So, can it be fixed?
Rider who can know more
Bikes: 1995 Trek 850 Mountain Track turned trail and road bike, 1989 Centurion Le Mans RS, 1993 Bianchi Advantage. Dead: 1982 Schwinn Traveler
Liked 8 Times
A couple days back I was in a bike accident where I got banged up with tons of trail rash and my child on a trail-a-bike got away with a couple bumps (whew). But my bike now looks like this:
Now the tech at our LBS says that obviously the fork is toast but since this has a lugged frame there may be hidden damage inside the lugs, and I think I may be seeing some separation, that makes it unsafe to ride.
I was wondering before I take it in for a 2nd opinion do they have a reasonable assessment for what could be going on here? I know the fork is dead but the rest of the frame makes me wonder.
Edit: Closeup of the headtube and the space there with a toothpick in it.
That would be iffy at best with a professional straightening but since you use it to tow your child that would be a "no way"!!! If your fork breaks while riding you lose control sending your kid into traffic, a tree, etc. Just make sure you check the rest of the frame very closely for signs of separation and paint cracks. Fortunately that old Schwinn can take a beating and may be OK. The old Schwinn experts here can advise on a replacement fork since it may have some hard-to-find threading on the steerer tube.
Liked 8 Times
That fork is scrap. But the rest of the frame is my question.
And thank you for helping me clarify my question.
Looks to me as if the downtube suffered damage as well. Look at the underside of the tube near the head tube lug, looks as if it is crumpled. The frame and fork appear to be a write off
Likes For alcjphil:
Liked 3,055 Times
you may want to try a post in frame builders forum https://www.bikeforums.net/framebuilders/ (think a couple of guys may be close to you) and add pictures showing the head tube with another 2 inches of top tube and down tube to see if any deformation can be seen in those areas
super good that the kiddo is ok......
Life is too short not to ride the best bike you have, as much as you can.
Likes For squirtdad:
Liked 4,088 Times
It looks like the downtube (and lug) are bent. But this is a conservatively spec'd and built frame. It might well be just fine; simply with a touch less wheelbase and slightly quicker steering. (You might look at a slightly straighter; ie less rake, fork to compensate. The combo will bring the front wheel closer so you will have more toe overlap.)
Yes, most would say don't ride it. But bikes like yours have been ridden with shortened wheelbases for the past century. If it were mine and I liked the bike, I'd look for a fork of similar length and say around 40mm rake and try it. Like it? Ride it (and keep your eye out for a nice replacement). If you ride this bike to failure, that failure will probably be at the headtube, not a good one. But the next two or three years? I'd guess the bike will do just fine. And that area is very easy to see and watch. It's old fashioned steel, so nothing is going to happen quickly.
Now I did do this almost exact same crash to my previous winter/rain/city fix gear and simply replaced the frame but I had already crashed that bike hard twice (15 and 10 years before and both were new fork times). It had 27,000 miles on it and had earned its retirement. That bike was a Miyata 610. Probably not all that far from yours in specs, durability, etc.
Before you do anything, lay the bike down minus front wheel. Tape a yardstick to the headtube osone edge runs down the center. Place another front wheel 2 inches forward of the centerline like it was on the bike. Close to the downtube? or does that look OK? If it is close, you can straighten the frame. I've never done it or seen anyone else do it but there is at least one thread on BF to go to.
Likes For 79pmooney:
Really Old Senior Member
Take a good straight edge and lay it along the "long" tubes to see if there is a bend.
Clark W. Griswold
Liked 4,281 Times
Would you want to continue carrying your child on that frame after the fork is bent like that. It is an old Schwinn nothing worth a ton of money and certainly not worth putting a child and their father at risk over saving some gas pipe steel from the 80s. You do you but I wouldn't put money towards the bike even if it could potentially be safe the thought of it being more compromised now would loom overhead.
Likes For veganbikes:
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Liked 217 Times
Negative - not worth the risk, and it's easy to find a comparable frameset cheaply, so it's new bike scouting time.
Blamester
If you have a fork that fits and the tools, you could do it and see. But otherwise get a new frame or bike.
What's the condition of the rest of the bike?
Liked 2,202 Times
There are a couple of pieces to this, one of which is getting your child to get back on the trail-a-bike.
If you replace the frame/bike, it might be an easier sell since you got a better bike that won’t crash.
John
John
That was a HARD hit. I guess if the bike was an expensive model, a very valuable classic, etc., you might start looking into stripping it down, doing a very thorough inspection and maybe deciding to replace the fork and ride. But it's not and further, it looks to be in rough shape overall. There's a fine line between being intelligently frugal and being cheap - to me, trying to fix this up and continue riding it is the latter.
- Mark
- Mark
SE Wis
Liked 3,428 Times
Old Schwinn. Nothing special. Buy something like a used 90's rigid mountain bike and upgrade.
https://allentown.craigslist.org/bik...302597468.html
Likes For dedhed:
Liked 8 Times
Liked 8 Times
As for the bike, what is wrong with it? It is something multiple LBS have tuned up and never said anything was wrong other than being old.
Liked 8 Times
Well the tech said there is concern about the the brazing in the lugs due to bike age and the severity of impact. And that led to this question.
Blamester
And is the rest of the bike worth saving. Like are the wheels and brakes good or the tyres or the gears.
Likes For blamester:
Liked 8 Times
As for the rest of the parts: brakes and lever and shifters seem good. The freewheel has had some use but not more than a few hundred miles. The chain is newish and the shifters could use a cleaning but they work. The back wheel is good but the front is a question mark.
I was planning on pulling the parts.
Liked 8 Times
Otherwise they did lube it since I took it in for annual check ups. I have to wonder if you're getting hung up on the visual appearance over the mechanical and structural reliability.
If it was unsafe I would expect these trained techs to tell me so. Since they didn't it was human error that got me here. Mine.
SE Wis
Liked 3,428 Times
Blamester
No fork on hand. Sad I didn't grab one the last time I had a chance.
Liked 3,209 Times
can it? Yes. Will it exceed the cost rather than just finding a good frame or ready to go bicycle? More than likely so.
-YMMV
-YMMV
Likes For Troul:
Clark W. Griswold
Liked 4,281 Times
I hit a sizable branch on a hardpack trail and instead of being a bump over it jammed the wheel and I went over. Not something I would normally do but it happened.
