WTB Raddler and tubes
Hi all, I've a Cannondale Topstone Sora which is awesome. It isn't tubeless. For absurd aesthetic reasons (like using a tan walled tyre), could I put on TCS ready tyres (like WTB Radler 40's) on the non-tubeless trims and then run it with tubes? i.e same set up just with TCS ready tyres.
Ta
Ta
Liked 2,207 Times
Ta
Ta
I would recommend Gravel Kings as an alternative. If you peruse the Cannondale Topstone FaceBook group, a lot of folks complain about the WTB Riddlers being very vulnerable to flats from thorns, etc.... The Gravel Kings are highly recommended as an alternative. The 43mm will fit.
https://www.biketiresdirect.com/prod...e?fltr=&sg=500
Yes, you can run tubeless tires on a regular rim with a tube.
Another alternative would be the Teravail Rutlands. I run the 700 x 47mm versions but they do come in a 38/42 mm also.
Liked 2,207 Times
I think OP was asking about the Raddlers, not the Riddlers. I say that bc the Raddlers have taller knobs closer to the Gravelking SKs. (WTB, why did you name your tires like this?!).
Apologies to the OP, but I do see a lot of folks recommend the Gravel Kings.
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Liked 313 Times
I just had a similar dilemma - I have a Cross Check that I intend to keep tubed (my Rove is tubeless and it's great, but I don't feel the need to go there on the 'Check for various reasons). My concern was that I kept getting the impression that many tubeless-ready tires would be hard to mount on my non-tubeless rims because of how tight they fit (or at least hard enough to mount that fixing a flat on the trail could be a real drag). So I ended up ordering Nano Comps - the tubed variety. Hopefully it won't be a struggle . . .
In my experience, I have had zero issues mounting tubeless-ready tires to non-tubeless ready rims. The way most non-tubeless rims are designed generally make mounting any tire straightforward if you're using the correct sized inner tubes (sizing down slightly on the inner tube will make mounting easier).
