Weigh bike with bathroom scale?
I've tried to weigh my bike with a bathrooms scale by getting on it by myself to get my weight and then getting off to zero it and then getting back on with my bike held as close to my body as possible and centered and doing the subtraction. Sounds goofy but not everyone likes to visit the bike shop. One of my bikes weighed close enough to specs, but the other two came in 4 to 5 pounds heavy, Does this method give an accurate weight or are the OEM specifics off. The two heavier bikes "feel" heavier than the OEM listed weight.
Advocatus Diaboli
Quoted: 4761 Post(s)
Liked 1,542 Times
I'd spend the $10 or thereabouts on a digital fish scale from eg. amazon.. handy for lots of other stuff and obviously a bit more portable.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
I use a bathroom scale for weighing my bikes and propane tanks. The tanks I can set on the scale and calculate how many gallons are left, the bikes I have to hold. I do this when I'm packed for a bike hike and am curious how much weight I've added in supplies and such. It works.
Quoted: 858 Post(s)
Liked 1,093 Times
Not goofy at all. Been done by many for as long as bathroom scales have existed. As long as your scale is accurate you'll get accurate weights. Try weighing each bike several times and maybe on different days to check for consistent readings.
Likes For Crankycrank:
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times
Um
Calibrate
The man who has one watch knows what time it is
The man who has two watches is never sure
Calibrate
Likes For bikebikebike:
Your method is fine if you scale is fine. Im sure its perfectly good enough. - Or get a luggage scale. Not very expensive and a bit more handy.
Likes For Racing Dan:
Quoted: 4854 Post(s)
Liked 3,992 Times
I use my bathroom scale. I do a couple of weighings as my scale is slightly different depending on where I stand.
Bike weighings can be sobering, Often not knowing is a happier place to be.
Likes For 79pmooney:
Quoted: 1814 Post(s)
Liked 923 Times
IME, bathroom scales vary body weight up to 5 lbs which is 3%.
Like the current discussion of power meters, a scale can be consistent and be fine to keep track of your weight from week to week,
but not necessarily accurate, so a 20 lb bike could show a 1/2 lb difference from one scale to another.
I happened to recently inherit a set of gram weights, & using them found the >$10 fishing scale to be dead accurate in the 1kg range,
while the smaller countertop scale is good at 100g, but off a bit at 1kg.
We use one* for boxed bikes for shipping them via Bike Flights (Now contracting with UPS)
with CoVid they have to be taken (local presort shipper)
Before then driver picked them up.
*Carton; length, height, width & Weight.. rounded up to avoid penalty charges ..
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4360 Post(s)
Liked 3,023 Times
Likes For DiabloScott:
Oddly enough I got a High tech Scale Made by Nokia, does water & body fat % & heart rate, when you stand on it barefoot..
I don't weigh bikes @ home, it does not matter..
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Also, I wouldn't expect much variation with tube and tire weight, but lower quality tires in a 25 or 28 width can add significant weight to a bike that was weighed with nicer 700x23c tires.
Really Old Senior Member
Depending on how cheap your digital scale is, the resolution may vary +/- lb. quite easily.
Weigh yourself 5-6 times a couple minutes apart and see how repeatable your readings are.
Mother Nature's Son
Quoted: 860 Post(s)
Liked 1,453 Times
Weighing a bike, by whatever means, will almost never match specs from a manufacturer/builder. Manufacturers weigh the bikes in a way that is going to give the lowest number they can get. Marketing places too much emphasis on weight. I am guilty falling of into the light weight hole to a point, but as I have aged, comfort has become more important. I get passed a lot no matter what bike I ride, I am OK with that. I have a titanium bike, bought used a couple of years ago, and it truly is lightweight and comfortable to me. I admit, I like that. Still, that is not he bike I ride the most. My two favorite bikes to ride, a Lemond Tourmalet and a Lemond Poprad, are both more than 2 lbs heavier when they are all stripped down to just the frame/fork and necessary components, no accessories. I have not weighed just the frames with the forks. That figure is likely less at that point.
Likes For delbiker1:
Bikes: Trek 4300, '84 Trek 400,'88 Trek, 85 Trek 720 560, 82 Motobecane Randonee, 75 Schwinn Collegiate, Schwinn Sierra, '84 Trek 890, 2001 Trek 5200 OCLV USPS, 99 Trek Y Foil
Liked 14 Times
And the advertised weight is usually a small or medium frame size, No pedals, sometimes No Seat, Certainly no bottle cages, racks, phone mounts. Its REAL easy to add 3-4-5 lbs to a bike in actual "As Ridden" weight.
Likes For Vefer:
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 882 Post(s)
Liked 1,232 Times
I use Kitchen scales.
Weight on the Front whee + Weight on the rear wheel = bike weight.
Barry
Barry
Quoted: 1439 Post(s)
Liked 1,094 Times
I have a Health-O-Meter balance which uses weights not springs (Dumpster® find) to weigh myself , and my dog by holding her and doing the math. It correlates well with my doctor and her vet. I have never weighed my bikes (don't care) but I would assume it would be adequate for that.
Quoted: 7084 Post(s)
Liked 11,188 Times
Someone's gotta say it: while I understand the academic curiosity, a couple pounds of bike weight, one way or the other, really won't affect your speed (or anything else, other than your ego) to any measurable degree.
And as others have noted, there is no standard method that mfrs follow for reporting bike weights, but they all certainly do NOT include pedals, bottle cages, mounts for computers and such, etc. So, yeah, your bike will be heavier than the mfr's claimed weight.
I'm glad that I wasn't the only one who does this ( a bit too often). My wife wakes up some mornings now and I see her heading to the bathroom (to weigh herself) and a few seconds later she automatically goes down to the garage...
Kind of funny I finally got that 22 pound "light bike" with a carbon fork(which weighs 25 pounds) I was dreaming about and its harder to pedal on steep hills than my 33 pound Giant Talon.... So bike weight is not everything
Guess my wife wont have to head to the garage for a while...
The dropped
Liked 1,014 Times
Likes For ClydeClydeson:
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 930 Post(s)
Liked 393 Times
If you consistently get the same answer for the light one, say before and after the heavy one, then your method is probably valid.
You could also get on there holding a few gallons of spring water and see that you get 8 pounds increment for each.
