Lock tire on binder bolts - slipping seatpost
Locktite on binder bolts - slipping seatpost
Hi all,
I have a seatpost that keeps slipping. I’ve tried liquid torque and I’ve replaced the old binder bolt but it’s still an issue. It’s better than it was but still dropping slightly. The new binder bolt is the same length as the old one which I believe was the original for the frame and is 19mm. I just ordered a 16mm to see if that might do it but I’m also thinking I’ll throw some blue locktite on the threads. Is there any reason I shouldn’t use locktite on minor components like this?
Likes For Dsprok:
Liked 5,020 Times
What kind of seat tube and binder clamp is it? Just a typical slot cut into the top of the seat tube with a clamp around it? Check to be certain the clamp isn't closing up completely when tightened or that the slot isn't closing up underneath the clamp. If one or both are, then you need to address that.
Locktite is a desperation move that will haunt you or another at some later date.
Liked 5,020 Times
So what prevents you from tightening up the clamp more? If the bolt has a shoulder on it, then maybe you are against that with the nut. In that case I'd imagine you got the wrong size post for your tube. That particular post has eighteen different diameter selections.
And even if you used the originally spec'd diameter, your your seat tube might not be that anymore.
I’m pretty positive the seat post is a good fit. There’s no play at all before tightening it. Even when I use grease or liquid torque, most of it ends up on top of the tube once I re-insert the post.
(rhymes with spook)
Liked 745 Times
Well, I imagine the binder bolt might be preventing me from tightening more. As I said, the new one is 19mm just like the original so I’ve ordered a 16mm in hopes of that allowing me to tighten it up more.
btw, i don't imagine the thomson post is original to your frame. do you have the original seat post?
you should make sure it's the right size. if it's .2mm smaller, you may not notice play, but it will surely slip if you're unable to get the binder to squeeze the seat tube anymore. someone suggested a shim. you might try a cutting from a soda can. that, or tell the forum what bike what you have and the diameter size stamped on your post
When I get the smaller binder bolt, I may try the can trick as well.
Friction between the seat post and interfacing seat tube is what keeps the seat post from slipping. As you tighten the binder bolt, it squeezes the seat tube to the seatpost. The more squeezing force, the more friction generated.
Perhaps you can try a carbon assembly paste, which is used to increase friction with less squeezing force. I imagine it like a gritty compound that ensures carbon parts don't slip without applying so much squeezing force that it crushes the carbon members.
https://www.amazon.com/Park-Tool-SAC...92580281&psc=1
Likes For mdarnton:
Loctite thread compound will not help.
(rhymes with spook)
Liked 745 Times
No, the Thomson is definitely not original. It’s a 26.8. I do not have the original but the only reference I can find to the bike’s original specs are for 26.8. It’s a 1987 Raleigh Technium Trilite.
if you're using the original length for a binder bolt, i can't understand what the problem with it would be. i mean, there shouldn't be problem with it. my '82 trek came with a 27.2mm seat post...which surprised me because i thought for the age of the frame, it'd be smaller....like 26.8. as many frames of the era were.
anyway, i sold a '94 trek 520 i had to a friend and made a recommendation to him on a seat post to buy. i told him 27.2 should be the size. i even looked it up on the web. the info i could wasn't clear and i was wrong. it was 26.8, so i gave him a nice one i had to compensate for the mistake. iow's, it's quite possible your seat post is just too small. it could be 27mm for the correct size. in which case, shimming it would be a better idea than using shorter binder bolt and therefore crimping the seat lug beyond what's intended
Liked 1,095 Times
If your binder bolt working itself loose is not the cause of your seatpost slipping, thread locker will accomplish nothing except for making it more difficult to loosen the bolt. You might try some valve grinding compound, it may be grittier than the Liquid Torque.
I tried the aluminum can shim. I can’t even get one layer of aluminum in there so the seatpost size must be appropriate. I’ll have to wait for the shorter binder bolt to show up and hopefully that will do it.
At least, I’ve never seen one designed to do that.
The edges of the slot should remain pretty much parallel when the bolt is torqued down.
I suppose it’s possible that the binder bolt is running out of thread before it gets tight enough to hold the post.
Liked 797 Times
Hi all,
Hi all,
Can you post a picture or two?
Liked 735 Times
Have you tried cleaning the seattube, maybe use an alcohol soaked rag on a broom handle, or paint pole, something like that. Maybe there is some really slippery lube in the seattube. Just don't soak the rag so much that it runs down to the bb.
I hadn’t thought of that but I was under the impression that grease actually prevented seat post slippage.
Liked 735 Times
I always looked at grease as a preventive measure--to keep the post from fusing to the seat tube. You still want something on the post, but maybe something like carbon paste, which from what I understand, has a bit of grit to it. Sounded like you've tried other things, and that the post is sized correctly, so figured something in the seat tube is letting it slip. Let us know when you get it to stay instead of slip. I know at least one (me) who is curious.
(rhymes with spook)
Liked 745 Times
if i were you, i'd either go buy a set of digital calipers at the auto store, or take your frame and post up there and let them measure it. you really shouldn't have to go through this much trouble to get a correct seat post to stay put. unless you're running out of threads on the binder bolt like someone suggested
He put a couple of photos on his album page:
[MENTION=348045]tough_boots[/MENTION]'s Album:
https://www.bikeforums.net/g/user/348045
https://www.bikeforums.net/g/album/21153738
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/640x480/80-img_0137_7059cce86e72c45cca1810a18531281d859e827f.jpg)
Unfortunately not a closeup of the rear... yet.
Personally I'm not a big fan of greasing seatposts. And, at least in this case, aluminum (or composite) frame, and painted/anodized seatpost, it should be fine assembling dry (if that is the case).
I like the idea of a reflector or second clamp just above the lug.
Likes For CliffordK:
