Gravel 1x vs Gravel 2x as Road Bike?
Boardwalk Loving
Hey guys - I have been heavily debating getting a gravel bike to use as my "road bike" I like the idea of a little more relaxed/endurance geometry, bigger tires for a smoother ride, etc. I will be primarily using this as a "Road Bike" not really gravel riding.
Have been narrowing it down to several different models of Specialized Diverge or Giant Revolt Advanced. One of the Diverge models I really like aesthetically is Comp E5 which has a 40t Chainring and 11-42 Casette.
My ? is, will this be too limiting from a gearing perspective? Would I be better off in everyone's opinion with a 2x setup, seeing that this will be used primarily on the road.
I'm fairly physically fit, 6'1 180 thinking size 58. Would like to use cyclings to supplement my surfing when the waves aren't great, as another type of exercise that is fun and has much less impact physically than running.
Debating between just getting a base model diverge, riding it and figuring out what I want to do (I.e upgrade from 8spd to something better groupset wise, wheels, etc), going with the 1x Diverge Comp 11sd/Giant Revolt Advanced 1 1x 11spd or Giant Revolt Advanced 2 or 3 2x
I would appreciate the opinions/advice/insight from you guys who are much more experienced when it comes to this than I am haha
Diverge Comp E5
Diverge Base
Giant Revolt Advanced Models
Diverge Comp E5
Diverge Base
Quoted: 4011 Post(s)
Liked 7,519 Times
If you’re going to use it as a road bike, wouldn’t road bike gearing make the most sense?
Likes For tomato coupe:
I bought a Jamis Renegade with a SRAM 1xdrivetrain, use it as my "non-road" bike most of the time, lightly loaded touring other times.. 11x42 on the back, a tiny 38T on the front. On my road bike I am rarely maxing out the big in front/little in back combo, I was willing to give up the high end to have a nice low end for the touring use. I also have the tendency to be a grinder - the lower gearing is good at forcing me to increase cadence, I like that.
Getting the wheel on my road bike rebuilt, so been riding the Jamis on roads for the past week or so. A 40T up front would give you more high end but if you are used to pedalling at over 24mph, you will definitely spin out. But, I would only be doing that on the steep downhills and around here I'm usually riding the brakes doing that to avoid various varmints or cars popping out. I'm not a racer, I'm in it for the fun of riding and the exercise. I like increasing my fitness to go faster.
It came with 40mm Donnelly gravel tires which are great on the non-road surfaces but pretty slow on pavement. For touring, I put on a pair of Schwalbe 35mm Marathons that are much lower rolling resistance and essentially puncture-proof.
I love my carbon road bike but if for some reason I had to only choose one bike it would be the Jamis gravel bike - it is better on the roads than my road bike is on gravel or dirt!
But, if you plan on doing rides with other people on road bikes, you'll be seeing them off in the distance much of the time!
Likes For jpescatore:
Quoted: 7100 Post(s)
Liked 11,223 Times
Go with a 2x drivetrain for greater flexibility.
Likes For Koyote:
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
For road...either will work. IIRC the gear spacing of 1x12 versus 1x11 ends up being close and the range is close too.
Likes For Marcus_Ti:
Bikes: 2021 Trek Domane SLR7 Project One 62cm- 2010 Specialized Allez 61cm
Quoted: 118 Post(s)
Liked 88 Times
You will likely spin out a 40-11 and a 40-42 is not that low of a gear ratio.
Glenn
Glenn
Likes For GAtkins:
Advanced Slacker
Quoted: 2765 Post(s)
Liked 2,543 Times
For dual use.... I’d definitely get 2x.
Likes For Kapusta:
Quoted: 890 Post(s)
Liked 733 Times
I don't have any gravel bikes, per se, but I recently bought a 1x CX bike mainly for road with an option in mind to handle the tamer off-road stuff. I also have more conventional 2x bikes. My 1x is 11sp with 40t chainring up front and 11-36t cassette. For solo riding, including decent climbs, I haven't noticed any downside. I don't go nearly as fast downhill, obviously, which doesn't matter to me. Uphill, the 40-36 ratio has been a non-issue, maybe because I've done a huge amount of low cadence climbing this year. It helps that no FD means a lighter bike. With a bigger cassette, maybe the tooth jumps will bother you -- again, it's something that doesn't matter to me when riding solo.
You would think that a 2x bike is more suitable for road riding, especially in a paceline, but one of the ride leaders of a group I rode with in the before times used a 1x bike and during a ride I even remarked how smooth his lead was. He would drop back on steeper terrain, but groups usually separate then anyway.
Likes For surak:
Non omnino gravis
If you're set on a fat tire road bike, go 2X. You don't need a clutched RD, you don't need a 1:1 final for climbing, you don't need to worry about chain drops from riding washboarded fire roads.
It doesn't hurt that I would buy virtually any Giant model before I even looked at a Specialized. You'll just get more bike for your money with the Giant.
Likes For DrIsotope:
Boardwalk Loving
That's what I'm trying to figure out, would the current gearing be sufficient for what I am looking to accomplish. Also, the reason I am trying to decide if starting with a 2x setup makes more sense
Boardwalk Loving
At least get 50t chainring. You'll grow out of 40t eventually if you'll mostly be on the road, trust me on this!
Also, don't miss the fact there are road bikes now with more relaxed/compliant geometry that fits 33mm wide tires. That with compliant carbon seatposts and aero dropbars, they'll be just as smooth and comfortable on the road as gravel bikes.
Quoted: 915 Post(s)
Liked 2,100 Times
Nobody here knows how strong you are, what hills you're going to climb, how far you intend to ride, how much you like to mash or spin, what speed you're okay spinning out at, how much you want to keep your cadence constant, what your goals are, who you ride with, etc. That doesn't stop people from filling in the blanks with their own answers and telling you what you should do, sometimes with great vigor.
Find a gear calculator, plug in the cadence numbers you like and the gearing choices, and see how it shakes out.
Boardwalk Loving
I'm a little biased because I just ordered one of these but the All-City Space Horse is supposed to be a great bike for those looking for something versatile. Not sure if you have your heart set on particular brands but I'd give All-City a look.
https://allcitycycles.com/
Likes For partyanimal:
An 11/42 cassette sounds like a better idea than it really is. On the road, no matter what chain ring you go with it is a nuisance to an abortion if you are riding on variable roads and shifting a lot.
Likes For Mulberry20:
I don't claim to be an expert, but here is my experience, for what it's worth. I recently bought a Giant Revolt Advanced (2021 model year), wanting something to ride the forest service roads a bit faster and farther than on my hard tail MTB. My intention was exclusively unpaved, but sticking to the smoother primary forest service roads in better shape (I still leave the rough stuff for my hard tail).
Coming from the MTB world of 1x drivetrains, I went with a Revolt Advanced 1 (40t up front, 11-42 in the rear), because I prefer the simplicity and aesthetics of a 1x system - and the jumps in gearing never bothered me on my MTB, so why would the gravel bike be any different. Also, I don't race or generally do group rides. Well... I gotta say that I can now see some advantages of the 2x system. Most of the time all is fine with the 1x, but there are times, especially when riding long slight inclines on the smoother roads, that there are (were) a couple of cog jumps that felt a bit too large (messed with my cadence), specifically between the 21 and 24 and the 24 and 28 cogs.
I think I may have now effectively solved this problem (for me) by replacing the 11-42 cassette with a 11-34. This eliminated the slightly too big jumps between cogs in the mid-range and I don't miss the larger cogs because I don't have to deal with real hills - I live in the coastal plain and where I ride this bike is pretty darn flat. If I ever take it to the mountains, switching the cassette back is fairly quick and easy. So now I feel like I have the best of both worlds. But I don't ride smooth paved roads and in no danger of spinning out the 40-11. But if you do, changing out the chainring to something bigger should be an easy enough task. And I still really do like the simplicity and aesthetics of the 1x - acknowledging that is completely subjective personal preference.
While the Revolt Advanced 1 is still fairy new to me, I can categorically and without reservation tell you that I absolutely love it! Zero regrets or reservations. Super comfortable and confident. All I want to do is ride it. All I think about is riding it. I am staring at it right now thinking I should get off this silly computer and go ride it.
And, last thought - if you do get a gravel bike and have 'gravel' roads near you, you should definitely give them a spin, riding them is a blast.
Likes For SwampGrinder:
I know you said Giant Revolt, but if you're mainly using it for road riding, but still want pretty big tires, a Giant Defy with something like a 32c Hutchinson Sector would probably be the ideal bike for you, and still be perfectly fine for gravel that's isn't too crazy.
Likes For zen_:
Boardwalk Loving
I went and rode the Trek Checkpoint ALR 5 today, it felt alright, shifted pretty smooth, brakes were ok
Put a deposit on a Diverge Comp E5, Rock n Road had one in stock in my size and wanted to be able to ride it before it sold out. Couldn't test ride that one at the time because I had my 11 month old son with me when I went to go look. Will ride it this week to compare geometry and sizing and the deposit is fully refundable if I don't end up wanting it.
I'm going to check out some of the other recommended bikes in this thread also
Boardwalk Loving
I'll have to check it out! 32 would be nice and a good compromise
Boardwalk Loving
I absolutely love the way 1x looks aesthetically as well, just looks so clean up front. I called around to every Giant dealer in so cal today to try and find a revolt advanced to at least go look at, found a shop that has an XL that I will go check out to see how it feels even though XL is too large for me
Boardwalk Loving
Bikes: 2019 Specialized Diverge, 2021 Cervelo Caledonia
Quoted: 262 Post(s)
Liked 380 Times
You definitely want to get the 2x chainrings. My only bike is a Specialized Diverge Comp, which I ride mainly on paved roads, though sometimes off-road. I like it as a road bike, and the option to go off-road is very nice. When riding on pavement, I often find myself on the big chainring and smallest cog on the cassette (48T up front and 11T in back). You need a bigger chainring than 40T to ride it on pavement. You say you are physically fit. I'm in pretty good shape too, but I'm also 70 years old. If I'm riding in the highest gears with my 48T chainring, you would not be happy with a 40T chainring. When it comes time to replace the chainring, I'm even considering going to 50/34 because I'm in high gear so much of the time.
Likes For Random11:
