28c vs 32c?
Bikes: Way too many
Quoted: 954 Post(s)
Liked 616 Times
28c vs 32c?
So I picked up a 2nd hand few week old bike a few weeks ago (Carrera Zelos), which comes on 700x28c tyres though the wheels can go up to 700x32c.
Am I (at 91kg) likely to notice much difference going 4mm wider?
Quoted: 2639 Post(s)
Liked 1,986 Times
Depends on your weight and the roads you ride, and the pressure you'd need in each size (not to mention which tire, which is a hole 'nuther thread).
I find 28 a bit rougher on rough roads, but slightly quicker on the front. YMMV.
Likes For pdlamb:
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
That is an aluminum frame, so wider tire would probably be a little better ride. Tires are individual though, and I don't know your road conditions.
Likes For c_m_shooter:
Bikes: Way too many
Quoted: 954 Post(s)
Liked 616 Times
I'm in Central Scotland, our roads are pretty awful. I haven't been on a proper ride yet to see if it's too bad on the 28c's.
Mad bike riding scientist
Quoted: 6276 Post(s)
Liked 4,303 Times
I’d say no. Too much fuss is made about marginal width changes on tires. To give some perspective, take two 2 pence coins and stack them. (Two nickels for us “Mericans) That’s the width and height change. And the amount of change in ride characteristics is going to be about as valuable.
Stuart Black
Stuart Black
Bikes: 2021 Trek Domane SLR 7, 2012 Giant Defy 0, 2012 Trek Domane 6.2 P1, Bianchi Infinito CV disc Di2
Quoted: 212 Post(s)
Liked 1,000 Times
Huge difference.
I have both (tubeless) - 28s on the Bianchi Infinito and 32s on the Trek Domane.
The difference in volume is what gives the much smoother ride on the Domane.
When the Bianchi needs new tires, I will switch up to the 32s.
Ride hard and ride on......
Likes For wthensler:
Bikes: Way too many
Quoted: 954 Post(s)
Liked 616 Times
I think that's where I'm at - I may just keep the 28's until I wear them out (I'm hoping to spend a lot of time on the turbo trainer over winter) and then replace them with 32's. Unless I stumble across a cheap enough set of 32's. If I recall correctly the inner tubes I have will work with both.
Likes For Herzlos:
Liked 4,303 Times
The only place it matters is at the contact patch. I’ve done the calculations before and it works out to a few milliliters more volume. It’s tiny in the grand scheme of things.
Stuart Black
Stuart Black
Likes For cyccommute:
Pennylane Splitter
Bikes: Yes
Quoted: 1861 Post(s)
Liked 1,517 Times
The 28c tires I've ridden were rated for 110psi pressure, most 32c for 70-80psi. Purely my speculative opinion but it seems the 32c give a more 'cushioning' effect since its not pumped up to as high pressure and can flex a little over bumps and road crap. And . . .its easier to pump up a tire to 70psi than to 100psi when you're on the side of the road fixing a flat tire. Those last few pumps at 100psi can be a b!tch!
Bikes: Way too many
Quoted: 954 Post(s)
Liked 616 Times
Very good point, I've never gone above about 50psi before and even with a track pump that's a bit of work. 100psi on a compact hand pump must be awful!
Quoted: 56 Post(s)
Liked 14 Times
That's only really true if you don't account for the change in psi between thinner and wider tires. Considering a 180lb rider and two otherwise identical tires (using Schwalbe's recommended PSI for the Marathon Plus as an example), the contact patch difference between 95 psi (the recommended psi for 28c) and 80 psi (the recommended psi for 32c) is almost 20%. That is without even considering the additional increase in contact patch from the tire width increase as well.
Really Old Senior Member
If your roads are rough, you'll probably appreciated that little extra "squish" to help "absorb" peak impacts. Especially sharp edged potholes.
Your wheels will appreciate it too, with smaller peak loads on the spokes.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
A little extra will always matter...we've got crap roads here in Belgium, too (not all, but many), as well as a fair amount of cobblestone and pavé. I've ridden 28, 30, 32 across all of this. Bigger is always more comfortable, and not necessarily "slower." Check out this link from SILCA for determining pressures, I use it, and have never had an issue, I pretty much don't care what is printed on the sidewall because it doesn't take into account all the factors at play such as total system weight, surface condition, actual measured tire width, etc.
Likes For Badger6:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
A small different in tire width wont make much difference according to the actual tire design as well as the tpi (threads per inch)
FWIW. My older bike only fits up to 25c and the newer bike has 32c. After riding both for many years I grab the 32c bike much more than I do the 25c.
got the climbing bug
Bikes: one for everything
Quoted: 636 Post(s)
Liked 930 Times
I've ran panaracer gravelking in both 28 and 32s for several yrs now. I don't find there is much rolling resistance feel between the two but the comfort level in the rough stuff does feel different. They are soft and grippy tires in the turns w/ decent/good flat protection.
If you can fit it, 32 should be way to go. I run the slick(file thread version) and they are about $35 on amazon prime.
https://www.panaracer.com/lineup/gravel.html
Rule #10 // It never gets easier, you just go faster.
Drip, Drip.
Liked 193 Times
Quoted: 636 Post(s)
Liked 930 Times
Well that is the beauty of larger tires. You can run them at lower tire pressures to get the feel or traction desired.
my 28s I’d run them about 80psi tubed
my 32s I’d run them about 60f/65r tubed
no point having all that case volume just to pump it up to max that is printed on the tire....
Drip, Drip.
Liked 193 Times
Gotta also consider that the width of your rim will change overall tire width. I've played around with a caliper measuring tool here and there and noticed that nearly all tires run at roughly .1 inch narrower than what is advertised on the tire.
Bikes: Way too many
Quoted: 954 Post(s)
Liked 616 Times
As an update; I went to buy a pair of 32c tyres for the bike, and in the end bought a new bike with 700x40c tyres on. So I've dropped from 90psi to 50psi and the comfort difference is incredible!
Quoted: 794 Post(s)
Liked 1,851 Times
Likes For jaxgtr:
Likes For Moisture:
Bikes: Modified 26 inch frame Schwinn Varsity with 700c wheels and 10 speed cassette hub. Ryan Vanguard recumbent. 67cm 27"x1 1/4" Schwinn Sports Tourer from the 1980's. 1980's 68cm Nishiki Sebring with 700c aero wheels, 30 speeds, flat bar bicycle.
Quoted: 131 Post(s)
Liked 141 Times
I have an old steel road bike with 700c x 32mm Gatorskin tires and am very happy with it. It does go off road but frankly my 700c x 40mm equipped bike is much better for off road. I also ride the older 27" x 1 1/4" wheel size with Schwalbe Marathon tires and it is quite comfortable and good handling. I ride the 27" wheels offroad a lot but again 40mm is better offroad. Had to get my two cents in.
Drip, Drip.
Liked 193 Times
As for the rear rim, there is so little clearance between the chainstays, that even if the rim bends slightly, the tire begins to rub. I measured the tire as 1.1 inches wide using a park tool caliper thingy...
I simply tried to compensate by adjusting the angle of the rear rim between the chinstays. I've already trued the rear rim twice. I can't tension two of the spokes properly or the wheel will simply bend more. After doing whatever I can to make the rim almost perfectly true, it loses tension and becomes slightly bent again the very next day. I need to replace the rear tire but I'm sort of weary to even bother until I can get this rubbing issue figured out.
Other than getting a new rim, any suggestions?
Quoted: 794 Post(s)
Liked 1,851 Times
700c is not the same as 27, but they are very close. 27 in is 630mm and 700C is 622 which will explain the tightness you are getting. How wide are the rims and what size size tire are you running?
