The Double Flat Blues
The other day I was cruising along minding my own business when, suddenly: BUMP-BUMP-hiss-hiss. I have no idea how I didn't see the rock sitting right in the middle of the shoulder, or how I managed to nail it so perfectly with both wheels, but RIP both my tubes. With only one spare, I had to call the ol' ball and chain for a first-ever rescue mission. Booo, stupid rock.
I know that some riders carry multiple spares and multiple CO2 cartridges, but I've always dismissed that as overkill. Sure maaaaybe some day I would experience two flats in one ride, but the odds seemed low enough to not justify schlepping the extra gear. And while I take the occasional 80 mile ride that gets me out into pretty rural areas, my rides never put me in a situation where I would be in actual danger if I got stranded.
Obviously, my recent fall from grace has me re-questioning the cost/benefit of being prepared for multiple flats on a ride. So my question to experienced road cyclists is this: was this a freak occurrence, and can I dismiss it as such? Or do those of you who ride several thousand miles a year on tubed tires all prepare for this as an eventuality? Is this the sort of event that drives a man to a tubeless setup? My new wheels are tubeless ready but I've generally been happy with my tubed lifestyle up to now. Any thoughts/advice appreciated, thanks.
Likes For sanmateoclimber:
Liked 10,155 Times
I carry a patch kit and a mini pump along with a spare tube and 2 co2 cartridges. Sometimes I will bring a second tube but the patch kit gives me security.
Liked 9,462 Times
I always carried a tube and a patch kit, just in case. Particularly on longer rides, it gives a little more peace of mind.
If you're generally happy with tubes, don't worry about tubeless, 'specially due to a freak incident. Go to tubeless if you get relatively small punctures (<1/4") pretty regularly and you're tired of changing tubes on the side of the road.
Likes For WhyFi:
Liked 4,331 Times
Two tubes, patch kit and frame pump. always. In my sewup days, good spare, patch kit and frame pump. (Zephal HPs then, HPXs now.)
I've never owned or used either a mini pump or CO2. I have had rides where I've used most of my resources. (Both tubes and several patches one ride. Granted, that was because both my brand new latex tubes blew out at the valve/tube juncture; something I have never seen before or since. (And no, not from the valve being manhandled with a pump. The tube was glues to a short piece of heavier tube with the valve. That glue joint failed in a slow blowout. Both tubes 10 miles into a 100 mile ride and a mile apart. Got another (or two, I forget) routine flat. Stopped 15 miles from home at a Fred Meyer (the store that carries everything) and bought a miserable tube and patchkit - just because. It worked, No more flats.
A thousand years ago, I rode from Boston to Fitchberg to watch the Longsjo Classic and the country's best racers. Got my second flat on the way home and patched the sewup on the side of the road 30 miles from home.
Now those are my most notable success stories re: flats - over 200,000 miles of riding. I look at it as good ol' Murphy's Law. That being prepared goes a long ways to stuff NOT happening. But even so, sooner or later, it does.
Oh, and frame pumps! What a blessing! They allow you to be tired, spacey, clumsy and on and on. Screw up and pinch the tube?. Have a really bad day with thorns? Patch it and try again, You can do this until you run out of patches. (Did you bring that much CO2? Are you willing to pump up that many times with a mini pump? And being able to stop and top off pressure just because. Get to gravel? drop the pressure, Back on pavement, Pump it back up. Racing a slow leak home? Want 110 psi, not 105? No problem. (In my racing days, I lent my frame pump to a skinny engineer/ post 40 yo time trial rider to pump his race tires to 120 psi. He had no trouble doing it. That pump and the others on my other bikes were the only pumps I owned when I raced. No floor pump, no compressor, no CO2. All my tires were sewups. Race tires had latex tubes and needed to be pumped from near scratch every time.
The manufacturers of carbon fiber bikes have done their best to obsolete frame pumps but as long as pneumatic tires of most of 100 psi are critical, good frame pumps will always be a blessing for those wiling to carry them. (And with all the freedom CF gives in design, why doesn't someone make a CF frame with sexy, near integral TT frame pump stowage? They've done everything else - except get around this issue of needing high pressure air.)
Ben (off on one of his favorite rants)
smelling the roses
Liked 901 Times
I used to always carry two tubes and a patch kit. Now, in the age of cellphones, and shorter rides, one tube and a patch kit, and rarely use either one out on the roads I now ride. Just last week I had to make the call of shame for a disintegrated rd. You can't plan for everything
Of course a frame pump is a given
Liked 9,462 Times
Likes For WhyFi:
Klaatu..Verata..Necktie?
Liked 13,199 Times
In tthe pre-cell phone days, I started out carrying a tube, some glueless patches, levers, and a frame pump. That worked till the day my spare blew on the way home. Then I started carrying TWO tubes, which worked till I got a bad enough hole in the tire that I blew both spares, notwithstanding my improvised Clif Bar wrapper boot, and had to walk a mile in cleats.
Then I got a bike that wouldn't take a frame pump. SO I tried CO2. But my luck with tires had improved so much that even though I'd practiced the whole scenario at home, by the time I needed it on the road, I must have forgotten how to do it because I blew two cartridges of CO2 just inserting them in the inflator. And had to walk a mile in cleats back to the car.
So, now I carry a tube, levers, a minipump (or frame pump on my steel bikes), and a cell phone.
Liked 1,429 Times
I've had that double flat experience. Hit a pot hole at speed. Fortunately I was carrying a tube and was with my GF and others so there were more tubes available. Patching tubes on the road is a crap shoot,although I have done it. Since going tubeless...no flats...no worries. I'm also faster and spinning more easily and at age 74 that's a gift.
Likes For bruce19:
Tubes are still a thing ?
Likes For RedBullFiXX:
Advocatus Diaboli
Liked 1,611 Times
There's really never a reason to not bring 2-3 glueless patches.. they're about the size of a bandaid. You only need it to last til you get home. An extra CO2 is pretty small as well.
Liked 4,331 Times
"The Double Flat Blues". A favorite of harmonica players.
Should Be More Popular
Liked 9,565 Times
Your decision.
I carry a spare tube and C02 for single flats, but also have a mini-pump and quick peel/stick patches in case of super bad luck.
Whether or not to go tubeless is way too complicated and controversial to answer easily. (hint, the answer is on the board)
Likes For datlas:
Arizona Dessert
Liked 2,169 Times
Double flats are not that common but failure to properly diagnose and/or repair a flat can be resulting in the need for 2nd repair immediately. Like most others I bring both tubes and a patch kit.
(If you get an obvious location of a simple puncture (say a thorn stuck on outside of tire) it can often be quicker to keep wheel on bike, pull out the affected section of tube, patch it, make sure thorn is fully gone, stuff it back, inflate and go than a full tube replacement. I learned this from my fixie days when I didn't like to remove my rear wheel.)
Likes For noisebeam:
This is obviously a sensible compromise. I had one bad experience with a cheap patch and kind of wrote them off, but they are an easy way to safeguard against a calamity like this without having to carry a boatload of extra tubes. Thanks folks.
Liked 9,565 Times
Liked 4,331 Times
I have a theory that in general carbon bikes are less comfortable on rougher surfaces than steel or ti, hence the love of softer, wider tires. (And it isn't just me with this theory. At Cycle Oregon, it's a running joke among the ti and steel riders that we have to be ready to hit the brakes anytime we hit chip seal because all the carbon bikes around us slow down.) I suspect modern, deep rims add to this.
Ben
Wow... precisely my strategy. One of the flats will be fixable with a patch kit. For the other I have a tube.Two Co2 cartridges against off chance of two flats. Feels covered to me. This should be a rare occasion. Perhaps not quite freakish, but close.
Liked 9,462 Times
Likes For WhyFi:
I have run over a rock and double flatted at one time. That was the only time I've had two flats simultaneously. This was during my lazy period when I wasn't checking my tire pressure like I should. I was only 5 minutes walk from home, so no big deal.
I do carry two tubes, patches and a frame pump. I have had multiple flats on one ride. Recently, I was in the middle of nowhere with no cell coverage. For the foreseeable future I will continue carrying my flat repair kit.
just another gosling
Liked 2,097 Times
2 tubes, patch kit, boot kit, spare tire, Road Morph G pump. Each one of those items is there to solve a problem I had. Haven't had a problem since, but there's always tomorrow..
Results matter
Results matter
Liked 4,331 Times
Another reason for higher than the now popular tire pressures - resistance to pinch flats. I do not know the details of the OP's flats but they sound like pinch flats. The hiss, the lack of blowout from slashed tire. Granted, tubeless is a good way to avoid pinch flats. Tubulars also reduce the likelihood a lot.
OP, would you like to tell us what tire size and pressure you were running? Your weight too if that's not too much to ask. (My 100 psi is with 24c ties and 155 pounds.)
Ben
Ben
Liked 4,331 Times
I live in goat head country so I always carry two tubes. Once, on a group ride with maybe 10 riders, we crossed a bridge where someone had dumped a box or two of tacks on the road. We all had several tacks in each tire. It must have looked funny to see a whole group with their bikes disassembled on the side of the road. It wasn't funny at the time. Somehow we had enough tubes to go around and we all made it home.
