New wheelset for my Nishiki Cresta?
CL Addict
Bikes: '50s Leon Cattrysse - late 50s Raleigh Lenton Sports - 1960/61 Raleigh Lenton Grand Prix - '72 Canadian Tire Company Supercycle - '74 Raleigh International - '83 Nishiki Cresta - '84 Centurion Turbo - '86 v. Herwerden (Chesini) - '87 Specialized Sirr
Liked 96 Times
What would you suggest? The current set has rims that are too narrow for wider clingers.
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/1920x1080/nishiki_cresta_2385644231b6a3bf99b7e037f261272323237c5c.png)
I will keep the spacing at 126 mm. I could build my own set. I'd like to keep the classic look so ideally silver rims.
I'm also thinking of "upgrading" to 8 speed indexed derailleurs with these Microshift bar end shifter set.
Liked 3,684 Times
Are these 700c wheels? I'll bet those rims will take 32c-35c tires. If you want/need new wheels, velomine has very solid prices on 126 OLD wheels.
Likes For bikemig:
CL Addict
Liked 96 Times
Ah, forgot to mention, yes, these are 700c wheels. The Kenda tires I have on them now are 32c and it took way too much effort to put them on. I will not be able to remove them on the road with a flat.
Liked 3,684 Times
Yeah but that's likely not because of the rim width. Some tire/rim combos are tough to deal with. Have you thought about a thinner rim strip? That sometimes is a big help. In any case, I don't think the problem you are having is the width of the clincher.
This thread has a discussion of rim tape you may find useful; post 17 talks about thinner rim strips:
https://www.bikeforums.net/road-cycl...till-used.html
Likes For bikemig:
CL Addict
Liked 96 Times
![Smilie](images/smilies/smile.gif)
Team Beer
Bikes: Too Many
Liked 161 Times
I have an 85 Cresta but mine has 27" wheels. I found mine as a frame set but couldn't get the brakes to work with 700's. I built a nice set of 27" wheels with 600 tri-color hubs and Sun CR18 rims. They have been great wheels for the past 10 years.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Agree with bikemig, the issue is definitely not the width of the rim here.
2019 Salsa Warbird
2019 Salsa Warbird
CL Addict
Liked 96 Times
The rims are Rigida red label.
Liked 3,684 Times
Also wired on clinchers, at least in my experience, tend to be a little easier mounting and dismounting than tires with kevlar beads. You'll pay a small weight penalty but on a touring bike that is not a big deal.
Those are Rigida 16-22 rims. Good rims, they came stock on Peugeot UO 10s and other bikes as well. I've never had an issue mounting a tire on those rims. Plus they're reasonably wide rims very suitable for touring and just fine for 32c tires (or a bit wider).
CL Addict
Liked 96 Times
For what use and on what type of surface? There are hundreds of good 700c tires in that width.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 3,684 Times
Panaracer paselas are good tires and the black/gum looks good on a vintage bike. I like Schwalbe marathon racers as well and the reflective stripe is a plus.
CL Addict
Liked 96 Times
A 38c may or may not fit on your bike. Some folks get 38c tires to fit with no issues on vintage touring bikes but BITD when this bike was designed 32c (or 27 x 1 and 1/4) was more or less the touring standard. A 35c should fit with no problems.
Likes For b dub:
Liked 3,684 Times
They'll fit on those rims. They're wide rims and those are very good tires. The limiting factor is generally not the rim but the frame. You have lots of clearance on a touring bike with cantilevers.
CL Addict
Liked 96 Times
Thank you all for your advice and input. I really appreciate it. Happy Friday!
jj
If you haven’t yet made the purchase, Panaracer’s Gravel King is nearly as comfy as the Pasela, quieter, and far more durable.
CL Addict
Liked 96 Times
Sunshine
Liked 7,731 Times
gravel king slick, gravel king ss(semi slick), gravel king sk(knobby)
All 3 varieties then come in regular casing or + casing, with the + casing being stronger for more abusive riding.
This makes the options seemingly endless.
To make it simpler, get some slick or ss tires in the regular casing- those will roll the fastest.
Oh, and they come in black or tan sidewall.
If you want to spend more $ for more supple and faster tires thats great as there are plenty more options, but the Gravel King line is popular for a reason.
2019 Salsa Warbird
2019 Salsa Warbird
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/e3fad3c8_49dd_41a6_8b60_948513f96ed5_464feef10a48e8a142368541bdf8d58a6080ac8f.jpeg)
I’ve got Compass Stampede Pass Extralights on my 1982 Nishiki Cresta. Size 32c x 700c. What a difference in ride quality these make. Used to have Paselas on this bike, but these Compass tires are far superior. Not the cheapest tires out there but to me they were worth every penny.
These are Velocity Dyad rims which are perfect for touring bikes and tandems.
Likes For Saguaro:
jj
Oh yeah, totally forgot that they do non-slick and + versions which you could accidentally buy- sorry!
My non+ set held on for about 4K miles before they were worn enough to be violated by one of the hundreds of roofing nails I routinely encounter.
The Slick nonplussed is as sweet as I think one can get while still having reasonably good glass & thorn protection, though I’ve yet to try out the Herse’s. This summer probably.
FWIW, I’m having surprisingly good fortune with some Conti GP5K 28mm on my winter bike doing 150-200 miles/week
since November (their tread is softer than the GK, so I feel a bit more comfortable on ice with them). Apparently they’re doing a gumwall version finally and also a 32mm version, but I don’t know about a gumwall 32... They probably cost about the same as the Herses.
