how to wash cycling clothing
how to wash spandex.lycra
jersey. Shorts
what are best ways to prolong life of clothing
jersey. Shorts
Dont fix whats not broken
Bikes: Steelman Stage Race, Dura-Ace 9s
Quoted: 95 Post(s)
Liked 166 Times
I just follow the care labels that are in all garments. Usually this is machine wash and drip dry. I've got jerseys that are well over 15 years old (and a couple pairs of shorts) that are still going strong.
There's also a point of view (that I agree with) that washing soon after riding prolongs the life of cycling clothing more than anything. Letting the clothes sit in a pile soaked with sweat is not good for them.
Likes For mprince:
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Gentle cycle and hang after
Likes For GlennR:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
In the U.S. folks began using washing machines in the early 20th century. By mid century, most folks were using them. That, a cool water wash cycle, laundry detergent and line drying is about all that's needed.
Now, up in the Great White North, who knows...
Likes For nomadmax:
Quoted: 7089 Post(s)
Liked 11,207 Times
Zip up all zippers. If left unzipped, the teeth will abrade fabrics.
Optional: place everything in lingerie bags, and don't overstuff them. This will reduce mechanical abrasion in the washing machine.
Use gentle detergent (Woolite is not gentle; use Dreft or other detergent designed for baby clothes).
Gentle cycle, or Handwash cycle if your machine has it.
Use the Extra Rinse option if your machine has it. Lycra doesn't like having detergent left in it.
Optional: dry on lowest heat setting for 15 mins to take out some moisture; skip this step if you are being super-cautious.
Hang to dry; make sure shorts are inside-out or they will take 2x as long.
Note: NEVER put anything with velcro in with your cycling clothes; velcro sticks to lycra and will cosmetically damage it. In other words, wash cycling gloves separately, by hand, in a sink.
Likes For Koyote:
My favorite neon yellow jersey had a dirt spray up the center back that would not come off, despite pre-treatment scrubbing w/ liquid detergent.
The solution that worked was to use bar soap and tap water to scrub off the stains, followed by a normal cold water washing machine wash.
Looks new again.
Looks new again.
Likes For wingless:
Liked 11,207 Times
Looks new again.
Looks new again.
The only two detergents that get my gym clothes clean and really free of odor are HEX, which is a sport detergent for synthetics, and Seventh Generation which you can buy at Target. The later is really good and giant bottle is cheap, ironically because it is a plant-based detergent. Not letting them sit around dirty is important too. At lease rinse them in water and hang up.
Quoted: 1853 Post(s)
Liked 680 Times
I zip the zippers on my jerseys and put my really nice skinsuits into bags for washing them. But otherwise, most of our cycling clothes go in with the regular wash - cold water and normal cycle. I do hang dry them though.
Also, use less detergent than you think you will need, double rinse, and add some vinegar to the wash.
Laundry detergent tends to cling to synthetic fabrics more than natural ones. This leads to perma-stench. Using less detergent, double rinsing and vinegar help release the detergent from the fabric so your clean cycling clothes don't develop a permanent smell.
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 393 Post(s)
Liked 325 Times
Likes For PoorInRichfield:
Quoted: 663 Post(s)
Liked 496 Times
I hand wash everything immediately after use. While still damp with perspiration, just a minute or two of washing does the job.
Likes For berner:
Quoted: 3352 Post(s)
Liked 1,056 Times
I have a magic drawer that clean cycling clothes magically appear. After a ride I throw them in a hamper, and like magic they reappear in my magic drawer.
Likes For rydabent:
Quoted: 4227 Post(s)
Liked 2,489 Times
Is this a serious question ??
Likes For wolfchild:
Quoted: 18529 Post(s)
Liked 15,890 Times
When touring, if there is a shower I will wash them while I wash myself, which is usually within an hour of arriving at camp. Need to get them hanging to dry as soon as possible.
Likes For indyfabz:
Hand washing with mild detergent, and then hang them to dry. Machine washing and drying is tough on clothes, and is the primary cause of wear and fading. Get enough jerseys and shorts that you can give each set time to dry before using them again. A good mild detergent is a decent quality shampoo. Dandruff shampoo works well to kill fungus in shorts. I was a medic in the Army, where so-called "crotch rot" was an issue with Infantrymen spending lots of time in the field with high heat and humidity, and few showers (and not fun, at least for me, to diagnose). Dandruff shampoo (like Head and Shoulders) was the best non-prescription cure.
Likes For u235:
Likes For NoWhammies:
Liked 3,090 Times
New every time
-Oh Hey!
-Oh Hey!
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
I normally only do one load of laundry per week. When I didn't have a weeks worth of cycling shorts and jerseys I washed them while taking a shower after my ride and hung them to dry. I don't bother with cycling specific clothes anymore. I only wear poly compression under shorts and mostly wear fast drying fishing shirts, so the laundry gets done when it needs done in the washing machine.
Bikes: Cervelo Prodigy
Quoted: 479 Post(s)
Liked 88 Times
Ditto. I wash my cycling clothing immediately after cycling.
If it's only your cycling clothing and probably a few other pieces of clothing in your clothes bin, it's definitely a waste of energy to throw them in the washer. In this case, hand-wash your cycling clothing. They're only few pieces after all, would only take 5 mins tops of your time to handwash.
Getting perspiration off the clothing immediately and a rinse in cold water is what I think will allow the material, especially the foam padding to last a bit longer.
Likes For Garfield Cat:
Quoted: 1814 Post(s)
Liked 923 Times
I'm trying to think of any cycling clothing aside from gloves that I have actually worn out.
In general, the stuff lasts like crazy with gentle machine washing and drying.
Likes For woodcraft:
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 849 Times
I think some of my oldest lycra is more than 6yrs, and those are still doing fine. I avoid the lower-priced stuff, maybe that helps.
Successful method: Machine wash, gentle cycle, use only Atsko Sport-Wash for these materials with 2 tbsp borax pre-wash. Line dry overnight. excellent long-term results: colors still strong, elastic intact, material feels new.
