Enve alloy road hubs
Just recently found a pair of these at an attractive price. Sounds like a quality hub, but I notice the spoke hole spacing looks a bit odd. Like the holes are grouped in 2's. Will they lace up like any other hub (2X) or are there any quirks I need to know about? Thanks
Liked 479 Times
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/800x400/1615680187_d927b854322ee39a8c0b417a59eec242bd329fd1.jpeg)
Like this one? I imagine you could build it up with a 24-hole rim if you duplicate the lacing pattern and calculate the correct spoke length. This will not lace like a 24-spoke wheel, but like a 48 with half the spokes left out. With 24 spokes it's 2x. If you imagine the missing spokes, it would be a virtual 4x pattern, I think.
Yup. Exactly like that. Just eye-balling it, the pattern and angles resembles that of a straight pull hub. So I might try the DT Swiss spoke calculator with a negative spoke head off set.
Update;
Despite the odd spoke hole pattern, these hubs laced up 2-cross like a normal hub. And the DT Swiss spoke calculator gives proper spoke lengths. Figuring out which hub hole the first spoke goes into if you want the label visible through the valve hole was a bit of a guessing game, but once I got that figured out, the wheel built up as usual.
Liked 479 Times
Update;
Yup, turns out the paired hole spacing doesn't have a noticeable affect on spoke length calculations using the DT Swiss calculator. No need to do anything exotic. The classical hub formulas work just fine. However, it does throw off Musson's method for selecting the first spoke hole to get the valve hole on the rim pointed at the hub label.
Liked 4,079 Times
I have to laugh. I have never considered lining up rim and hub beyond getting parallel spokes at the valve. I suppose I should have known that this was important to some! Built my first wheel 49 years ago and have built nearly every wheel I've ridden since. I just learned something new. (Maybe I'll incorporate this into my next re-rim. That would be easy. But no rush. I'm going to start swapping over to tubular as my current rims wear out so new builds for a while.)
do you mind sharing your hub specs that you added to the dt swiss spoke calculator ?
I also have this hub and looking to build two wheelsets.
Type:
model:
pitch circle left
pitch circle right
flange dist left
flange dist right
Ø spoke hole
weight
Type:
model:
pitch circle left
pitch circle right
flange dist left
flange dist right
Ø spoke hole
weight
Update;
