Dilemma between chains: HG, IG, or SRAM. Please advise.
Bikes: 96-97 Gazelle Medeo.
I have a triple Shimano Alivio IG crankset and 7 speed Alivio IG casette.
The chain is currently Shimano IG 50. I want to install a new chain.
What would you recommend?
Here in Holland in bike shops around they have Shimano HG 52, HG 70/73, HG 90/93. Oredering from the
web is an option but I would rather avoid it due to waiting period and other issues.
Also Sram PC 58 is available, at a good price.
I read conflicting reviews, and bikeshop owners insist that using HG chain with IG system (IG front cranks) is acceptible.
Sheldon Brown strongly recommends PC 58.
So, all the opinions and reasons would be greatly appreciated. Please post your opinion.
Thank you.
Thank you.
Liked 735 Times
I ride a bike with that same crank and cassette and am using the PC-58 chain, and it works fine.
Whenever I need to replace the current PC-58, it will be another PC-58.
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
I'd like everyone to stop and notice something... 5 posts, plus a citation from Sheldon Brown, and a post from syndey, and they all agree... I'm marvelling at the simple beauty of this thread...
peace,
sam
peace,
sam
Bikes: are better than yours.
peace,
sam
peace,
sam
You should only use motor oil to lube that chain when you put it on. Let the flames begin!
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Another vote for the SRAM chain. Not just for the Powerlink, but the roadside servicablity is easier then Shimano. No special pins to deal with.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I've also found SRAM chains to be more durable and stronger than Shimano chains. Perhaps it's because SRAM chains are so much easier to clean or perhaps they are indeed stronger but I've never snapped a SRAM chain whereas I've broken about a half dozen Shimano chains over time... everything from HG50s to their, at the time,top-of-the-line CN-7700s. I'm now running Wippermann chains and would highly recommend those too. They also have a tool-less removable reusable link (ConneXlink) like the SRAM PowerLink. Check out the Wippermann Connex 808 chain. It's comparable to the SRAM PC58.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
First, I would like to thank EVERYONE for your input.
With PC 58 getting so many positive votes from reputable users, and considering almost half the price of shimano chain, I seriously consider it.
But is PC 58 is as narrow as HG 70 for example? If, so, then IG (wider ) chains are recommended by shimano:
https://cycle.shimano-eu.com/publish/..._ig_chain.html
" If you use a HG chain with a 7-speed IG cassette (CS-IG50 and CS-IG60) the rear derailleur adjustment becomes more critical. One significant compatibility issue is always avoid using a HG chain with an IG-only crank set. Why? The chain will release from the large (outer) chain rings too easily while in the large rear cog. It may be potentially dangerous if the chain drops off the outer ring without shifting the lever, under full power."
In other words, is PC 58 similar in that respect to IG or HG chain?
DEADBEEF
Liked 6 Times
The SRAM PC58 is 7.1mm wide. This is the same exact width as the HG50/70/91 and IG31/51/70/90 chains. The HG53/73/93 and CN-7700 chains are 9-speed chains and have a 6.57mm width.
kipuka explorer
Bikes: 1994 Trek 820, 2004 Fuji Absolute, 2005 Jamis Nova, 1977 Schwinn Scrambler 36/36
I love my powerlink! (I have only experience using PC-58 with an 8-speed cassette) It boggles the mind why Shimano doesn't have a competing quick-link.
-=- '05 Jamis Nova -=- '04 Fuji Absolute -=- '94 Trek 820 -=- '77 Schwinn Scrambler 36/36 -=-
Friends don't let friends use brifters.
DEADBEEF
Liked 6 Times
Originally Posted by bkrownd
I love my powerlink! (I have only used it with an 8-speed cassette) It boggles the mind why Shimano doesn't have a competing quick-link.
Originally Posted by Inoplanetyanin
Could the chain cause this??? Or are there some adjustments possible?
How's the weather in Los Angeles?
Originally Posted by The Fixer
Hot & muggy this week......not pleasant for cycling unless you're near the coast. So did you take your bike with you to Holland? Will you be doing any touring there?
Ok,it's also pretty hot here this week, but was raining on and off for a few days last week.
Well, my Schwinn Traveler got stolen. I bought a Gazelle medeo hybrid bike here in Holland. Yes, touring is on my mind. In fact, we might go to Schiphol to Amsterdam tomorrow with my gf, and perhaps spend the night at the sea.
I was tuning and adjusting the bike this past week, before taking it somewhere far.
They don't have Schwinns here, so it feels special even more now.
DEADBEEF
Liked 6 Times
Yes, thanks George.
I am already looking for new 7 sp casette. IG or HG... Tourney or LX...?
kipuka explorer
Good possibility that your cogs are worn. A new chain and worn cogs don't mate well....
I got IG 60 cassette now.
Thought since you mentioned it, George, have you ever actually used more than one chain on the same cassette?
I hear conflicting info: some say that cassette needs to be changed at the same time as the chain, others insist that you can use several chains before replacing the cassette.
It is my belief that every person in this world has something to teach, and everything to learn.
In memory of Jim Price (aka. sydney) ...
