Crank extractor and rusty crank advice (with pics)
I’m trying to clean up the cranks on a commercial grade spin bike, and I have two questions:
1. Does the extractor need the magnetic fitting to make its base wider, or use it without?
2. Other than steel wool, any good advice for getting rust out of the nooks and crannies? Any soaks, applications helpful? I plan to prime and repaint once rust is gone.
Thanks for any advice!
With adapter on
Without adapter
Need to clean up this crustiness.
With adapter on
Without adapter
Quoted: 4239 Post(s)
Liked 3,973 Times
I believe the BB and arms are of the "power spline" design and will need the "traditional" smaller extractor end. BTW keep these cranks tight on the BB axle, we've seen far more fall off the spindles then the number in use would suggest.
A popular rust remover solution is Best Rust Remover | Remove Rust Quickly with Evapo-Rust® (evapo-rust.com) I would try it on an out of sight spot before coating the hole part, just to be sure you're good with the results. Andy
AndrewRStewart
AndrewRStewart
Liked 3,130 Times
scrub with CLR, wash off with WD-40. Repeat as needed.
-Oh Hey!
-Oh Hey!
Quoted: 1188 Post(s)
Liked 1,154 Times
Hit the cranks with paint stripper. Afterwards soak in a citric acid solution (maybe 10 tablespoons in a quart of warm water) until the rust is gone, rinse immediately and dry and prime asap.
Quoted: 6353 Post(s)
Liked 4,956 Times
That's not a lot of rust. Put some primer on it, paint it and be done. If you are using automotive type paints and a primer with zinc, then no issue whatsoever.
Liked 1,154 Times
Liked 3,130 Times
being an inside use only equipment, I'd rough it up & apply an epoxy coating such as chassis saver on it.
-Oh Hey!
-Oh Hey!
Quoted: 194 Post(s)
Liked 206 Times
Only you can answer that.
We just blindly grope in the dark, hoping you tell us more before we blunder too badly...
Liked 3,130 Times
Presumably it depends on how smart a finish that you want - some people would be satisfied with something like Hammerite slapped over it, others would want something like new.
We can give you the tips, but in the end, you're doing the work.
-Oh Hey!
-Oh Hey!
Looks like evapo rust is available at home depot for less than $10. Seems like a good opportunity to try something news. I’m cleaning this up to sell, no more room in the house. It works fine, but is unsightly and will hurt resale. I could by a replacement crankset for $70, but would rather go the elbow grease route I suppose, esp if I don’t want to take a bigger loss on the sale. Thanks for all of the tips!
Liked 3,130 Times
-Oh Hey!
-Oh Hey!
Liked 4,956 Times
If you do a really fine perfect paint job that will last forever, you'll probably spend more on the paint job than you'd have gotten if you just spray some paint on it and be done.
If you are selling it used, then the people buying it should expect it to be used.
I’m not sure I understand why though. I want them to look nice and hold up, regardless of whether or not they are for me or for someone else. My refinish plan would be pretty much the same either way I think. If refinishing cost more than replacing, I would wind up just replacing them - same again either way. I do appreciate the good advice - I feel like the tips have been invaluable.
Liked 3,130 Times
cost effective responses would have ensued first.
-Oh Hey!
-Oh Hey!
