Heat & Shape Shimano Hyd. Hose?
Quoted: 1638 Post(s)
Liked 741 Times
Is it possible?
To get better routing of my brake lines can it be heated to soften, then shape and cool?
nine mile skid on a ten mile ride
Quoted: 1441 Post(s)
Liked 1,095 Times
Being brake lines I would be wary of doing anything which might weaken them, but using a spring tubing bender might help keep it from collapsing: https://www.amazon.com/Wostore-Sprin.../dp/B07W5MTTND Filling the tubing with fine sand is another method, but getting all of the sand out could be problematic.
Liked 741 Times
The line is a plastic material of some sort. It can be carefully bent without collapse but returns to the original form.
I may acquire some new line and test it first.
Thanks!
Thanks!
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Keep in mind it is essence a pipe, so if you put a sharp bend in it, however perfect, it will disrupt hydrodynamic flow and thus braking power.
