Need hitch bike rack
I just got a new SUV, and need a bike rack to fit a 2" receiver. Most likely I will need a 4 bike carrier, but the most important thing is finding something that is stable and won't harm the frame on my carbon Salsa Warbird. Preferably $400 or less. Suggestions?
Dave
Dave
Quoted: 630 Post(s)
Liked 369 Times
Sunshine
Quoted: 11048 Post(s)
Liked 7,596 Times
Not sure of a quality 4 bike 2" rack that doesnt clamp to the frame and costs less than $400.
Raise your budget, lower your standards, or buy used.
Bikes: Niner RLT RDO, Trek Remedy 9.8
Quoted: 108 Post(s)
Liked 117 Times
+1 for the 1upusa rack - but you are not going to get a new one for under $400. Even a quality rack that is used may still be over your budget.
Quoted: 1873 Post(s)
Liked 693 Times
Don't get a Kuat, they eat through your fork. Sold mine to get a 1Up. And you won't get anything quality for under $400.
2019 Salsa Warbird
2019 Salsa Warbird
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
My Kuat doesn't even touch the fork.
Likes For Rolla:
Sunshine
Liked 7,596 Times
Yeah those racks are fine- Thule, Saris, etc have similar ones to that. A few friends use the 4 bike versions and they've lasted the years I've known em.
Quoted: 324 Post(s)
Liked 251 Times
That connects to the frame, which it seemed like you didn't want since you mentioned harm to your frame. Pretty sure everyone figured you want a rack that doesn't attach to your frame.
I think a lot of the hesitation with carbon frames and bike carriers are with the non-platform type of bike carriers. I think one that has a padded frame support like that, where the weight is still on the platform, is fine.
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
I have a Transit four bike rack that is similar/identical to the Home Depot rack - less than $200 on sale at Performance Bike 8 years ago. It has carried carbon framed bikes on more than thirty thousand miles of road trips without incident - with plenty of snow, rain and wind thrown in. On matte paint, the padding against the top tube will create a shiny spot, but that's been the only issue.
If I had to do it again, I'd go with a two bike expandable to 4 set-up. Very rarely need to carry four these days.
Likes For tigat:
Agree with others -- the 1up USA or Kuat NV 2 along with the add-ons are the best options. I like the Kuat personally, especially if you have a bike with fenders - the 1up doesn't work especially well with fenders on the rear, though it can be fine if needed. The Kuat shouldn't even be touching the fork unless you have a fat bike or something (my Trek Farley's suspension fork barely clears on the Kuat NV 2). Kuat looks nicer IMO and is faster to fold too.
Likes For seinberg:
Likes For Clipped_in:
Liked 693 Times
You and Rolla must not be using the Kuat NV version. Which model do you have?
2019 Salsa Warbird
2019 Salsa Warbird
Quoted: 427 Post(s)
Liked 340 Times
+1 for the Kuat. No problem with damage to the fork if you use it correctly. The Transit 3-bike is less than $400. The Sherpa 2-bike is less. I own both. 4-bike racks tend to be quite a bit more expensive due to the extra reinforcement needed to support that much weight.
Liked 693 Times
2019 Salsa Warbird
2019 Salsa Warbird
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
The aluminum arms don't corrode and peel and get stuck to the point where you can't use the adjustable arm at all?
Quoted: 427 Post(s)
Liked 340 Times
Here is the user guide. Pages 8 - 11. Be sure no grit remains between bike and holding arm and be sure holding arm is as tight as it will go to eliminate any movement between the arm and the bike. https://www.kuat.com/wp-content/uplo...user-guide.pdf
Hollywood Hitch Racks
I have found them reliable and cheap. They do rust if you leave them on in the winter with salt on the road. Lots of clones around too with different names.
https://hollywoodracks.com/collectio...rm-hitch-racks
Küat Sherpa 2.0 vs NV 2.0
I’ve been lusting for a Küat Sherpa 2.0 for years. Those of you with a Küat NV 2.0 - what in your mind makes the NV 2.0 worth $200 more than the Sherpa 2.0?
Either way, gorgeous bike racks.
Rubber side down
Bikes: are fun! :-)
Quoted: 5 Post(s)
Liked 225 Times
I don't have an NV 2.0 but I can tell you that the main differences are the Sherpa is designed primarily for road bikes (low weight) whereas the NV is built for mountain bikes (higher weight). It also has the available extension to give it a 4 bike capacity, and it also has the built-in repair stand. Which one you get simply depends on what your needs are. If you just want to carry a couple of road/gravel bikes then the Sherpa would be fine.
