GRX Di2 shifters + RS785 brakes (post-mount)
I've got a 2016 Diverge which is post-mount. Anyone know if the GRX Di2 shifters will work with RS785 brakes? The Shimano compatibility tool says they are compatible, but the spec sheets for the shifters and levers call for different brake hose kits.
GRX Di2 shifter - SM-BH90-JK-SSR brake hose
RS785 calipers - SM-BH59-J-SS brake hose
Anyone using this shifter + caliper combination?
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
In my experience, all of the two-piston Shimano calipers are interchangeable.
The RS785 calipers are re-branded XT, so if they work with XT, they will work with those.
(Also, FYI: You can get the RS785 calipers along with the Di2 shifters for $250 at Universal Cycles. (I bought a backup set when the price briefly dropped to $199).)
Occam's Rotor
Liked 2,331 Times
I don't have GRX, but I think the main difference is the pivot point is supposed to be more ergonomic for folks who ride the hoods.
I ride the hoods on the RS785 and they are the most comfortable brakes I ever had.
Yeah, other than ergonomics all Shimano Hydraulic brakes are interchangeable and will work with one another. I really wanted the new GRX di2 hoods and brakes but like you said, the upgrade is quite expensive so I went with Ultegra. The different brake hose kits are for the caliper end because the XT and I believe all post mount have a banjo fitting where the newer flat mount calipers like the GRX's have a straight threaded fitting. Just re-use the hose you have and all is good!
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
The GRX Di2 brifters cannot be bought. Shimano has missed every restock promise since August 2020. And the GRX Di2 lineup is part of that. If it isn't in stock now you're not going to see it until next year at soonest.
Bikes: Colnago Crystal, GT MTB, Fuji D6 TT bike, Breezer Beltway commuter
Quoted: 35 Post(s)
Liked 13 Times
I have a bike with GRX shifters and XT post mounted brakes.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
https://www.merlincycles.com/en-us/sh...eid=4e44856289
Liked 406 Times
You correct that they are hard to find. Merlin has the whole 2x GRX 815 Di2 groupset in stock right now.
And, of course, presuming Merlin even ships Shimano to the USA anymore.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I would have to say the GRX Di2 levers really are that much better. The braking power is definitely an improvement over the DA 9120 brakes on my road bike, which are supposed to be better than the RS785 levers. If you can find them I wouldn't hesitate on buying them.
