replacement disc..HELP!!
Hi guys and gals, hope you can help me......Had a bit of a mishap........end result is my brake disc is bent beyond repair, its a great hub and wheen, no other damage other than the disc. Im finding it impossible to get a replacement, hopefully you can come up with a solution. Its a Shimano SM-RT67 centrelock. The disc itself is riveted with steel rivets to the spider impossible to do at home......Stamped on the disc is SM-RT67. Is there a repalcement forv it that you guys might know of? its 160MM. Thanks in advance
Liked 1,102 Times
You have to replace the entire disc, which is quite easy. Any Shimano or other make center lock disc of the same diameter will work.
The SM-RT67 isn't made anymore, you'll have to replace it with a newer model or find a seller with some old stock.
* some Shimano rotors are made for resin pads only
https://bike.shimano.com/en-US/compo...ake-rotor.html
https://productinfo.shimano.com/#/co...460&acid=C-461
The SM-RT68 and SM-RT70 are SLX models that would be equivalent to your old rotor.
Likes For Pop N Wood:
Wow, thanks guys, you have saved me much searching and hassle. Much appreciated!!!!!!
One more question if I may? What would be the difference between the RT 68 and the RT 70
Lol!! Not a weight weenie so I will follow your advice, thank you so muck, all of you!!
