MTB rider - Perineal pain
Hi,
New to cycling...
purchased an MTB a couple of months ago..... made some initial adjustments to my saddle to get rid of knee pain... and now am stuck with a dull pain on the perineal side and it keeps lingering around an entire day ...
My cycling frequency has reduced from 5 times a week to 3 times a week due to this pain
Should i go in to adjust my handle bar height to help me reduce the perineal pain. Will this help reduce..
Or probably should i go ahead and change my saddle, i do understand that anatomy of each person varies.
Am around 5'8"...
Looking forward to inputs.
Thanks,
New to cycling...
Am around 5'8"...
Thanks,
Quoted: 6353 Post(s)
Liked 4,956 Times
Are you positively certain it's perineal pain? Or is it perhaps more a pain in the bones and joints that you sit on?
The former will need some adjustment of you or saddle, maybe even a change of saddle or change of bike if it's completely wrong size for you. The latter might just need a few more weeks of riding to get your body used to using that part of your body to sit on.
Quoted: 1085 Post(s)
Liked 1,348 Times
Hi,
New to cycling...
Am around 5'8"...
Thanks,
New to cycling...
Am around 5'8"...
Thanks,
People generally tolerate a too low seat height than a too high seat height.
Likes For phughes:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
You probably raised your saddle thinking that was your problem with knee pain. That is what caused your perineum pain. Drop your saddle slightly. Go here and read about saddle height. https://www.stevehoggbikefitting.com...ard-can-it-be/ People try to jack up the seat height so much, thinking that is causing them to lose power, or causing their pain, when usually, note I said usually, seat height isn't causing their knee pain, it is generally overuse, or simply trying to do too much too soon. Here is what you started with, "New to cycling..." That is what was causing your knee to hurt.
Bottom line, unless you are riding a wholly ill fitting bike, maybe you're using the wrong size stem, wrong crank arms, pushing too hard on the cranks during your ride or a combination of all these factors, if your knee pain is bad enough id suggest taking a serious break from biking for the sake of your joint health.
Bikes: 73 Schwinn Continental, (my first), 1993 Nobelette, Cannondale 500,Team Fugi, Raleigh Supercourse, Raleigh Gran Sport, 1976 Krystal, Tsunami, Giant Boulder SE, Series 30 Paramount, Scott Unitrack, As long as I have room the Hoard will grow...
Quoted: 26 Post(s)
Liked 25 Times
Let us know about your saddle. When I started riding again, I used a nice soft, squishy saddle. I started training for a triathlon and had perineal pain. And it pinched all of the area. My LBS let me try a few different saddles , I found one that felt great, stiff and long nosed, and all was well. Old saying: you won't ride if the saddle is uncomfortable.
Liked 1,348 Times
