Let's see your bike oddities
Quoted: 3026 Post(s)
Liked 3,902 Times
So that rim joint not the opposite of the valve hole thread got me to thinking.
Some years ago, I bought several low flange FB hubs from a friend. Condition didn't matter, I mostly wanted them for the internals - axles, cones, etc. One of them, the last one, has been sitting in the bin for 5-6 years, Another friend proposed a trade, and I was game to get it out of the bin so it would see the light of day. I thought it was an orphan rear, 36 holes and the condition was quite good. It had never been laced. I was wrong about the hole count, it is actually a 32.
Well you say, what makes that odd? It's 18 holes on the drive side, 14 holes on the non drive side.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,451 Times
Speaking of hubs, I've seen plenty of Sturmey rear hubs and have several, but this is the first Sturmey front I've ever seen and it was in the co-op's dumpster a few weeks ago.
Likes For thumpism:
Phyllo-buster
Quoted: 2299 Post(s)
Liked 2,061 Times
Staying with the steel hub theme, these 30's - 50's BH Solite hubs have floating alloy dust caps on the front hub, as well as the outer shield as part of the dust cover on the rear. I suspect they machined the front openings too wide and threw a bodged quickie dustcap on it. The fit is less than first class or whatever the right phrase is.
Quoted: 1117 Post(s)
Liked 1,341 Times
I quite like them, they have a BIG HOLE look to them, like the Lambert crank.
Likes For oneclick:
Liked 2,451 Times
Cool!
Liked 3,902 Times
FB low flange hubs 2 by iabisdb, on Flickr
Liked 1,341 Times
You can still get the balls in and cleaning's a bit more, but the only other reason to have removable dustcaps is to replace races - and they are ground into the shell
so you'd be taking the flange off anyway.
Liked 1,341 Times
Simplex oddity
A delrin rear mech with no top pivot spring: This came on a mid-70's Peugeot UG45 -ish, a child's drop-bar bike with 24" wheels - and a five-speed rear, it was listed as a "Prestige Mini":
Bikes: 1964 Huffy Sportsman, 1972 Fuji Newest, 1973 Schwinn Super Sport (3), 1982 Trek 412, 1983 Trek 700, 1989 Miyata 1000LT, 1991 Bianchi Boardwalk, plus others
Quoted: 589 Post(s)
Liked 704 Times
Sakae ATB handlebar stem
Maybe not strange to others, but strange to me. This Sakae stem is on a 1986 Schwinn Mirada that I was recently working on for my sister. A lot going on with this stem.
Sakae from 1986 Mirada ATB
Steel stem transitioning to aluminum upper with brake cable hole and removable clamp. Looks like a lot of engineering for a lower end bike.
Freewheel Medic
Quoted: 1465 Post(s)
Liked 2,223 Times
thumpism and oneclick I also have one of the Sturmey Archer front hubs. I actually had cudak888 lace it for me for a '39 Schwinn New World project I completed many years ago.
Bob
Bob
Likes For Hproduguidon:
Likes For oneclick:
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 1001 Post(s)
Liked 679 Times
"WOW" doesn't even begin to describe it.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Likes For tiger1964:
car dodger
this '71 raleigh competition I picked up at an estate sale had "custom" cable routing. No need for saddle height adjustment for a one owner bike!
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Likes For norskagent:
Liked 679 Times
While familiar, at a distance, with cable-less FD's -- my brother raced on one, and still has the bike -- I have never seen a set-up like this one. Seems like an extreme end-result of a "pre-cable" era, even though RD's had cables at this point. Was this an off-the-shelf option, or a one-off fabrication. At the very least, someone had to make that clevis for this application, I might presume.
Bikes: Indeed!
Quoted: 1515 Post(s)
Liked 3,502 Times
Cinelli aluminum bars with bulge instead of shim.
Brent
Brent
Liked 3,902 Times
I have seen that in one or two places. Certainly an odd duck.
Liked 3,902 Times
feros ferio
Quoted: 1399 Post(s)
Liked 1,345 Times
A British gent who had retired to Fallbrook (San Diego County) CA after a career with Hetchins, had a beautiful collection of 24 Hetchins road bikes spanning 24 model years. One of them had a reversed bottom bracket, with the fixed cup on the left and the adjustable cup on the right. One could easily enough do that with Italian or French threading (I have also seen the use of two adjustable cups a few times to allow chainline finetuning), but this was English(!) threading. Someone at the factory presumably left-threaded the left side of the BB shell and right-threaded the drive side.
Liked 679 Times
tiger1964 a collector friend who owns 200 bikes has already seen this system but could not confirm that it was an option or an ingenious homemade system
Regardless, I think this part is winning the Bike Oddities Sweepstakes so far.
Liked 2,451 Times
