Cracked Mavic Ksyrium Elite wheel
Got back from a ride last week and noticed when cleaning the crack in the hub of my wheel (they are 3 years old so not under warranty anymore), have emailed Mavic and they want £130 + 20 postage to repair (could be more if crack worse than pic)
Is it worth it?
Is it worth it?
Your hub is cracked or the wheel is cracked?
www.mp-aviation.com
www.mp-aviation.com
Quoted: 18526 Post(s)
Liked 15,872 Times
Only you can judge for yourself if it's worth fixing.
This time, but some campagnolo zonda wheels from probikekit.com.
Likes For DaveSSS:
Quoted: 4717 Post(s)
Liked 1,882 Times
Happened to my rear SL Premium many years ago. It was newer than yours. I got it replaced through the LBS where I bought but had to pay about that much. There was also a problem with the internals of the rear hub that started early on and that Mavic wanted a couple of hundred dollars to fix. There was also a known design defect in the spoke nipple that could cause drying and ultimately cracking if a true was need, which happened to the front wheel. Had to pay to have the cracked spoke nipple fixed. I told Mavic to engage in intercourse with itself re: the hub and have not bought another Mavic product since.
Likes For noodle soup:
