Saddle adjustment
Saddle adjustment
I've read that pain on one side of your sit bones and not the other, can mean one leg is shorter than the other. The article said to adjust your saddle either towards the side with the pain or away from it. I can't recall which. Anyone know which is correct or if that even works?
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Liked 166 Times
In general, you would move the saddle away from the side with the pain (the way the question is worded is a bit confusing). If you have sit bone pain (and you have gotten over the "general" saddle soreness that comes with getting used to being on the bike), I would lower the saddle slightly (like 1/8"/3mm) and see if things improve. Leg length discrepancies are fairly common, some use shims under their cleats to make up the difference (which is an alternative to changing an otherwise OK saddle height).
Do you notice your hips rocking from side to side when seated climbing? This is another sign (to me at least) to lower the saddle a bit.
Likes For Oso Polar:
all the adjustments are up/down and back & forth on the saddle rails..
+ a little tilt varying from level
Personally I'm not a fan of down tilting the saddle.
my hips should not slip down off the saddle IMHO.
Liked 735 Times
Probably just need to make a (or some) saddle adjustments. I'm sure I have one leg shorter, was on crutches for 9 months after fracturing a hip when I was still in high school. I recently, after riding the same saddle on my road bike for a year, felt the saddle wasn't feeling just right. Adjusted the tilt (upward) a couple of times and feels like a totally different saddle, in a good way. Other than getting a year older, nothing else changed, but the change in saddle adjustment sure helped! Don't know if moving it off center left or right would help, didn't try that. Try a few adjustments, they can easily be reversed if they don't work.
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Liked 355 Times
I had a high tibial osteomoty on my left knee years ago, and as a result, it seems to help with comfort and keeping saddle sores at bay when i rotate saddle the nose slightly clockwise. My bars always feel best slightly cocked as well.
You may want to read this: https://www.stevehoggbikefitting.com...ard-can-it-be/
And this: https://www.stevehoggbikefitting.com...d-can-it-be-2/
I adjusted my saddle down a bit and did 23 miles this morning. Definitely better than before. Interestingly I was faster and did better on the climbs. Is this the saddle adjustment or the fact I've been off the bike for 3 days? It was very humid and after awhile I was soaked through and this created some issues when the chamois bunched up. Probably should have worn my bibs but wanted to try the adjustment with shorts. Thanks for all the help, I'll continue to try small adjustments until I get it dialed in.
Actually, this means that you simply need a saddle of a different shape - the one with "sharper" transition to the wide part (saddle looking more like a T than a triangle). I have the same issue with some saddles. For example, with Cobb Randee saddle this is a huge issue for me but not an issue at all with Cobb San Remo.
