Road bike hand position - name them
meh
Quoted: 1112 Post(s)
Liked 1,013 Times
Let's get down a silly rabbit hole of bike terminology... I know many terms for hand positions on road bars, but there's one grip I don't know what to call.
Let's start with the basics:
For contrast, this is the position I refer to as 'on the hoods'. Are both grips still referred to as 'on the hoods'?
- On the tops: hands on the horizonal bars, like a flat-bar bike, mostly used on climbing
- On the corners: slight modification of 'on the tops', hands further to the edge of the bars ... where the bars turn forward to the levers. I typically use this for a quick rest to stretch my back or while eating.
- On the hoods: hands on the brake hoods, the most popular/common position
- On the hooks: hands on the drops, right at the front to have easy access to the brakes, common position for descending or to get aero for a break away or sprint
- On the drops: kinda old school since most most modern bars don't have the longer extension to place the hands further back on the drops. On my bikes that have bars that allow this position, it's a nice alternative aero position.
Liked 3,174 Times
the pistol grip is a position i use too.
-YMMV
-YMMV
Likes For Troul:
Quoted: 20810 Post(s)
Liked 9,456 Times
I do something similar to your top photo, but I'm more on top, palms a little more downward facing, lever knob more in the middle of my palm, and my pinky doesn't hook under the shifter. It's probably a little less secure in terms of bumps, but yeah, I only really do that when I'm in front or by myself on a long, clean stretch of road.
Likes For WhyFi:
meh
Liked 1,013 Times
I run two fingers on top, two tucked under the levers. Pinky shifts up, ring fingers down. BTW, I am running MicroShift. That may not work on Shimano/Sram.
Likes For FlMTNdude:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,543 Times
I learned a modified "hands on hoods" position many years ago. I rest the meat of the side of the hand (karate chop) by laying it on where the bar meets the hood, and DON'T wrap my palm or hook my fingers around the hood. The hands rest firmly enough to control the bars, but there's no impingement on the median or ulnar nerves. No grabbing, per se. Light touch.
I grab the hood only when needed (standing, sprinting, shifting or braking). This greatly reduces fatigue.
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
I use that top position. I would call it maybe Aero-hoods? It's always as you say, stretching out at the front, getting a little more aero than the pistol-grip, but without going into the drops. The next step from Aero-hoods is Invisible Aero-Bars. Which is the not-adviseable-on-public-roads elbows-on-the-tops position that you see pros doing when riding a steady pace on the front.
I don't believe the pinky is necessary. If you're in a riding situation where you think you may need quick access to the brakes, you should probably be in the pistol-grip position anyway. And as you say, lots of hoods nowadays (particularly Campag with their horns-design, but also Shimano and SRAM hydraulic levers with the reservoir up top) have plenty of space up above to get a solid grip on the top of the hood.
Likes For Leinster:
Quoted: 1467 Post(s)
Liked 1,495 Times
For me, this is just an alternate hand placement when in an aero position. I can move between this and riding in the drops without changing my overall body position. It's harder to "pistol grip" the hoods when your elbows are bent.
Likes For msu2001la:
meh
Liked 1,013 Times
I should add that I have 5 drop-bar bikes, all with different shifters:
90s version of Campi's Ergo shifters - I can't use the pistol grips with this bike
SRAM hydraulic GX - these are very comfortable with the pistol grip
Shimano 105 - these are good with the pistol grip
Old Shimano Microshifters - I can't use the pistol grip with this set up
Gvenalle GX - great with the pistol grip
N+1 coming in '21 will have SRAM eTap - based on the test ride last fall, these hoods are optimized for the pistol grip
Biker
I more often use a top position by holding the hoods. It gives more aero-pressure to hold and maintain the brake position for a proper grip. Forr me, this is only another hand situation when in an air position. I can move among this and riding in the drops without changing my general body position. It's harder to "single-handed grip" the hoods when your elbows are twisted.
Likes For RICKhudson:
