Crunchy/grinding drivetrain
^that guy^
Setup:
DuraAce single sided fixed hub
Soma 18t cog
Sugino 75 cranks w/ AARN 49t ring
Izumi Jet Black chain.
Upon taking off and slowing down I get a nasty crunching feeling in the pedals. Chain line is off by a couple MM. Always been a lil noisy but crunchiness wasn't always there. Tried changing the chainring to a Campy 49t 3/32 ring and it's still doing it. Running SCC Slick chain lube .
Soma 18t cog
Clark W. Griswold
Quoted: 4449 Post(s)
Liked 4,111 Times
Pictures maybe? Could your chainlink be too tight? Maybe things need a good cleaning or maybe you have the wrong chain on it 1/8 vs 3/32 or vice verse.
^that guy^
Clark W. Griswold
Liked 4,111 Times
Maybe a picture from the side would be handy.
^that guy^
Clark W. Griswold
Liked 4,111 Times
Yes to see chain tension but it looks pretty good. When you are spinning the cranks do you have any really tight spots as that can cause some noise. If that is the case loosen just a touch more. I really doubt 3mm is going to cause any issue with noise. I have never once measured chainline on any of my bikes and really don't intend to unless doing some odd conversion.
^that guy^
Feels more like metal rubbing metal than a crunching I guess... Was way more noticeable with the 3/32 Campy ring.. tossed the aarn back on and it's not as bad. Might just try a new chain since I've heard the Izumi chains are notorious for their noise.
^that guy^
FIXED GEAR
Bikes: 2019 tarmac pro disc 2020 allez sprint track
Quoted: 14 Post(s)
Liked 36 Times
I was waxing my fixed chain 1/8 but damm thing only lasted 45-50 miles until it started squeaking and making all kinds of noise. I would ultra sonic clean it, then hot wax it. I think wax is better for geared chains more wiggle room for wax or lube to work in. Wax chain was all kinds of noisy when it intermeshed with the cog. So I tried tri flow kinda ok I guess, Cleaned it and now using Phil tenacious oil, only bummer is it flings everywhere for a few rides which I hate, I like clean bikes which is why I started waxing. So far all is good and quiet just messy.
op have you made any changes since the noise started? Its not really clear how long you have been getting the noise. Is it noisy even free wheeling it on a stand? Or only noisy when you apply force to the cranks? are all your parts new? used? some used? more info!
Mine started doing this and also got harder to pedal. It was the bottom bracket bearings. Check those and the wheel bearings. Take the chain off and spin the crank and listen/feel for the roughness. Same for the back wheel. Other than that your chain looks a little dry and could be some grit in it. If the previous 2 things don't work degrease the chain and reapply some other type of grease to it.
Clark W. Griswold
Liked 4,111 Times
I use the Izumi super toughness and don't experience a ton of noise on a EAI Gold Medal cog and Sugino Zen chainring. It sounds like you have a pretty decent set up but maybe the cog is not as round as it could be?
Likes For veganbikes:
^that guy^
When spinning it on a stand I only get what I describe as rollercoaster racheting.. I can only hear it if I put my ear to the seat or other parts of the bike, I'm only getting the "feeling" when I have my weight on it tensioning the chain. Drivetrain is clean and recently lubed up.. and nothing has been changed. New chain is in the mail.
^that guy^
Thinking about it, I do remember hitting a patch of sand on a ride shortly before this started up. I've throughly cleaned everything since.. probably 2-3 times trying to get rid of it. Hopefully new chain fixes it
Clark W. Griswold
Liked 4,111 Times
My Langster got briefly crunchy after I did a touch of maintenance and lubed it tonight. I spun the cranks a bit and it went away. Nothing was particularly dirty as the bike is a pure road bike and rarely sees bad conditions since I have enough other bikes that have fenders and such. I don't know why it got crunchy but it is gone.
^that guy^
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 766 Times
I soak mine in a bucket filled with mineral spirits, swirl it around and use a nylon bristle brush, then spray it off on my driveway with a garden hose nozzle, then sun dry. I then immediately reinstall it on my bike and lubricate it to avoid corrosion. I don’t think those Park cleaners work very well.
Also, I use master link chains on my SSFG bikes to facilitate removal and reinstallation.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
^that guy^
Finally got the new chain in the mail and put it on... Fixed my problem... Noticed when sizing the new chain next to the old one it had about half link of stretch over the entire chain length. Not sure if that'd cause the issue I was having or not though.
Likes For TejanoTrackie:
^that guy^
It really didn't have a whole lot of mileage on it either. I was surprised to see that much stretch on it.
^that guy^
Update... Still making these horrible noises, enough that my wife could hear them as I rode by... Swapped on my old crankset that gives me a 100% straight chain line and it's gone.. that 3mm off definitely made a difference.. I'll just save the 75's for another build that will allow them... Stupid Wabi Classic, not sure how they work on the Special but not the Classic.
