What is this piece on front skewer?
only here for the "LIKES"
Quoted: 1647 Post(s)
Liked 2,261 Times
thanks
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Is it a Sansin Hub?
Edit: it looks like that tab would lock into the bottom of the dropout. For what reason I can't imagine. Other than to keep it from spinning so that other hole can do its job. Whatever that may be.
Edit2: That other hole could function as a second eyelet. Is it threaded?
Quoted: 1088 Post(s)
Liked 1,207 Times
Sansin thingy on a Shimano hub and Shimano skewer? Yeah, I would just get rid of it. I have two sets of RX100 hubs, and both have the typical conical springs on their skewers.
As for function -- maybe to hold something for a bike computer or mechanical speedo? None of the Sunshine/Sansin hubs on Velobase have anything like that piece.
Liked 1,207 Times
I think it's for a speedo. This pic from an Amazon analog speedo listing has a similar piece that goes to the hub.
SE Wis
Quoted: 2755 Post(s)
Liked 3,427 Times
I'd surmise it's some sort of lawyer lip type device for wheel retention when loose
Likes For dedhed:
Quoted: 1654 Post(s)
Liked 857 Times
If it's marked left, then there could have been a right side version..... which makes me think that it could work like a fender stay mounting eye, if your dropouts do not have them. It might work the same for the back wheel too.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Polymultiplié
Bikes: Yes, please.
Quoted: 2222 Post(s)
Liked 4,825 Times
I've no idea what it is, but I already like it.
Likes For non-fixie:
It looks to me like some sort of lawyer lip variation.
Likes For Salamandrine:
Likes For fietsbob:
lawyer lip for idiots that didn’t understand how a skewer worked. Alot of that stupidity in the 80’s...
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Liked 857 Times
If it's a lawyer lip thingamajig, what does it attach to on the fork to retain the wheel??
Schwinn had bosses on their fork ends to interface with layer lip clips but if the wheel came originally with the bike pictured, we do not see any means of retention on it.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 2368 Post(s)
Liked 1,761 Times
What brand of bike?
Polymultiplié
Bikes: Yes, please.
Liked 4,825 Times
I'm thinking the seller knew the buyer, found this among his lawnmower tools and thought "let's see how long this will keep 'em busy".
Quoted: 2622 Post(s)
Liked 3,163 Times
Don't know whether this patent applies; there's no drawing of the item.
Quoted: 4274 Post(s)
Liked 2,995 Times
Does it keep the axle positioned in a horizontal dropout in which there is not a positioning screw?
Ride, Wrench, Swap, Race
Quoted: 1568 Post(s)
Liked 1,308 Times
Only needed on one side, since the wheel would need to tilt further than the fork legs would allow in order for the other end of the axle to move out of it's dropout.
Amazingly simple, but can't the thing be inadvertently defeated by being in the wrong rotational position as the QR lever is flipped?
I suppose if the adjusting nut were Loctited to the shaft that the operator wouldn't be able to flip the lever if the device were in the wrong orientation.
But if the nut is backed off then the QR could be flipped with the device in it's "release" position AND with the lever tension perhaps set too loose.
The problem with this device is that it would require the operator to know how to use it, which makes it somewhat redundant to the QR lever.
It would work as intended though if the only setup problem were incorrect tensioning of the QR nut (or if the operator used the QR handle as a wing-nut). That's the only benefit that it offers, sparing the operator from having to determine quantitatively just how tight that the QR lever tension should be set, and not having to turn the "wing nut" (qr lever) tighter than is comfortable on the hand (if used improperly).
The idea of adding complexity to the setup of something that the operator is already doing wrong is almost humorous. But hey, it might work, right?
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 440 Post(s)
Liked 3,581 Times
They leave their calling card like Zorro left his.
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
SE Wis
Liked 3,427 Times
I kind of look around a little for SANSIN patents related to this but didn't find anything exactly like it.
Liked 1,761 Times
What does it have to do with Sansin. Isn't the hub brand coincidental? "Lawyer" hub retension (it should actually be retention, but I digress....) is specific to the brand of bicycle. That question still hasn't been answered. It's clear there are no hub retention "lips" on the fork, and that's the reason for this device. Has nothing to do with the brand of hub.
Liked 1,761 Times
Two counts of oops, did not see the branding in photo 1. And I swear "retention" was misspelled the first time I saw it.
That is odd, that it's specific to the hub. The only other retentions I've seen similar to this are the familiar Schwinn "clips", and a spring-loaded release clip that bolts onto the fender eyelet on a couple Univegas. The common thread is the lack of "lips" on the dropouts.
