Built a rack to fit Tandem into our 2012 Odyssey - no front wheel removal
For anybody interested, I did some measurements and decided I could fit our 1997 DaVinci Tandem into our 2012 Odyssey by taking out the center middle row seat and building a rack to hold the rear wheel. I'm a person of simplicity so if the bike is in one piece I am more likely to haul/ride it than if I have to take on/off pieces... even if it is just the front wheel. So this rack is designed to swallow the tandem whole - with fenders and wheels all attached. You lift the rear wheel, roll back the tandem, and the clip catches it and holds in place. It is tight and I get a little breathing room with the 26" wheels and 25mm wide tires. But, a larger tandem would still fit. It takes about 20 seconds to load and unload the bike.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/2_6e489661793dcf422db8ccf27371d9106fa5c772.jpg)
Center console area between middle seats
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/3_7585a5e7754448337369ff52befff5cbcbcbc2ed.jpg)
Base of Rack. Holes drilled and tapped on the vertical pieces so screws can hook under the U shaped steel in the van.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/4_0c696680a5207a2607a1a99b1d5375152d5b5ba8.jpg)
Setting up the rear wheel height. Raising the rear wheel means the stokers drop bars are above the middle seats so they can fully recline.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/6_82d9e4c2680a58932b8cb084f8d37badfe6a5c6a.jpg)
Tabs for the Yakima tray.
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/7_f05908a9a7a700641ec379dfd1aea459ddc7f1c7.jpg)
Arm to hold the drive side seat stay. Wanted a way to roll in the bike and have it clip in place.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/10_db2c91c9e6fe498c89abd313419bbc199d1f6157.jpg)
Painted with fold down cup holders attached.
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/11_950f7ba4337963d6ed692c9b6964fd982bd1ada3.jpg)
Front wheel holder. When Testing discovered that the front wheel would move around a bit. In this design the angle iron drops between the rear seat and the rear of the car. The front wheel drops between the square tube.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/13_67be4338a6e344c0ac6482cc89aec2e375910a6a.jpg)
Bike rolled in.
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/15_e22809d9e6d1cb0106ca995684202b528e37389a.jpg)
Believe it or not, the rear hatch closes without touching the wheel or shifters.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/16_de7faacb02699d81ebfb3ae09bb403fd302b0a75.jpg)
Loaded up so nothing is touching the bike.
Bike rolled in.
Likes For sdodd:
You can see current offerings here:
https://www.davincitandems.com/components/
-simon
Likes For sdodd:
Thank you. It's great that DaVinci has a nice selection of crank lengths and spindle lengths. I don't know of any other manufacture that has the choices for tandem cranksets.
Likes For sdodd:
It is never too late to learn! I started welding at 40+ years of age when I took a community college intro to welding class with my 10/12 year old kids. I'm not certified or even very good. Mostly I make brackets and odds and ends for the house or garage. I stay away from anything structural that could get myself or others hurt. In the end, when I work on multi-year projects at work with semi-obtuse end-points, being able to start and finish a project in the garage one weekend is very satisfying. =)
Very nice, we haul our tandems in a 2006 Odyssey and I have to take the front wheel off. I hadn't thought of getting more clearance by raising the rear wheel. I'm going to take a look at such an option (when the weather is a little warmer).
I raised the back to give the stoker bars clearance from the middle row seats. However, it did provide more clearance as I was able to slide the wheel a little over the front center console. I could have moved back 6” more and still opened the console. But I didn’t need to. Maybe it will work for you?
Bikes: Indeed!
Liked 3,550 Times
Very nicely done. Great design.
But you sure went to a lot of trouble for a guy who doesn't like to remove a front wheel!
Brent
Brent
Likes For obrentharris:
1) the incremental effort of building a stable way of hauling the tandem in the van and building it to accommodate the front wheel being on was minimal.
2) taking off the front wheel is OK, but wheels/forks/disks/etc aren't very structural when they are apart so it is easier to damage
3) taking a day to build a rack can be planned and is enjoyable. Taking an extra 5 minutes to take off/put on/secure the tandem each ride is just an extra hurdle to overcome. And when it is raining out, I don't need more de-motivators. =)
simon
That's pretty cool! I've thought of doing something similar for my 2016 Odyssey but am too lazy :-)
Questions:
1. How does it bolt to the seat mounts (I assume) in the second row? Do you have a photo of that?
2. Doesn't the clamp scratch the seatstay? Surprised you don't use a clamp with a coating or padding of some sort.
3. What are the square box-looking things on the uprights of the rack? Cupholders, maybe? If so, bonus points for that!
Questions:
Questions:
Questions:
2) Yes, the clamp has the potential to scratch the seat stay. I put some electrical tape on the seatstay to protect the bike. It isn't really needed as there are no sharp edges on the clamp - they are all rounded. I had a powdercoated version in there at one point instead of just the metal version but it didn't make much difference.
3) the boxes are steel plates with cupholders added. I used 'fisher universal cup holders'. They have a great mechanism for folding and they size well for different size cups. WAAAAAAY better than most of the generic cup holders. $20 each but worth not worry about which kid will break one when. https://www.ultimatecupholders.com/f...cupholder.html Pictures below as well.
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_7124_a4b2a7c8073e650e469f8c0f49f8cafa97fbea82.jpg)
Front view of retention bracket
![](https://cimg7.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_7125_a1e626b95c8014f3d1655b2d19dd66f4c3314b4e.jpg)
Side view of retention bracket
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_7126_0cecd8a1beaa3e78307a266795732c50beaeb60f.jpg)
Cup Holder closed
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/img_7127_8df0d8ddb5ef96e14edc99995b264d2a7f75a0ca.jpg)
Cup holder open
