Riding TL, get a puncture, seals, get home and...
and then what?
I was on a ride and on the way back, 10km from home hisssssssssssssssss and milky stuff spewing out of the tire. This was a first for me so wasnt sure, stop or keep going. So I slowed down and the goo managed to seal the puncture. When I got home, I was trying to plug it and I have added extra sealant. As soon as I pumped the tire up the plug went flying, couple times I did this. So then again I added more sealant and pumped the tire up. Now it seems to hold, but I did not go for a ride yet. Looks like the hole is about 1/8" and its more of a cut.
What should I do? Go for a ride and see if she holds? If it does I am all good or not really?
This is on Gravelking SK 32mm tires.
If there is a hole or cut in the tire large enough for the sealant to leak through, you either need to boot the tire or replace.
Likes For ClydeClydeson:
If you used a Dynaplug or a Stan's Dart and it went flying, it was installed incorrectly. I haven't used bacon strips so I can't speak to how those could come out.
Many people ride Dynaplugs for the life of the tire. Darts have not been out as long, but expect those will also be ridden the life of the tire as opposed to being booted.
There is lies the problem. I dont have the booster pump to set the tire again so I will need to bring into a shop.
I guess my adventure with TL tires stop now. Switching back to tubes and dealing with punctures the old way
But if the sealant did seal why did you try to plug it?
Dynaplug or a stan's dart are there for the life of the tire and you just need to top up the sealant to be ready for the next one...
No need to take the tire off until it's worn out or damaged beyond a plug.
I had a really big puncture that seeped if I added too much air. I rode with ~50psi for about an hour and it sealed up just fine after the sealant hardened a bit. Still good today!
Went for a ride today, managed to get 100m from home. Rode back, swapped it all back to tube and old tires.
Personally, I prefer tubes in my bike tires. But then, I started biking around the time Goodyear invented vulcanized rubber. LOL.
The Old Peddler
The Old Peddler
Likes For The Old Peddler:
And this is why most people use tubes for road bikes still. The high pressure just doesn't work well with sealant and punctures. It's great for gravel but tires are usually under 40-45psi..
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Disco Infiltrator
Liked 2,150 Times
What you shouldn’t have done is anything.
Genesis 49:16-17
Genesis 49:16-17
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Liked 1,318 Times
TL Patch
I've pulled Goat Heads from the 5000TL's and never done a thing after that. It seals itself...done.
This works for the small pin prick type hole.
On the larger size (glass shard) I've patched the tire from the inside. Originally I used a regular tube patch after much scrubbing and cleaning.
Now I've the Rema Tubeless Patch kit ready and waiting for my next repair.
Barry
Barry
