‘74 Raleigh headset servicing
Hello all,
I noticed when riding the other day that my headset on my ‘74 Raleigh Gran Sport was shifting and giving me a single noticeable ‘click’ when using the front brake. I checked for play with the bike stationary and the front brake applied and, indeed, there was some noticeable play at the top of the headset only.
i disassembled the cockpit, got ball bearings all over the floor (collected them... 22 on top and 22 on the bottom? Will have to check) and noticed that the upper race wasn’t properly seated in the frame and came out with the adjustable race. Now, I haven’t taken it to a shop yet because I’m dreading wait times, so I’ve come here for advice. Is there a way to press-fit the upper race into the frame with some home-spun tools? When I insert the upper race into the head tube and exert downward pressure on it I notice a bit of play - is this normal and will go away once it is press fitted? It looks like it is in pretty good condition, so I would be surprised if it is worn - is this ever a problem with older headsets/head tubes?
I can supply pictures if necessary.
I really love this bike and already just went through a whole ordeal with the bb, so I’m hoping to just get this solved quickly so that I can hop back on it!
Thanks in advance for the help.
Señor Member
Quoted: 1519 Post(s)
Liked 1,142 Times
A picture would help. I've not heard of headsets just coming out on their own - which would indicate a serious problem. If the last person to own the bike just never got it properly seated, it is possible to press it in using a threaded rod, nuts and washers. Once in, there should be no movement at all.
22 bearings top and bottom sounds right.
Upon closer inspection it looks like the top race, when sitting on the head tube and a little loose, can’t actually move any further down into the headtube. Could it be too small? There is equal play in seemingly all directions. Maybe of about a 1/2 mm.
Señor Member
Liked 1,142 Times
Have it measured. Races come in 26.4 and 27.0. I have to wonder if someone needed a 26.4 and only had a 27.0. It might be a very simple fix.
i guess ill have to take it to a shop after all... would most shops sell an upper race independently or does this look like I’ll have to get a new headset?
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Word of caution (and you might want to remind the shop, depending on how many English-built Raleighs from the 70's they service), your fork's steerer tube may be threaded with Raleigh's proprietary 26tpi threading. The only part you'll need to reuse is the locknut, the rest of the headset is interference fit in standardized diameters.
Quoted: 3882 Post(s)
Liked 3,502 Times
happily, the 1970's era Gran Sport came with a 24TPI steerer and HS.
HS is a product called the Aletet (also spelt Alatet) from Brampton of Birmingham, England.
ball size is 5/32"; a full complement is 26 balls per race.
the outside diameter of the pressed-in head cups is 30.0mm.
the inside diameter for the fork crown race is 26.9mm, intended for a seat of 27.0mm diameter
steps -
the first thing i would do would be to mill, or have milled, the ends of the head tube and the fork crown to make sure everything is square.
if the head cups are slightly loose in the head tube that is the fault of Raleigh and can be remedied by shimming. aluminum beverage can material is adequate, brass is better. when shimming one must take care that the shim material does not get between the race and its seat. shim material must all be in vertical plane.
when reassembling use all new grade 25 balls.
steps -
Likes For juvela:
Señor Member
Liked 1,142 Times
Let the shop figure out if it's the head tube or the top race that's out of spec. Generally, the headset is sold as a complete kit, so crown race up through the locknut at the top. You might be able to source an upper race from a bike co op, but that doesn't address why your upper race has lost its fit in the head tube.
Rather doubtful that this has 26 tpi threading. This model would have been made in Worksop - which was using 24 tpi threading.
The dropped
Liked 1,014 Times
Agree with the first part - though I suspect someone put on a headset with a 27.0 crown race and put the imperfect fitting race on rather than bothering to get a properly fitting 26.4.
Conceded that the steerer threading is likely 24tpi standard. It's messy in the early 70's for Raleighs.
steps -
steps -
Just to confirm that i understand - Raleigh likely made the head tube slightly too wide? And i have to shim the upper race to the head tube to ensure a snug press fit?
As far as fork crown and race go, they fit snugly and are in excellent condition. The play was only coming from the upper race against the head tube.
Thanks for the info regarding ball bearings. So grateful for the BF vault of knowledge.
Liked 3,502 Times
regarding the fit of the two head tube races -
the manufacturer would have likely employed the same tool to ream and face both ends of the head tube
of course, if both ends were done simultaneously the cutters would have been different for the top and for the bottom
it may be that one was "loose on its moorings" and made an oversize ream...
This doesn't look like a crown race, but more like the pressed race into the head tube. I'm not sure how a too large crown race at the bottom of assembly contributes to a poor fit at the top of the head tube. Am I seeing things wrong?
Quoted: 7410 Post(s)
Liked 2,609 Times
Do we understand the problem? If I'm following correctly, the race that presses into the TOP of the head tube is too loose, but others seem to be addressing something else.
If I am right about the problem, the cause could be that the inside diameter of the head tube somehow got too large. I don't know of a proper fix for that, but there are some improper fixes that might be good enough such as using a piece of a soda can as a shim.
Disraeli Gears
Can one knurl an inside diameter (or make a reasonable facsimile thereof using a hammer and punch with care and alacrity)? I know that this is sometimes done with the outside of the fork crown interference fit area on the base of the steerer tube when people find that race is loose -- I have one of those that just came right off the fork, from Hilary Stone no less.
Going to try a soda can shim tomorrow and will report back.
Blamester
If soda can is too thick I have the cups on my bike shimmed with tinfoil and plenty of rough miles with no problems.
Likes For blamester:
Quoted: 732 Post(s)
Liked 696 Times
If you use a shim, it would need to be thin enough so that the entire circumfrence is shimmed, or at least equally spaced so the race remains centered in the head-tube.
The dropped
Liked 1,014 Times
Liked 2,609 Times
I don't think that would work. I think you have to drape the foil over the head tube's top in two to four strips and then insert the race.
Quoted: 732 Post(s)
Liked 696 Times
Disraeli Gears
Tinfoil sounds unsettlingly dubious to me. A shim needs to be thick enough that the material reliably won't bunch up or tear, and should provide more or less constant contact, if possible, all the way around the opening. IMO anyway -- but YMMV.
Quoted: 732 Post(s)
Liked 696 Times
Liked 2,609 Times
But the tiniest bit of soda can might be adequate and easier to use. I was impressed the first time I cut one up. Scissors go through the material as if it's paper.
It's not a Raleigh 26 tpi headset, so that's good. Raleighs of the 70s are said to have been fitted with headsets with 30.0mm cups. Before shimming the cup, I'd get an accurate as possible measurement of the cup mating surface and see if it's less than 30.2 mm. If it is, and if the headtube is not out of round or larger than 30.2, I'd buy a modern iso headset and install that sucker. Although the Raleigh headtubes that I've measured have been about 30.0 mm, ISO headsets, like modern Tange Levin, press right in with the interference fit. If you do decide to replace the headset, pop the crown race off the fork and measure the fork surface that will hold the crown race. Lots of Raleighs had 27.0 mm while most would have been 26.4 mm. Headsets like the Tange Levin are available with either 26.4 mm or 27.0 mm crown race dimension. Cups are 30.2 mm (though there is a JIS version with 30.2 mm) with either crown race.
Personally, I heart the Tange Levin headsets. They are cheap but well made, look good on vintage steel, and have a short stack height so it's unlikely to find a fork/headtube that it won't work on. Just add some spacers to make everything happy.
Likes For desconhecido:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4719 Post(s)
Liked 5,981 Times
jpjpjp
Where do you live? One of the great benefits of this forum is that you may be very close to someone with lots of experience in the very problem you're trying to solve. If you were within driving distance of Portland, Oregon, for example, I'd be happy to take a look at your frame.
