Chainring choices ....
Quoted: 14 Post(s)
Any suggestions please .....
When I bought my road bike it came with 50-34 chain rings and an 11-32 cassette. That was fine for a while but then I found it very easy to ride and difficult to get any speed. So I changed to 52-36 with an 11-34 cassette. That helped. But now ... I feel that I am getting a relaxed ride again and rarely use the small chain ring.
I have recently moved house and there are things called mountains just up the road and they are certainly challenging.
I was thinking to put the 34 back on and replace the 52 with a 53 chain ring. The idea being some help going up hills with the smaller gear and a bit more grunt on the level and down hill.
What is wrong with that?
What is the brand/part number of the chainrings? Nicer ones will not shift as well with mismatched pairs, because the shifting aids on the ring are designed to work with the other.
Quoted: 14 Post(s)
Thank you for the response and I had not even thought of this, I sort of assumed that the number of teeth was the key...
I do not recall any part number, the brand of the 52 and 36 is Stronglight. I will have to wait for daylight to look at the others. In any event I do not think they will be expensive.....
So apart from that you do not seem to say there is a problem with a 53-34 combination?
What cranks are they on?
Over the hill
Quoted: 1017 Post(s)
Liked 1,258 Times
You should be able to pedal a 52/11 comfortably to about 40mph. It sounds like you use way too slow of a cadence, which is not only bad for sustainability (edited as per Asgelle's and WhyFi's comments), but also bad for your knees. Instead of messing with the chainrings any more, I suggest you work on increasing your pedal cadence. A typical optimum cadence is somewhere around 80-100 RPM.
It's like riding a bicycle
Sunshine
Quoted: 11100 Post(s)
Liked 7,699 Times
At some point, just tuck and let gravity pull you down the hill.
Also, if you are pedaling at a good cadence and still genuinely need 53/11, then you should look into a pro contract.
Over the hill
Liked 1,258 Times
Efficiency depends on a lot of factors (speed, wattage, resistance, etc.) but I'm quite confident based on the OP's description that they would benefit from a higher cadence.
https://www.roadbikerider.com/whats-...cling-cadence/
https://www.trainerroad.com/blog/wha...ke-you-faster/
Quoted: 20810 Post(s)
Liked 9,456 Times
Too fast OR too slow of a cadence is inefficient. If the OP is feeling too "relaxed" with a 52/11, they're almost definitely on the too slow side. Even at 60 RPM, a 52/11 would be comfortably cruising around at 23 mph.
Likes For WhyFi:
It's the only sense that has any meaning. In urbanknight's usage I have no idea what it means. It could be efficiency (though wrong), but it could also be speed, endurance, comfort, fatigue resistance, etc. In other words, no meaning at all.
Habitual User
Quoted: 5111 Post(s)
Liked 8,439 Times
Make sure your derailleurs can handle the increased range.
Over the hill
Liked 1,258 Times
Liked 9,456 Times
Well, it's the sense in which it has the most specific meaning. I mean, I hear you and you're right, but language means what people decide it means. In this context, enough people have decided that it has to do with perceived effort and a middle ground between grinding and frying your legs and spinning too lightly and too quickly.
Likes For WhyFi:
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
When I asked about stepping up to taller gears a while back on this forum I was also lectured on increasing my cadence. Since leaving the MTB behind and moving up to the lighter road bikes my cadence has increased all of its own accord. Where I used to maintain low 60's, I am now in the 80's. Yet when I get back on the MTB I have a hard time pushing more than 70 RPM. Go figure. I say if the OP wants taller gearing, go for it. I'm 71 and have always been a pedal masher and never have I had knee problems. I'd give that Wickworks a try that HTupolev mentioned. I have a 52T large on both of my road bikes mated to a 14T on the old Giant and an 11T on the Fuji. I go as fast as I want on the Fuji and don't feel a need to go taller. I would like taller gears on the Giant too, but unless I want to do major upgrades on the old beast, it is what it is. Good luck
Over the hill
Liked 1,258 Times
They do make 56t chainrings with 110 BCD (assuming the chain wrap is ok and the FD can handle the tooth difference).
Quoted: 14 Post(s)
hmmm ... nothing like opening a can of worms.
To answer questions ....
The crankset is Shimano Claris.
The 50 and 34 chainrings are Shimano. (this appears to be stamped on the gear but very difficult to read).
The 52 and 36 chainrings are Stronglight. (52T 10/9 speed Comapact concept 110mm; 36T 10/9 speed 7075 CNC)
urbanknight ... you say "You should be able to pedal a 52/11 comfortably to about 40mph." That is about 64 khm and to be able to ride at that speed would encourage me to spend more time on my road bike and less on my mountain bikes. Actually that is really fast. I have no idea how to accomplish that with the existing legs / gears ... if I ride down a slight slope I cannot catchup with the chain no matter how fast I try to rotate the crank. On the level I am always wanting to push more but again as soon as I get moving I cannot catch up with the chain.
Thank you mstateglfr for that observation, I did not know about the tooth difference being critical since it is the same front derailleur but I do take the point. A pro contract at my age is not a reality but thanks for the suggestion.
Over the hill
Liked 1,258 Times
https://bike.shimano.com/en-EU/produ...D-R2000-F.html
