRStewart
Quoted: 329 Post(s)
Liked 265 Times
The hole and the bolt look like they're for clamping this to the table of a mill or drill press. The semi-circular notch might be for adding a clamp to stop it all spinning round. Then it looks like there's a channel and another clamp for holding the work, perhaps something that already has a 90 degree bend in it as this would explain the small round hole at the back. Maybe it's for holding narrow tubing such as for a rack while notching it? But then I would have expected that channel to have a round bottom. But this is my best guess.
Randomhead
Liked 3,781 Times
I have no clue. I'm waiting to find out. I'll hold my breath.
I should go fix my mill in the interim.
Likes For unterhausen:
Liked 3,954 Times
It's to hold a number/letter punch in place WRT the BB shell. I've struck so many times with the letters being off angle, uneven heights and spacing. I have plans for another that clamps to the steerer. Andy
AndrewRStewart
AndrewRStewart
