Ultegra is more Dura Ace, less 105, or vice versa?
Liked 353 Times
love my old 9 speed dura ace work amazingly my question is does ultegra minic dura ace more than it does 105
my newish 10 speed 105 is not even close to the quality and smooth nessie of my 9 speed dura ace. looking to get new groupo.
I understand what you are asking. Obviously Ultegra is closer to 105 than DA in terms of price. However, I think it may be closer to DA if you are considering finish and functionality. As an example, a couple of generations ago 105 brakes used that not-quite-Phillips (JIS?) screw to adjust the side to side balance. Ultegra and DA used the much nicer Allen screw. Maybe someone can give more current examples. Anyway, I think this is the reason most folks consider Ultegra the best value in the lineup. It really makes it hard to justify the big price leap to DA and I suspect Shimano likes it that way. Keeps DA more exclusive.
Likes For shelbyfv:
Mother Nature's Son
Liked 1,569 Times
I sure do not have a definitive answer to the question. I can say that I purchased a 105 7000 groupset and have it on a Soma Smoothie I built about 6 weeks ago. The 7000 groupset is outstanding. Set up was fairly easy with help from a couple of youtube videos. The gear shifting is clean and precise and the braking, rim brakes, is really good. I usually use KoolStop salmon pads but am keeping the 105 pads for now. I read a couple of reviews on the 7000 groupset and they sold me on the purchase. I have compact 50/34 crankset, mid length derailleur and 11-32 cassette. I have an 11-28 cassette on order.
I was leaning towards the Tiagra 4700 groupset but do not like the lack of compatibility with other groups. I estimate I have around 800 miles on the 7000 groupset now. Definitely glad I went with the 105 7000. I have older Ultegra and 105 groupsets and really the only one I do not care for is the 5700 10 speed. I have read posts by others that have the 6700 and it seems to be disliked by the majority of users. The shifting has never been good and needs adjusting quite often. The 105 5600 and the Ultegra 6600 have both been good performers, with the Ultegra definitely a step up. I also have the 6500 group on a couple of bikes and it works very well. Never had the 105 5500
The reviews I read on the 7000 groupset all said that this version of 105 really narrowed the performance gap between the Ultegra and 105. The main difference is in the weight savings for the Ultegra. The aesthetics were mentioned, giving the Ultegra a slightly sleeker look, whatever that means.
Liked 353 Times
ultegra is nice very nice but is 105 too close to bother.
mini groupo on line is super affordable.
Liked 5,414 Times
Shifting wise? Weight wise? Some other quality? Depends on what you want to compare.
Shifting wise I think that Shimano 105 5800 shifts as good or almost as good as Ultegra 6800. When those two groups were new back in 2017 I think along with DuraAce whatever number 7800 or 7900 the two or three articles I read stated the same. 105 shifts just as good as Ultegra. However they also said that DuraAce shifted better than both. While the articles I'm talking about are three or more years old and the Shimano's introduced some newer versions, I still imagine that the same holds true today.
Weight wise, Ultegra makes a pretty good difference over 105. I think I added up about a 1 pound difference for the entire groupset, but I might be confusing some other things so don't hold me to the exact number. But go pick up a DR of each or a cassette of each and you'll notice it just holding them.
Didn't look at DuraAce, but likely lighter still.
If you are comparing older groups than 5800 and 6800, then yes there is a difference. When they came out with 5800 is when the reviews changed their tune on 105's shifting being comparable to 6800
We’re talking 9 speed and 10 speed, right?
Closest you will find to DA feel in 10 speed is Ultegra. Hands down. Solid stuff, lasts forever, sublime shifting.
105 10 speed had a number of issues, mostly mid-cassette shifting quality, while Ultegra avoided those issues. Not to say 105 ten speed is trash, jist not as good as Ultegra or DA.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Liked 2,038 Times
Likes For cyclist2000:
Each time you go up a level you get more alloy, more bearings, better tolerances.
Shifters I've used in the past few years in order of preference. 6600>8000>5800>6700>7900. Never fortunate enough to use 7800. I understand that was the best ever.
Likes For shelbyfv:
Bikes: two blacks, a blue and a white.
Liked 860 Times
I always hear that technical and engineering upgrades start at Dura-Ace, then 'trickle-down' to Ultegra, which then trickles to 105, which then trickles to... yadayada. Pretty safe bet it almost never goes the other way. SO, wouldn't it follow that, at any given time, Ultegra has likely inherited some feature that hasn't made it to 105 yet? Ultegra would always "be ahead" on the migration scale. If you're looking at the two, made in the same year, I'd therefore think that Ultegra's got some form of a Dura-Ace feature that has not yet "flowed down" to 105 yet. What makes that "nearer to Dura-Ace" always uncertain is that we can't typically measure the marginal utility of each evolutionary feature (which can even be negative). That said, I have versions of all three of those groupsets in the garage, and I do personally see Ultegra as "the sweet spot" - I'd chose to pay up for Ultegra over 105, but I would not pay up for Dura-Ace over Ultegra. Personal preferences. (And the Campy SuperRecord looks better than all of them!)
Likes For blacknbluebikes:
Liked 3,492 Times
Historically 105 have been considered by most the sweetspot/best value for cost/performance I personally would not go lower than that on the shimano chain. I have 105 5800 (gen before 7000) and it has been great. of course about 2 weeks after I installed that i could have gotten ultegra 8000 for a similar prices
that said Ultegra is my favorite, has always worked great and is to me a noticeable step up from 105
Life is too short not to ride the best bike you have, as much as you can.
I have a 9 speed DA triple bike and a newer 10 speed 105 compact crank bike, with no brand name brake calipers. The DA brakes stop better. The 105 shifts with less force and the detent is still noticeable. I like the 105 10 speed better in warm weather. I ride in the winter with heavy gloves or thick goose down mittens. I can shift both in the cold. The added force and the bigger noise and feeling in the hands of the DA group is easier to get a perfect shift with gloves or mittens. I just shift carefully. No racing for me, just long rides. I've had the mittens about 50 years. They work on a motor cycle, but not as well.
you want opinions I guess.. & this place has many opinions...
I sense the lower cost parts , the engineering is in the machinery to produce adequate functioning components in the millions for cheap..
with no hand labor..
Likes For fietsbob:
Liked 353 Times
jonny I was hoping for a dialogue not an uneducated opinion.
but thanks.
there is a functional difference between a pivot pin with an oil bushing around it, and a hole..
Tight tolerance vs Loose
I ride a Rohloff hub bike now , the Derailleur one hangs on a peg
Campag Euclid, Rally Mavic 851 My Shimano is an older LX deore..
I worked in bike shops
Watching the one more speeds makes 1 bike better than another
is just a spectator sport now.
Likes For shelbyfv:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Liked 176 Times
And by your standard of "educated," you should be ignoring anyone that isn't a Shimano engineer that worked on these specific components, no?
Who is widely ignored? Hammer or Fiets?
Likes For shelbyfv:
Liked 353 Times
Are you saying he should say he doesn't know his own opinion? I'm pretty sure he does, and it seems like that is what you are seeking.
kinda different but I fear over your head.
why play hate games yo. ride the bike share be kind
