What Trek Did I Get from the Vancouver Bike Swap?
Car free since 2018
Bikes: Mostly japanese ones
Liked 279 Times
There was a bike swap today in Vancouver (it's still on till 2 PM). It's the size of a small parking lot (because it takes place in a parking lot). I think prices were pretty reasonable, and there was enough stuff for me to take home. Some stuff I wanted to take home but I passed. I might end up regretting that in a few weeks but I guess there's always next year. It was fun because there was enough stuff to buy and with the local coops here kind of affected by covid, it was a chance to browse for stuff.
I hadn't intended on buying a frame since I was on my bike, and this is one size smaller than I prefer, but hey, for 40 CAD I can probably make it work. So what is it exactly? Seller wasn't too sure other than "early Trek". The serial number is either 05xxxx or 06xxxx.
There's only one set of bottle bosses. It came with a bottom bracket, which interestingly to me is marked "superbe". No tubing decals, no country of origin.
What year and model do you think?
seņor miembro
Bikes: '70s - '80s Campagnolo
Liked 7,001 Times
Steerer looks really tall for that head tube.
Liked 2,186 Times
Decal set is from 1981 or 82, chain stays will indicate whether it was a touring 400 series or perhaps 500. Just a guess, Smiles, MH
Car free since 2018
Liked 279 Times
First time I've bought a frame without a headset. I just assumed they belonged together on account of, they were together. I know nothing of fork sizing, if you could educate me I would appreciate it. I will try to take some measurements later when I get a chance.
seņor miembro
Liked 7,001 Times
Yeah, it would be weird if they didn't belong together. It may be just fine. Didn't want to startle you. Unless there's visible damage, go ahead and mount/press your headset and go from there. If the steerer is too long, you can always trim it down easily enough. Hopefully, the threads reach.
Likes For SurferRosa:
Old Bike Craphound
So much better to have a steerer that is too long, rather than what I always find!
-Will
-Will
Serial number?
Car free since 2018
Liked 279 Times
Likes For rgvg:
Both serial numbers are for a 1983 520. Probably 053741, a 19" frame. https://www.vintage-trek.com/images/t...83/83Trek7.jpg
Is the seat post unstuck?
Steerer tube length sounds right.
Car free since 2018
Liked 279 Times
Thanks again.
Car free since 2018
Liked 279 Times
Little more help please. The fork is slightly gouged at the top. I tried to take a picture but it was blurry, and I accidentally pressed video instead of picture,... I can try again tomorrow. Maybe somebody dropped the fork and it landed top first?
Anyway, the tube is not out of round but the gouge has pushed some material towards the center of the tube. Maybe 1 mm or so. it is enough to make putting in a stem a problem.
How to fix? What tools would I need?
Liked 2,327 Times
[MENTION=468594]rgvg[/MENTION] Exhaust pipe expander. Some are small enough.
Hoards Thumbshifters
Bikes: '23 Black Mtn MC, '87 Bruce Gordon Chinook, '08 Jamis Aurora, '86 Trek 560, '97 Mongoose Rockadile, & '91 Trek 750
Liked 342 Times
It was originally a 27" wheel 126mm rear dropout spaced bike, however this was just before they made 520's with Cantilevers so you just need longer reach caliper brakes or center pulls to make this frame work with 700c wheels. Cool find and worth the build up.
Car free since 2018
Liked 279 Times
There are a lot of BF forum members around you surely someone will know what to do or how to help, if this is an old 520, it will be a lovely rider to build up. Also, this may be worth looking at with a bike shop. You'll need a new headset, and depending on how much tube length is needed you may need to cut down and rethread the steering tube anyway.
I knew I would regret passing up on some stuff at the swap, like longer reach calipers or center pulls....
I'll try to take the fork to the coop when there's a chance. Their hours are still limited due to covid, but I guess I could try some bike shops as well.
Thanks all.
Liked 342 Times
I haven't had the pleasure of meeting any other BF members around here. Or I might have and not known they were on here. I guess you could file me under "socially awkward".
Thanks all.
Thanks all.
Bikes: 48 Alleluia, 52 Blondin, 68 CNC, 55 Dujay, 46 Herse, 67 Herse, 76 Singer, 48 LeGreves, 55 Metropole, 62 Holdsworth Cyclone, 55 Condor, 65 Masi Special, 81 Sequoia, 76 Eisentraut, 72 Proteus, 60 Paramount, 77 Trek TX700, 81 Ross, 82 CBS, 70 Cinelli SC
Liked 159 Times
Thanks all.
Thanks all.
Old Bike Craphound
As another Vancouver resident C&V member:
I did not make it to the Swapmeet - I meant to but then .... life. I am glad to hear that there was interesting stuff. The COVID19 bike boom and restriction at the co-ops has made this a curious time for C&V. I have a good stockpile of medium quality parts and bits, and I am a long-time volunteer at the co-ops, which rarely seems to make a difference. If you are stuck for something, let me know and we may be able to work out a swap.
If the steerer on your fork is close, you can always add a few spacers, and cutting it shorter is not hard (just put a few threaded pieces on the steerer below the cut so they can chase the threads clean when you remove them after the cut). If it is much too short and you need to cut threads lower on the steerer, both OCB and the UBC Bike Kitchen have the dies and tools to do this, but for now you cannot do that work yourself (no DIY repairs because of COVID19).
-Will
-Will
I know there are a few BF members here in Vancouver - I've even met one in person. I went to this swap meet yesterday for the first time, and was pleasantly surprised. There were some interesting frames for sale, including RIH, Gazelle, CBS and Derek Bailey. I managed to find some useful bits including some TA/Stronglight 49D cranks and rings.
Liked 159 Times
Vancouver swap meet
If I do a search for the address, I find Terminal City Riders: https://terminalcityriders.ca/
Looking through the photos of past events, one wouldn't expect to find too much road stuff, but there was some this year and it did seem to be selling reasonably well. One fellow who had several interesting frames for sale did manage to sell all but one or two. There's no fee for sellers, which I'm sure encourages folks to haul out whatever odds and ends they've accumulated and sell them cheap. I might try it next year.
The event poster says "6th Annual" - here is their ad on Craigslist: https://vancouver.craigslist.org/bnc...192451899.html
Car free since 2018
Liked 279 Times
