Is this the chain stay? And how to fix?
Quoted: 25 Post(s)
I want to buy this bike but before I go drive to check it out, I wanted to ask if this area of the bike is any concern? Apologies if this is the wrong place to post this.
Quoted: 1188 Post(s)
Liked 1,154 Times
Chain is a little long and has been flopping around while they ride over speed hump cross chaining...
Randomhead
Liked 3,802 Times
They have been dropping the chain a lot. Put a sticker over the paint damage.
I would replace the chain and have the bearings looked at by a mechanic and everything retorqued, cables. Tune up stuff.
You can buy an adhesive chain stay guard to cover that up. Or you can buy colored silicone tape and wrap it.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Congratulations on posting the least useful photos I've seen on here in a while. Yes, that is the chainstay. No, I can't tell a thing from your blurry/too far away photo. It 'looks' like it's just dirt and lube from the chain hitting the stay, but can't say for sure.
Quoted: 590 Post(s)
Liked 445 Times
I'm guessing the crappy photos were taken by the bike's seller and posted on CraigsList.
Likes For Riveting:
Liked 3,174 Times
have it stripped down, inspected, then if all is good.. have it professionally powdercoated.
-YMMV
-YMMV
Likes For Troul:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
You can play around with the bolts holding the rear derailer in place to ensure that the chain is tensioned properly.
Next remove a link (or two or three) from the chain
Likes For atwl77:
Bikes: lots
Liked 2,932 Times
Randomhead
Liked 3,802 Times
Likes For unterhausen:
Sunshine
Quoted: 11103 Post(s)
Liked 7,708 Times
...though by the volume, it looks like its more permanent than that.
Really nice bike otherwise and as mentioned- you can just wrap it or buy a chainstay protector to cover it.
Quoted: 609 Post(s)
Liked 352 Times
You know you don't actually have to post on every thread with your negative unhelpful comments. Your comments are starting to wear thin. Maybe RoadBikeReview wants you back? Then again I bet they don't.
Likes For blakcloud:
Quoted: 1649 Post(s)
Liked 1,875 Times
This is the seller who sells bikes in the Dogpatch neighborhood under the 280 freeway overpass, right? His name is Chris and he is a good honest guy. Just ask him if there is any real damage to the chain stay.
I doubt there is any real damage there. It's just scratches and gunk just like you would find on any chain stay.
Likes For icemilkcoffee:
Quoted: 4896 Post(s)
Liked 4,067 Times
@kevsf, that's a steel frame. It takes some real abuse to go anything more than cosmetic damage from the chain. If I saw dents in the chainstay, I'd pass on it but I highly doubt that is the case.
Chainslap happens, especially if you are coasting when you go over a large bump. especially if you are riding in the smaller cogs or chaInrings. That chainslap takes off the paint but (at least on steel) does no more, As others said, you can cover the paint damage with a stainless steel cover made for the purpose or any number of creative tape schemes. It's really not a big deal. The bike will almost certainly die of other causes long before chainslap of the resulting rust kills the frame. And that death from other causes might be 50,000 miles away or more.
If it fits, does what you want and tickles your fancy, buy it and enjoy! (Without actually seeing and shifting the bike and gears, the chain length looks totally reasonable. You may need a new one; that is part of the "turf" buying a used bike, but don't alter the length without careful consideration.)
Likes For 79pmooney:
Quoted: 18596 Post(s)
Liked 16,096 Times
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
The chain should be replaced if it's worn out. But it might be just fine.
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
